Commandes Non Creees et Erreur 500
Oui c’est un bug qu’il va falloir que je répare…il y a une manip à faire pour passer outre mais je ne me souviens plus… Je regarde ça rapidement et je te dis
Merci, pour le pb d’erreur 500 comme tu l’as résolu ce n’est plus nécessaire
Euhh non il est toujours là
Celle ci tu l’as toujours?
oui
0000|[Wed Jul 10 15:44:32.083065 2024] [:error] [pid 653] [client 34.98.187.25:0] PHP Fatal error:  Uncaught Error: Call to undefined function yaml_parse_file() in /var/www/html/plugins/solarman/core/class/solarman.class.php:140
0001|Stack trace:
0002|#0 /var/www/html/core/class/DB.class.php(196): solarman->postInsert()
0003|#1 /var/www/html/core/class/eqLogic.class.php(1022): DB::save(Object(solarman), false)
0004|#2 /var/www/html/core/ajax/eqLogic.ajax.php(498): eqLogic->save()
0005|#3 {main}
0006|thrown in /var/www/html/plugins/solarman/core/class/solarman.class.php on line 140, referer: https://jeedom.nas-jpf.synology.me/index.php?v=d&m=solarman&p=solarman
0007|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0008|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0009|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0010|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0011|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0012|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0013|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0014|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0015|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0016|[Wed Jul 10 22:14:58.061215 2024] [:error] [pid 2780] [client 192.168.1.126:49184] PHP Fatal error:  Uncaught Error: Call to undefined function yaml_parse_file() in /var/www/html/plugins/solarman/core/class/solarman.class.php:400
0017|Stack trace:
0018|#0 /var/www/html/plugins/solarman/core/ajax/solarman.ajax.php(44): solarman::raz_ConfigInverter('deye_sg04lp3.ya...', '239')
0019|#1 {main}
0020|thrown in /var/www/html/plugins/solarman/core/class/solarman.class.php on line 400, referer: http://192.168.1.50/index.php?v=d&m=solarman&p=solarman&id=239
0021|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
0022|sh: 1: cannot create /var/www/html/core/class/../../log/cron_execution: Permission denied
alors il faudrait modifier le fichier html/plugins/solarman/plugin_info/packages.json en remplaçant ce qui y est par:
  "pip3" :{
    "pyyaml" : {},
    "pyudev" : {},
    "serial" : {},
    "requests" : {},
    "umodbus" : {}
  "apt" : {
    "php-yaml" : {}
  "npm": {
    "js-yaml" : {}
  "post-install" : {
    "restart_apache" : true
une fois fait, relancer les dépendances
Normalement tu devrais avoir un log que tu peux envoyer stp
Je viens de faire la modif et relancer la dépendance mais toujours pas de logs supplémentaires
Ça te gênerai de me donner un accès à ton jeedom ?
je t’ai envoyé les login en DM
j’ai trouvé pour l’erreur du postinsert. Essaie la v 1.0.9 et dis moi si tu as toujours des soucis.
Hello, J’ai installé la version 1.0.9 et relancer l’installe, mais j’ai toujours la même erreur. Si tu es dispo, je peux t’ouvrir l’accès
0000|[Sun Jul 14 22:47:54.586492 2024] [:error] [pid 2780] [client 192.168.1.126:54639] PHP Fatal error:  Uncaught Error: Call to undefined function yaml_parse_file() in /var/www/html/plugins/solarman/core/class/solarman.class.php:401
0001|Stack trace:
0002|#0 /var/www/html/plugins/solarman/core/ajax/solarman.ajax.php(44): solarman::raz_ConfigInverter('deye_sg04lp3.ya...', '241')
0003|#1 {main}
0004|thrown in /var/www/html/plugins/solarman/core/class/solarman.class.php on line 401, referer: http://192.168.1.50/index.php?v=d&m=solarman&p=solarman&id=241```
Je viens de voir ton message… Ce soir ou dans l’après midi peut être si tu es dispo.
Pour les personnes qui pourraient rencontrer le même problème, voici c e qui a marché chez moi:
Ces commandes sont à adapter en fonction de votre installation, chez @Djipii la version php affichée sur la page santé de jeedom était la 7.0 et celle affichée lorsque l’on saisi php -v en ligne de commande était la 7.3
