Depuis putty je tape :
miiocli roborockvacuum il te donne les commandes
Après
miiocli roborockvacuum --ip --token « la commande que tu veux test »
Normalement ça te donne les valeurs de la commande appeler
Voilà les commandes fournies par la première demande .
Commands:
add_timer Add a timer.
carpet_cleaning_mode Get carpet cleaning mode/avoidance setting.
carpet_mode Get carpet mode settings.
child_lock Get child lock setting.
clean_details Return details about specific cleaning.
clean_history Return generic cleaning history.
consumable_reset Reset consumable information.
consumable_status Return information about consumables.
create_nogo_zone Create a rectangular no-go zone (gen2 only?).
create_software_barrier Create software barrier (gen2 only?).
delete_timer Delete a timer with given ID.
disable_dnd Disable do-not-disturb.
dnd_status Returns do-not-disturb status.
dust_collection_mode Get the dust collection mode setting.
edit_map Start map editing?
enable_lab_mode Enable persistent maps and software barriers.
fan_speed Return fan speed.
fan_speed_presets Return available fan speed presets.
find Find the robot.
fresh_map Return fresh map?
get_backup_maps Get backup maps.
get_room_mapping Retrieves a list of segments.
get_segment_status Get the status of a segment.
goto Go to specific target.
home Stop cleaning and return home.
info Get (and cache) miIO protocol information…
install_sound Install sound from the given url.
last_clean_details Return details from the last cleaning.
locale Return locale information.
log_upload_status partial(func, *args, **keywords) - new…
manual_control Give a command over manual control interface.
manual_control_once Starts the remote control mode and executes…
manual_start Start manual control mode.
manual_stop Stop manual control mode.
map Return map token.
mop_intensity Get mop scrub intensity setting.
mop_mode Get mop mode setting.
pause Pause cleaning.
persist_map Return fresh map?
raw_command Send a raw command to the device.
resume_or_start A shortcut for resuming or starting cleaning.
resume_segment_clean Resuming cleaning a segment.
resume_zoned_clean Resume zone cleaning after being paused.
segment_clean Clean segments.
serial_number Get serial number.
set_carpet_cleaning_mode Set carpet cleaning mode/avoidance setting.
set_carpet_mode Set the carpet mode.
set_child_lock Set child lock setting.
set_dnd Set do-not-disturb.
set_dust_collection Turn automatic dust collection on or off.
set_dust_collection_mode Set dust collection mode setting.
set_fan_speed Set fan speed.
set_fan_speed_preset Set fan speed preset speed.
set_mop_intensity Set mop scrub intensity setting.
set_mop_mode Set mop mode setting.
set_sound_volume Set sound volume [0-100].
set_waterflow Set water flow setting.
sound_info Get voice settings.
sound_install_progress Get sound installation progress.
sound_volume Get sound volume.
spot Start spot cleaning.
start Start cleaning.
start_dust_collection Activate automatic dust collection.
status Return status of the vacuum.
stop Stop cleaning.
stop_dust_collection Abort in progress dust collection.
stop_segment_clean Stop cleaning a segment.
stop_zoned_clean Stop cleaning a zone.
test_properties Helper to test device properties.
test_sound_volume Test current sound volume.
timer Return a list of timers.
timezone Get the timezone.
update_timer Update a timer with given ID.
use_backup_map Set backup map.
waterflow Get water flow setting.
zoned_clean Clean zones.
