Ok voici, même procédure que précédemment:
[29-10-2021 13:18:45][INFO] : Démon prêt et à l'écoute !
[29-10-2021 13:18:45][INFO] : Connexion au controleur Unifi...
[29-10-2021 13:18:45][INFO] : Login au controleur : OK
[29-10-2021 13:18:46][DEBUG] : getDeviceNameMappings : {#####}
[29-10-2021 13:18:46][INFO] : Ecoute des évènements du controleur : OK
[29-10-2021 13:18:46][INFO] : Connecté au controleur Unifi !
[29-10-2021 13:18:46][INFO] : --Demande régulière WLAN et SITE (60sec)--
[29-10-2021 13:18:46][DEBUG] : Resultat getWLanSettings : [#####]
[29-10-2021 13:18:47][DEBUG] : Resultat checkControllerUpdate : [{"latest":"6.4.54","download_link":"https://fw-download.ubnt.com/data/unifi-controller/1c14-debian-6.4.54-0bb324db149c4793bd93c23d0f9be683.deb","has_upgradable_controller":false}]
[29-10-2021 13:18:47][DEBUG] : Resultat getSiteSettings : {"super_cloudaccess":{"_id":"#####","key":"super_cloudaccess","device_id":"#####","x_certificate_arn":"OBFUSCATED","x_certificate_pem":"OBFUSCATED","x_private_key":"OBFUSCATED","device_auth":"OBFUSCATED","enabled":true,"ubic_uuid":"#####"},"super_identity":{"_id":"#####","key":"super_identity","name":"UDM","hostname":"UDM"},"super_mgmt":{"_id":"#####","key":"super_mgmt","discoverable":false,"data_retention_time_enabled":true,"data_retention_time_in_hours_for_5minutes_scale":24,"data_retention_time_in_hours_for_hourly_scale":720,"data_retention_time_in_hours_for_daily_scale":2160,"data_retention_time_in_hours_for_monthly_scale":8760,"data_retention_time_in_hours_for_others":2160,"time_series_per_client_stats_enabled":true,"minimum_usable_hd_space":500,"enable_analytics":false,"multiple_sites_enabled":false,"autobackup_enabled":true,"autobackup_cron_expr":"0 0 1 * *","autobackup_days":0,"autobackup_max_files":7,"backup_to_cloud_enabled":false,"live_updates":"auto","override_inform_host":false,"override_inform_host_type":"unifi-os","live_chat":"disabled","autobackup_timezone":"Europe/Paris","google_maps_api_key":"OBFUSCATED"},"super_fingerbank":{"_id":"#####","key":"super_fingerbank","fingerbank_key":"#####"},"super_mail":{"_id":"#####","key":"super_mail","provider":"cloud"},"super_fwupdate":{"_id":"#####","key":"super_fwupdate","sso_enabled":true,"x_sso_token":"#####","available_controller_channels":["release"],"available_firmware_channels":["release"]},"super_sdn":{"_id":"#####","key":"super_sdn","sso_login_enabled":true},"connectivity":{"_id":"#####","site_id":"#####","key":"connectivity","enabled":false,"uplink_type":"gateway","x_mesh_essid":"#####","x_mesh_psk":"#####"},"element_adopt":{"_id":"#####","site_id":"#####","key":"element_adopt","enabled":true,"x_element_essid":"#####","x_element_psk":"#####"},"guest_access":{"_id":"#####","site_id":"#####","key":"guest_access","auth":"none","redirect_https":true,"restricted_subnet_1":"192.168.0.0/16","restricted_subnet_2":"172.16.0.0/12","restricted_subnet_3":"10.0.0.0/8","redirect_url":""},"ntp":{"_id":"#####","site_id":"#####","key":"ntp","ntp_server_1":"0.ubnt.pool.ntp.org","ntp_server_2":"1.ubnt.pool.ntp.org","ntp_server_3":"2.ubnt.pool.ntp.org","ntp_server_4":"3.ubnt.pool.ntp.org"},"mgmt":{"_id":"#####","site_id":"#####","key":"mgmt","advanced_feature_enabled":true,"x_ssh_enabled":true,"x_ssh_bind_wildcard":false,"x_ssh_auth_password_enabled":true,"unifi_idp_enabled":true,"x_mgmt_key":"#####","x_ssh_username":"ubnt","x_ssh_password":"OBFUSCATED","x_ssh_keys":[],"wifiman_enabled":true,"x_api_token":"#####","x_ssh_sha512passwd":"OBFUSCATED","led_enabled":true,"alert_enabled":true},"dpi":{"_id":"#####","site_id":"#####","key":"dpi","enabled":true,"fingerprintingEnabled":true},"lcm":{"_id":"#####","site_id":"#####","key":"lcm","