Je viens de changer l’EMMC sur une smart pour passer en 16go. EMMC achetée sur domadoo.
L’installation est simple, mais la je suis bloqué à 55% Initialisation de Jeedom…
J’ai ouvert dans un autre onglet pour voir les log que voici…
[START UPDATE]
****Update from 4.0.61 (2022-10-22 18:40:00)****
Parameters : []
Send begin of update event | OK
Check update | OK
Check rights
Download url : https://github.com/jeedom/core/archive/V4-stable.zip
Download in progress--2022-10-22 16:40:07-- https://github.com/jeedom/core/archive/V4-stable.zip
Resolving github.com (github.com)
140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443 connected.
HTTP request sent, awaiting response 302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable [following]
--2022-10-22 16:40:08-- https://codeload.github.com/jeedom/core/zip/refs/heads/V4-stable
Resolving codeload.github.com (codeload.github.com)
140.82.121.9
Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443 connected.
HTTP request sent, awaiting response 200 | OK
Length: 82237130 (78M) [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K 3% 15.9M 5s
3072K 7% 24.1M 4s
6144K
11% 10.5M 5s
9216K 15% 16.9M 4s
12288K 19% 23.0M 4s
15360K 22% 21.7M 4s
18432K 26% 19.2M 3s
21504K 30% 19.0M 3s
24576K
34% 20.9M 3s
27648K 38% 20.6M 3s
30720K 42% 19.9M 2s
33792K 45% 22.3M 2s
36864K 49% 20.0M 2s
39936K 53% 22.0M 2s
43008K 57% 20.8M 2s
46080K 61% 20.3M 2s
49152K
65% 22.2M 1s
52224K 68% 20.7M 1s
55296K 72% 23.5M 1s
58368K 76% 20.0M 1s
61440K 80% 23.9M 1s
64512K 84% 20.7M 1s
67584K 87% 22.1M 0s
70656K 91% 21.4M 0s
73728K
95% 22.5M 0s
76800K 99% 21.8M 0s
79872K 100% 24.1M=3.9s
2022-10-22 16:40:13 (20.1 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [82237130/82237130] | OK
Cleaning folders | OK
Create temporary folder | OK
Unzip in progress | OK
Clean temporary files (tmp) | OK
Disable all task | OK
Disable all scenario | OK
Moving files
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-4-stable///docs/pt_PT/noteVersion.md because size is 0 | OK
Remove temporary files | OK
Update system into : 4.1.1 | OK
Update system into : 4.1.2cp: cannot stat '/var/www/html/install/update///core/config/scenario': No such file or directory | OK
Update system into : 4.1.3 | OK
Update system into : 4.1.4 | OK
Update system into : 4.1.5 | OK
Update system into : 4.1.7
Warning: apt-key output should not be parsed (stdout is not a terminal)
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: The repository 'https://oph.mdrjr.net/meveric all Release' no longer has a Release file.
E: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: The repository 'https://oph.mdrjr.net/meveric buster Release' no longer has a Release file.
E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'stable-updates' to 'oldstable-updates'
Update Jeedom repository | OK
Update system into : 4.1.15 | OK
Update system into : 4.2.3
Fix repo issue | OK
Update system into : 4.2.4
Update certificate | OK
Update system into : 4.2.11Enable apache remoteip | OK
Update system into : 4.3.0 | OK
Check jeedom consistency
[START CONSISTENCY]
[START CHECK AND FIX DB]
Fix : ALTER TABLE `cmd` DROP INDEX `unique`;
Fix : ALTER TABLE `cmd` DROP INDEX `isHistorized`;
Fix : ALTER TABLE `cmd` DROP INDEX `type`;
Fix : ALTER TABLE `cmd` DROP INDEX `name`;
Fix : ALTER TABLE `cmd` DROP INDEX `subtype`;
Fix : ALTER TABLE `cmd` DROP INDEX `eqLogic_id`;
Fix : ALTER TABLE `cmd` DROP INDEX `value`;
Fix : ALTER TABLE `cmd` DROP INDEX `order`;
Fix : ALTER TABLE `cmd` DROP INDEX `logicalID`;
Fix : ALTER TABLE `cmd` MODIFY COLUMN `configuration` mediumtext NULL
Fix :
