le démon a été relancé, le Pi également
voici les logs
[2022-06-18 19:41:43]DEBUG : Found light model : LCT015
[2022-06-18 19:41:44]DEBUG : Found light model : LST002
[2022-06-18 19:41:44]DEBUG : Found light model : LLC020
[2022-06-18 19:41:44]DEBUG : Found light model : LWV001
[2022-06-18 19:41:44]DEBUG : No configuration found for light : LWV001 => {"id":11,"attributes":{"state":{"on":true,"bri":180,"alert":"none","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-01-20T12:01:18"},"type":"Dimmable light","name":"lampe canap\u00e9","modelid":"LWV001","manufacturername":"Signify Netherlands B.V.","productname":"Hue filament bulb","capabilities":{"certified":true,"control":{"mindimlevel":2000,"maxlumen":550},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"vintagebulb","function":"decorative","direction":"omnidirectional","startup":{"mode":"powerfail","configured":true}},"uniqueid":"00:17:88:01:08:18:64:b1-0b","swversion":"1.93.7","swconfigid":"24097809","productid":"Philips-LWV001-1-ST64CFDLv1"},"client":{}}
[2022-06-18 19:41:44]DEBUG : Use generic configuration : default_color
[2022-06-18 19:41:44]DEBUG : Found light model : LTW012
[2022-06-18 19:41:44]DEBUG : Found light model : LCT015
[2022-06-18 19:41:44]DEBUG : Found light model : LWB010
[2022-06-18 19:41:44]DEBUG : No configuration found for light : LWV001 => {"id":17,"attributes":{"state":{"on":false,"bri":254,"alert":"none","mode":"homeautomation","reachable":false},"swupdate":{"state":"noupdates","lastinstall":"2022-01-20T12:00:28"},"type":"Dimmable light","name":"Lampe escaliers","modelid":"LWV001","manufacturername":"Signify Netherlands B.V.","productname":"Hue filament bulb","capabilities":{"certified":true,"control":{"mindimlevel":2000,"maxlumen":550},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"vintagebulb","function":"decorative","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:08:ee:72:68-0b","swversion":"1.93.7","swconfigid":"24097809","productid":"Philips-LWV001-1-ST64CFDLv1"},"client":{}}
[2022-06-18 19:41:44]DEBUG : Found light model : LWA001
[2022-06-18 19:41:44]DEBUG : No configuration found for light : LWA001 => {"id":18,"attributes":{"state":{"on":false,"bri":143,"alert":"select","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-01-20T12:01:04"},"type":"Dimmable light","name":"Lustre","modelid":"LWA001","manufacturername":"Signify Netherlands B.V.","productname":"Hue white lamp","capabilities":{"certified":true,"control":{"mindimlevel":5000,"maxlumen":800},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"pendantround","function":"functional","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:08:bd:8b:7f-0b","swversion":"1.93.7","swconfigid":"FB5A0F23","productid":"Philips-LWA001-1-A19DLv5"},"client":{}}
[2022-06-18 19:41:44]DEBUG : Found light model : LTE002
[2022-06-18 19:41:44]DEBUG : No configuration found for light : LTE002 => {"id":20,"attributes":{"state":{"on":false,"bri":127,"ct":369,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-01-20T12:00:59"},"type":"Color temperature light","name":"Lustre cuisine","modelid":"LTE002","manufacturername":"Signify Netherlands B.V.","productname":"Hue ambiance candle","capabilities":{"certified":true,"control":{"mindimlevel":200,"maxlumen":470,"ct":{"min":153,"max":454}},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"candlebulb","function":"functional","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:09:0d:24:d2-0b","swversion":"1.93.7","swconfigid":"5672D683","productid":"Philips-LTE002-1-E14CTv2"},"client":{}}
[2022-06-18 19:41:44]DEBUG : Use generic configuration : default_nocolor
