Capteur gaz TZE200_yojqa8xn.TS0601
J’ai fait l’acquisition d’un détecteur de gaz et j’ai tenté son inclusion dans Jeedom via le plugin Zigbee
Lien AliExpress
Il fait parti de la famille des Tuya TS0601 mais n’est pas reconnu par le plugin.
Voici ses infos brutes :
    "ieee": "a4:c1:38:0e:44:58:57:6c",
    "nwk": 54446,
    "status": 2,
    "lqi": "152",
    "rssi": "-62",
    "last_seen": "1661930638.064761",
    "node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "_TZE200_yojqa8xn",
            "model": "TS0601",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 70
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_yojqa8xn"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    4,
                    5,
                    61184,
                    0
                    25,
                    10
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
NB : n’y aurait-il pas un intérêt à ajouter les infos manufacturer (_TZE200_yojqa8xn) dans les libellés des produits supportés en plus du nom du modèle ? Que ce soit dans le plugin ou dans la page Produits compatibles avec le plugin Zigbee
De ce que je vois ce module n’est pas encore compatible zigpy il faut attendre qu’il l’ajout une fois que ça sera fait je l’ajouterai rapidement à jeedom.
Pour l’autre demande je suis pas sur de comprendre car même en ajoutant cette info tu ne peux pas en faire grand chose… Impossible de savoir avant l’achat de savoir ce que tu auras comme modèle avec tuya
Pour l’autre demande, ce n’est pas tant avant l’achat que lors des inclusions. Il arrive souvent qu’un module porte le même nom TSxxxx mais que le manufacturer soit différent. Quand il n’est pas identifié correctement, voir cette info serait un plus. Idem dans la liste de compatibilité. Si on a un module dont ref et manufacturer sont bien indiqués dans la liste comme étant compatibles, on a quand même toutes les chances qu’il fonctionne. La réf a elle seule n’est pas gage de compatibilité et je crois que le visuel non plus…
Je peux mais sache que c’était le cas au début et qu’on m’a dit que ça alourdit trop la page et j’ai du le retirer… Donc je vais le rajouter mais on ça me demande de le retirer dans quelques mois.
Pour info tu peux voir cette information dans configuration du module une fois inclus
Je sais qu’il n’y pas de solution miracle qui satisfasse tout le monde. Effectivement on peut voir cette info une fois le module inclus mais je pense que ça apporte vraiment un plus de l’avoir dans la liste déroulante des équipements.
Et merci d’avoir trié cette liste, avant elle était déroutante, maintenant elle est juste déroulante :smile:
Dans la liste c’est sur que ça passera pas que je mette ça par contre, je vais me faire jeter par les utilisateurs
Puisque qu’on parle de tri (et après on cloture le sujet), penses-tu pouvoir faire qq chose dans l’onglet Noeuds de la fenêtre réseaux Zigbee. Pouvoir trier via des clics sur les entêtes de colonnes serait idéal mais un simple tir par nom serait déjà bien. J’ai plus de 120 devices sur le contrôleur Popp et une 20aine sur le Zigate, quand tu en recherches un c’est galère (le Ctrl + F du navigateur est une solution de contournement). Et quand tu veux vérifier s’ils sont encore tous en vie, c’est pire, sauf à attendre les alertes de timeout (alors qu’un tri sur last communication donnerait la réponse en 2 s)
Faut que je regarde le tri c’est bien mais ça charge vriament pas mal le navigateur et ralenti la page. Ya plein d’endroits j’ai du le retirer et honnêtement sur 120 lignes j’ai des doutes
