Suite au mail de Netatmo :
Dear Netatmo developer,
We hope this message finds you well.
We are writing to inform you of an upcoming change to our API domain configuration. As part of our ongoing efforts to streamline and improve our services, we will be retiring the domain api.netatmo.net and consolidating all API traffic under the existing domain api.netatmo.com.
Effective Date:September 8, 2025
To ensure uninterrupted service, we kindly ask you to update your applications to use api.netatmo.com exclusively before the above date. The structure and functionality of the API remain unchanged — only the domain name is affected.
Le changement de serveurs API de netatmo aujourd’hui a-t-il une incidence sur le plugin ?
Les valeurs ne sont plus récupérées de mon côté depuis 11H le 8/09
PS : si tentative de synchronisation des équipements :
Echec de la requête HTTP : https://cloud.jeedom.com/service/netatmo?path=%2Fgetstationsdata cURL error : Operation timed out after 30000 milliseconds with 0 bytes received
En essayant Netatmopro il semble que l’appel pointe également vers Netatmo.net qui n’est plus opérationnel :
redirectURI:: ex:'GuzzleHttp\\Exception\\ClientException - GuzzleHttp\\Exception\\ClientException - 400 - Client error: `POST https://app.netatmo.net/oauth2/token` resulted in a `400 Bad Request` response: {"error":"invalid_client"} '