CREATE UNIQUE INDEX `unique` ON `cmd` (`eqLogic_id` ASC,`name` ASC)
Fix :
CREATE INDEX `isHistorized` ON `cmd` (`isHistorized` ASC)
Fix :
CREATE INDEX `type` ON `cmd` (`type` ASC)
Fix :
CREATE INDEX `name` ON `cmd` (`name` ASC)
Fix :
CREATE INDEX `subtype` ON `cmd` (`subType` ASC)
Fix :
CREATE INDEX `eqLogic_id` ON `cmd` (`eqLogic_id` ASC)
Fix :
CREATE INDEX `value` ON `cmd` (`value` ASC)
Fix :
CREATE INDEX `order` ON `cmd` (`order` ASC)
Fix :
CREATE INDEX `logicalID` ON `cmd` (`logicalId` ASC)
Fix : ALTER TABLE `cmd` DROP INDEX `logicalId_eqLogicID`;
Fix : ALTER TABLE `config` MODIFY COLUMN `value` mediumtext NULL
Fix : ALTER TABLE `cron` DROP INDEX `deamon`;
Fix : ALTER TABLE `cron` MODIFY COLUMN `option` text NULL
Fix : CREATE INDEX `function` ON `cron` (`function` ASC)
Fix :
CREATE INDEX `deamon` ON `cron` (`deamon` ASC)
Fix : ALTER TABLE `cron` DROP INDEX `type`;
Fix : ALTER TABLE `cron` DROP INDEX `logicalId_Type`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `unique`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `eqTypeName`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `name`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `logical_id`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `object_id`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `timeout`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `generic_type`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `tags`;
Fix : ALTER TABLE `eqLogic` MODIFY COLUMN `configuration` mediumtext NULL
Fix : ALTER TABLE `eqLogic` DROP `eqReal_id`
Fix :
CREATE UNIQUE INDEX `unique` ON `eqLogic` (`name` ASC,`object_id` ASC)
Fix :
CREATE INDEX `eqTypeName` ON `eqLogic` (`eqType_name` ASC)
Fix :
CREATE INDEX `name` ON `eqLogic` (`name` ASC)
Fix :
CREATE INDEX `logical_id` ON `eqLogic` (`logicalId` ASC)
Fix :
CREATE INDEX `object_id` ON `eqLogic` (`object_id` ASC)
Fix :
CREATE INDEX `timeout` ON `eqLogic` (`timeout` ASC)
Fix :
CREATE INDEX `generic_type` ON `eqLogic` (`generic_type` ASC)
Fix :
CREATE INDEX `tags` ON `eqLogic` (`tags` ASC)
Fix : ALTER TABLE `eqLogic` DROP INDEX `logica_id_eqTypeName`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `eqReal_id`;
Fix : ALTER TABLE `eqLogic` DROP INDEX `logicalId`;
Fix : ALTER TABLE `historyArch` DROP INDEX `cmd_id_index`;
Fix : ALTER TABLE `interactDef` ADD `comment` text NULL
Fix : ALTER TABLE `scenario` DROP INDEX `group`;
Fix : ALTER TABLE `update` ADD `updateDate` datetime NULL
Fix : ALTER TABLE `viewData` DROP INDEX `fk_data_zone1_idx`;
Fix : ALTER TABLE `widgets` DROP INDEX `unique`;
Fix : ALTER TABLE `widgets` MODIFY COLUMN `name` varchar(191) NOT NULL
Fix :
CREATE UNIQUE INDEX `unique` ON `widgets` (`type` ASC,`subtype` ASC,`name` ASC)
Fix : CREATE TABLE IF NOT EXISTS `timeline` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`folder` varchar(255) NULL,
`type` varchar(27) NULL,
`subtype` varchar(27) NULL,
`link_id` varchar(27) NULL,
`name` varchar(255) NULL,
`datetime` datetime NOT NULL,
`options` text NULL,
primary key(`id`,`datetime`))
ENGINE InnoDB;
CREATE INDEX `datetime` ON `timeline` (`datetime` ASC)[END CHECK AND FIX DB]
Check jeedom package
warning: commands will be executed using /bin/sh
job 4 at Sat Oct 22 16:41:00 2022 | OK
Check jeedom database | OK
Check crons
Check filesystem rightPHP Fatal error: Uncaught Error: Call to undefined method jeedom::cleanFileSystemRight() in /var/www/html/install/consistency.php:375
Stack trace:
#0 /var/www/html/install/update.php(277): require_once()
#1 {main}
thrown in /var/www/html/install/consistency.php on line 375
Comment dois je faire pour mettre ma sauvegarde ?
