encore moi (et désolé)
les ordres en tahoma local ne passe pas (open n’ouvre pas et close ne ferme pas)
mais avec le plugin tahoma (cloud) ca fonctionne très bien
@chris94440 merci pour ton aide
Ok ça marche
Tu peux vider les log du plugin et daemon … Faire un open et close, une synchronisation et m’envoyer les logs stp en mp
[2023-10-23 22:19:01][INFO] : Client connected to [127.0.0.1:50284]
[2023-10-23 22:19:01][INFO] : Message read from socket: b'{"action":"execCmd","deviceUrl":"io:\/\/1201-4430-6743\/4160700","commandName":"open","parameters":"","name":"open","execId":"","apikey":"pKDTmwX1iZAcMduJqpMxUcxsAhMXIsc7EViwLnVMmTeTFLdNMrxuLTZBt6tF4EYT"}'
[2023-10-23 22:19:01][INFO] : Client disconnected from [127.0.0.1:50284]
[2023-10-23 22:19:01][INFO] : == action execute command ==
[2023-10-23 22:19:02][INFO] : Send to jeedom : {'eventItem': {'parameters': [''], 'deviceURL': 'io://1201-4430-6743/4160700', 'command': {'parameters': [''], 'command': 'open', 'execId': '4f48db5d-a5a4-42de-a76a-5cb0e783bab8', 'state': 'FAILED', 'rank': 0, 'deviceURL': 'io://1201-4430-6743/4160700', 'failureType': 'INVALID_COMMAND'}, 'execId': 'e8f57c19-3e68-4f0f-9493-b9658fb2e36d', 'name': 'CommandExecutionStateChangedEvent', 'state': 'FAILED', 'failureType': 'INVALID_COMMAND', 'CommandName': 'open', 'rank': 0}}
[2023-10-23 22:19:02][INFO] : Send to jeedom : {'eventItem': {'failureType': 'INVALID_COMMAND', 'oldState': 'INITIALIZED', 'execId': 'e8f57c19-3e68-4f0f-9493-b9658fb2e36d', 'name': 'ExecutionStateChangedEvent', 'newState': 'FAILED'}}
[2023-10-23 22:19:12][INFO] : Client connected to [127.0.0.1:54644]
[2023-10-23 22:19:12][INFO] : Message read from socket: b'{"action":"execCmd","deviceUrl":"io:\/\/1201-4430-6743\/4160700","commandName":"close","parameters":"","name":"close","execId":"","apikey":"pKDTmwX1iZAcMduJqpMxUcxsAhMXIsc7EViwLnVMmTeTFLdNMrxuLTZBt6tF4EYT"}'
[2023-10-23 22:19:12][INFO] : Client disconnected from [127.0.0.1:54644]
[2023-10-23 22:19:12][INFO] : == action execute command ==
[2023-10-23 22:19:12][INFO] : Send to jeedom : {'eventItem': {'parameters': [''], 'deviceURL': 'io://1201-4430-6743/4160700', 'command': {'parameters': [''], 'command': 'close', 'execId': 'cf352251-a7cb-4fb7-9091-5a4a38b2582c', 'state': 'FAILED', 'rank': 0, 'deviceURL': 'io://1201-4430-6743/4160700', 'failureType': 'INVALID_COMMAND'}, 'execId': '8ad5d088-9aa3-44a3-b66e-b561cb40b385', 'name': 'CommandExecutionStateChangedEvent', 'state': 'FAILED', 'failureType': 'INVALID_COMMAND', 'CommandName': 'close', 'rank': 0}}
[2023-10-23 22:19:12][INFO] : Send to jeedom : {'eventItem': {'failureType': 'INVALID_COMMAND', 'oldState': 'INITIALIZED', 'execId': '8ad5d088-9aa3-44a3-b66e-b561cb40b385', 'name': 'ExecutionStateChangedEvent', 'newState': 'FAILED'}}
(merci pour ta réactivité mais faut dormir lol)
C’est ma requête http qui est mal constituée
Peux tu m’envoyer le résultat du synchroniser stp …
Les commandes infos sont ok ?
Tu m’envoyer une copie des commandes créer stp
les commandes infos me semblent ok (je n’utilise que pedestrian)
liste des commandes:
tahomalocalapi_daemon (1).txt (73,7 Ko)
Je regarde et reviens vers toi
Bonjour. Je viens d’installer le plugin (je suis sur une Tahoma V2 et mon Jeedom tourne sur une VM sur Synology). Le daemon ne se lance pas. Dans la log Tahomalocalapi, j’ai le message « Daemon_info → {« log »:« tahomalocalapi »,« state »:« nok »,« launchable »:« ok »} » et dans la log daemon « Error: importing module jeedom.jeedom ». Merci de votre aide.
Et dans la log du daemon y a quoi ?
Re,
Dans la log du daemon tu dois avoir plus d’info …exemple à l’execution d’une commande open sur un volet roulant velux IO
Peux tu vider les logs (plugin et daemon) et me les envoyer par MP stp
@chris94440
Hello
Je viens de pousser une beta j’espère qu’elle va solutionner le soucis … car sinon j’ai pas trop de piste…
@chris94440
[2023-10-24 09:38:22]DEBUG : |D| script_response = b’null’
J’étais avec le dévelopeur et la on coince
Comprends pas ?
désolé, mauvais post
pas de pb. Je ferais ça cet aprem. Suis pas sur place et vu l’install pas chaud pour le faire tout de suite en remote
tu veux peut etre que je passe en debug pour avoir plus d’info ?
EDIT:
je suis impatient j’ai deja essayé ton dernier push beta. Le portail s’ouvre et se ferme !
Ca fonctionne
donc la derniere beta solutionne ton soucis c’est bien cela ?
Bonjour, dans la log du daemon, j’ai juste « Error: importing module jeedom.jeedom »
Ce soucis est lié à jeedom
as tu regardé ce post ?
Je viens de le lire et je ne comprends pas tout… Que faudrait-il que je fasse ?
j’avoue j’ai pas lu…je regarde cela dans la journée ou ce soir.
C’est le seul daemon que tu ne peux pas lancer ?
oui, c’est le seul
