J’ai reçu 2 prises chinoises qui sont censées remonter la puissance.
Modèle : _TZ3000_gjnozsaz
Le plugin Deconz reconnait comme une prise ON/OFF pas plus. En cherchant sur le Net, j’ai récupéré le JSON modifié qui semble récupérer la puissance. Par contre débutant la dessus j’imagine que je dois le placer qq part ici pour qu"il soit lu ?
root@Ubuntu-Jeedom:/var/www/html/plugins/deconz/core# ls
ajax class config i18n js php
Le Json pour ceux qui souhaitent
"schema": "devcap1.schema.json",
"manufacturername": "_TZ3000_gjnozsaz",
"modelid": "TS011F",
"vendor": "_TZ3000_gjnozsaz",
"product": "TS011F",
"sleeper": false,
"status": "Gold",
"path": "/devices/_TZ3000_gjnozsaz.json",
"subdevices": [
"type": "$TYPE_ON_OFF_PLUGIN_UNIT",
"restapi": "/lights",
"uuid": [
"$address.ext",
"0x01"
"items": [
"name": "attr/id"
"name": "attr/lastannounced"
"name": "attr/lastseen"
"name": "attr/manufacturername"
"name": "attr/modelid"
"name": "attr/name"
"name": "attr/swversion"
"name": "attr/type"
"name": "attr/uniqueid"
"name": "state/alert",
"description": "The currently active alert effect.",
"default": "none"
"name": "state/on",
"refresh.interval": 5
"name": "state/reachable"
"type": "$TYPE_CONSUMPTION_SENSOR",
"restapi": "/sensors",
"uuid": [
"$address.ext",
"0x01",
"0x0702"
"items": [
"name": "attr/id"
"name": "attr/name"
"name": "attr/type"
"name": "config/on"
"name": "config/reachable"
"name": "state/consumption",
"refresh.interval": 300
"name": "state/lastupdated"
"type": "$TYPE_POWER_SENSOR",
"uuid": [
"$address.ext",
"0x01",
"0x0b04"
"items": [
"name": "attr/id"
"name": "attr/name"
"name": "attr/type"
"name": "config/on"
"name": "state/current",
"name": "state/power",
"name": "state/voltage",
"bindings": [
"bind": "unicast",
"src.ep": 1,
"cl": "0x0006",
"report": [
"at": "0x0000",
"dt": "0x10",
"min": 1,
"max": 1800
"bind": "unicast",
"src.ep": 1,
"cl": "0x0702",
"report": [
"at": "0x0000",
"dt": "0x25",
"min": 1,
"max": 300,
"change": "0x0000000A"
"bind": "unicast",
"src.ep": 1,
"cl": "0x0B04",
"report": [
"at": "0x0505",
"dt": "0x21",
"min": 1,
"max": 500,
"change": "0x00000003"
"at": "0x0508",
"dt": "0x21",
"min": 1,
"max": 300,
"change": "0x0000000F"
"at": "0x050B",
"dt": "0x29",
"min": 1,
"max": 300,
