Avec le capteur de sommeil, l’appli Withings permet de consulter chaque matin le temps de sommeil total.
Celui ci est en ensuite décomposé en 4 phases : réveillé, sommeil léger, sommeil profond et sommeil paradoxal .
Dans le plugin-withings, seuls les 3 premiers (durée du reveil, sommeil profond & leger) sont remontés. Il manque le temps de sommeil paradoxal pour calculer la durée totale de sommeil.
Est-il possible d’ajouter la durée du sommeil paradoxal (ou REM) dans le plugin ?
L’idée étant de pouvoir reconstituer la durée totale de sommeil (et/ou au lit) en cumulant les différentes durées : Leger+Profond+Paradoxal = durée totale Sommeil + Réveillé = Durée au Lit
Merci d’avance
List of requested data fields, separated by a comma.
Available data fields are listed above.
Ex: data_fields=asleepduration,breathing_disturbances_intensity,deepsleepduration
Standard sleep medicine metrics
nb_rem_episodes
> Count of the REM sleep phases.
sleep_efficiency
> Ratio of the total sleep time over the time spent in bed.
sleep_latency
> Time spent in bed before falling asleep.
total_sleep_time
> Total time spent asleep. Sum of light, deep and rem durations.
total_timeinbed
> Total time spent in bed.
wakeup_latency
> Time spent in bed after waking up.
waso
> Time spent awake in bed after falling asleep for the 1st time during the night.
Other sleep datapoints and vitals
asleepduration
> Duration of sleep when night comes from external source (light, deep and rem sleep durations are null in this case).
> Intensity of breathing disturbances
deepsleepduration
> Duration in state deep sleep (in seconds).
durationtosleep
> Time to sleep (in seconds). (deprecated)
durationtowakeup
> Time to wake up (in seconds). (deprecated)
hr_average
> Average heart rate.
hr_max
> Maximal heart rate.
hr_min
> Minimal heart rate.
lightsleepduration
> Duration in state light sleep (in seconds).
out_of_bed_count
> Number of times the user got out of bed during the night.
remsleepduration
> Duration in state REM sleep (in seconds).
rr_average
> Average respiration rate.
rr_max
> Maximal respiration rate.
rr_min
> Minimal respiration rate.
sleep_score
> Sleep score
snoring
> Total snoring time
snoringepisodecount
> Numbers of snoring episodes of at least one minute
wakeupcount
> Number of times the user woke up.
wakeupduration
> Time spent awake (in seconds).
