J’ai une erreur depuis quelques jours dans ma log Philipshued :
node:internal/modules/cjs/loader:1024
throw err;
Error: Cannot find module 'axios'
Require stack:
- /var/www/html/plugins/philipsHue/resources/philipsHued/jeedom/jeedom.js
- /var/www/html/plugins/philipsHue/resources/philipsHued/philipsHued.js
at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
at Function.Module._load (node:internal/modules/cjs/loader:866:27)
at Module.require (node:internal/modules/cjs/loader:1093:19)
at require (node:internal/modules/cjs/helpers:108:18)
at Object. (/var/www/html/plugins/philipsHue/resources/philipsHued/jeedom/jeedom.js:17:15)
at Module._compile (node:internal/modules/cjs/loader:1191:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
at Module.load (node:internal/modules/cjs/loader:1069:32)
at Function.Module._load (node:internal/modules/cjs/loader:904:12)
at Module.require (node:internal/modules/cjs/loader:1093:19) {
code: 'MODULE_NOT_FOUND',
requireStack: [
'/var/www/html/plugins/philipsHue/resources/philipsHued/jeedom/jeedom.js',
'/var/www/html/plugins/philipsHue/resources/philipsHued/philipsHued.js'
Quelqu’un a-t-il une idée dela cause du problème ? d’une solution ? Merci de votre aide.