[2022-06-18 19:41:44]DEBUG : No configuration found for light : LTE002 => {"id":21,"attributes":{"state":{"on":false,"bri":127,"ct":369,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-01-20T12:00:56"},"type":"Color temperature light","name":"Lustre cuisine","modelid":"LTE002","manufacturername":"Signify Netherlands B.V.","productname":"Hue ambiance candle","capabilities":{"certified":true,"control":{"mindimlevel":200,"maxlumen":470,"ct":{"min":153,"max":454}},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"candlebulb","function":"functional","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:09:0d:24:29-0b","swversion":"1.93.7","swconfigid":"5672D683","productid":"Philips-LTE002-1-E14CTv2"},"client":{}}
[2022-06-18 19:41:44]DEBUG : No configuration found for light : LTE002 => {"id":22,"attributes":{"state":{"on":false,"bri":127,"ct":369,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2022-01-20T12:00:53"},"type":"Color temperature light","name":"Lustre cuisine","modelid":"LTE002","manufacturername":"Signify Netherlands B.V.","productname":"Hue ambiance candle","capabilities":{"certified":true,"control":{"mindimlevel":200,"maxlumen":470,"ct":{"min":153,"max":454}},"streaming":{"renderer":false,"proxy":false}},"config":{"archetype":"candlebulb","function":"functional","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:09:61:33:a0-0b","swversion":"1.93.7","swconfigid":"5672D683","productid":"Philips-LTE002-1-E14CTv2"},"client":{}}
[2022-06-18 19:41:45]DEBUG : Found sensor model : PHDL00
[2022-06-18 19:41:45]DEBUG : No configuration found for sensor : PHDL00 => {"id":"1","attributes":{"state":{"daylight":true,"lastupdated":"2022-06-18T04:06:00"},"config":{"on":true,"configured":true,"sunriseoffset":30,"sunsetoffset":-30},"name":"Daylight","type":"Daylight","modelid":"PHDL00","manufacturername":"Signify Netherlands B.V.","swversion":"1.0"},"client":{}}
[2022-06-18 19:41:45]DEBUG : Found sensor model : RWL021
[2022-06-18 19:41:45]DEBUG : Found sensor model : SML001
[2022-06-18 19:41:45]DEBUG : Found sensor model : RWL022
[2022-06-18 19:41:45]DEBUG : Found sensor model : HUELABSENUM
[2022-06-18 19:41:45]DEBUG : Found sensor model : BEH_STATE
[2022-06-18 19:41:45]DEBUG : No configuration found for sensor : BEH_STATE => {"id":"104","attributes":{"state":{"status":0,"lastupdated":"2022-06-18T17:39:30"},"config":{"on":true,"reachable":true},"name":"textState","type":"CLIPGenericStatus","modelid":"BEH_STATE","manufacturername":"Philips","swversion":"1.0","uniqueid":"2:13:b99f-c8f2-4c43-837b","recycle":true},"client":{}}
[2022-06-18 19:41:45]DEBUG : No configuration found for sensor : BEH_STATE => {"id":"123","attributes":{"state":{"status":0,"lastupdated":"2022-06-18T12:21:59"},"config":{"on":true,"reachable":true},"name":"textState","type":"CLIPGenericStatus","modelid":"BEH_STATE","manufacturername":"Philips","swversion":"1.0","uniqueid":"2:13:d69c-26aa-43fe-a7ca","recycle":true},"client":{}}
[2022-06-18 19:41:45]DEBUG : No configuration found for sensor : BEH_STATE => {"id":"142","attributes":{"state":{"status":1,"lastupdated":"2022-06-18T06:06:03"},"config":{"on":true,"reachable":true},"name":"textState","type":"CLIPGenericStatus","modelid":"BEH_STATE","manufacturername":"Philips","swversion":"1.0","uniqueid":"2:13:3ac8-bb7b-4689-afe5","recycle":true},"client":{}}
[2022-06-18 19:41:45]DEBUG : No configuration found for sensor : BEH_STATE => {"id":"144","attributes":{"state":{"status":0,"lastupdated":"2022-06-02T08:18:55"},"config":{"on":true,"reachable":true},"name":"textState","type":"CLIPGenericStatus","modelid":"BEH_STATE","manufacturername":"Philips","swversion":"1.0","uniqueid":"2:13:6a50-c32b-4acc-8198","recycle":true},"client":{}}
[2022-06-18 19:41:46]DEBUG : Found sensor model : HUELABSENUM
lorsque je relance jeedom ou le demon, la charge remonte peu de temps après,
on le voit sur les graphiques
et la tache id21 fonctionne non stop