enabled":true,"brightness":80,"idle_timeout":300,"sync":true,"touch_event":true},"usg":{"_id":"#####","site_id":"#####","key":"usg","ftp_module":true,"gre_module":true,"h323_module":true,"pptp_module":true,"sip_module":false,"tftp_module":true,"broadcast_ping":false,"receive_redirects":false,"send_redirects":true,"syn_cookies":true,"offload_accounting":true,"offload_sch":true,"offload_l2_blocking":true,"mdns_enabled":true,"upnp_enabled":false,"upnp_nat_pmp_enabled":true,"upnp_secure_mode":true,"mss_clamp":"auto","geo_ip_filtering_countries":"","geo_ip_filtering_block":"block","geo_ip_filtering_enabled":true,"geo_ip_filtering_traffic_direction":"ingress","icmp_timeout":30,"other_timeout":600,"tcp_close_timeout":10,"tcp_close_wait_timeout":60,"tcp_established_timeout":7440,"tcp_fin_wait_timeout":120,"tcp_last_ack_timeout":30,"tcp_syn_recv_timeout":60,"tcp_syn_sent_timeout":120,"tcp_time_wait_timeout":120,"udp_other_timeout":30,"udp_stream_timeout":180,"firewall_wan_default_log":false,"firewall_lan_default_log":false,"firewall_guest_default_log":false},"usw":{"_id":"#####","site_id":"#####","key":"usw","dhcp_snoop":true},"network_optimization":{"_id":"#####","key":"network_optimization","site_id":"#####","enabled":true},"country":{"_id":"#####","key":"country","site_id":"#####","code":"250"},"locale":{"_id":"#####","key":"locale","site_id":"#####","timezone":"Europe/Paris"},"provider_capabilities":{"_id":"#####","key":"provider_capabilities","site_id":"#####","upload":994000,"download":944000},"ips":{"_id":"#####","key":"ips","site_id":"#####","enabled_categories":["botcc","emerging-worm","emerging-malware","emerging-mobile","tor","emerging-exploit","emerging-shellcode","emerging-useragent","dshield"],"endpoint_scanning":true,"honeypot":[],"honeypot_enabled":false,"ips_mode":"ips","restrict_ip_addresses":true,"restrict_tor":false,"suppression":{"alerts":[],"whitelist":[]},"dns_filtering":true,"dns_filters":[{"allowed_sites":[],"blocked_sites":[],"blocked_tld":[],"description":"","filter":"none","version":"v4","network_id":"#####","name":""},{"allowed_sites":[],"blocked_sites":[],"blocked_tld":[],"description":"","filter":"none","version":"v4","network_id":"#####","name":""},{"allowed_sites":[],"blocked_sites":[],"blocked_tld":[],"description":"","filter":"none","version":"v4","network_id":"#####","name":""},{"allowed_sites":[],"blocked_sites":[],"blocked_tld":[],"description":"","filter":"none","version":"v4","network_id":"#####","name":""},{"allowed_sites":[],"blocked_sites":[],"blocked_tld":[],"description":"","filter":"none","version":"v4","network_id":"#####","name":""},{"allowed_sites":[],"blocked_sites":[],"blocked_tld":[],"description":"","filter":"none","version":"v4","network_id":"#####","name":""},{"allowed_sites":[],"blocked_sites":[],"blocked_tld":[],"description":"","filter":"none","version":"v4","network_id":"#####","name":""},{"allowed_sites":[],"blocked_sites":[],"blocked_tld":[],"description":"","filter":"none","version":"v4","network_id":"#####","name":""}],"utm_token":"#####","last_alert_id":"616338439-2021-10-29T12:58:44.244838+0200","last_nmap_id":"741313043-Fri Oct 29 11:57:36 2021"},"auto_speedtest":{"_id":"#####","key":"auto_speedtest","site_id":"#####","enabled":true,"interval":20},"rsyslogd":{"_id":"#####","key":"rsyslogd","site_id":"#####","port":"514","enabled":false,"debug":false,"this_controller":false,"this_controller_encrypted_only":false,"ip":"","netconsole_enabled":false,"netconsole_host":"","netconsole_port":"514"}}
[29-10-2021 13:18:50][DEBUG] : MàJ Device #####(UDM){"_id":"#####","ip":"#####","mac":"#####","model":"UDM","type":"udm","version":"1.10.4.3702","adopted":true,...}
