Bonjour, voici les logs en debug
homeconnect
2022-10-18 18:45:07][ERROR] : Erreur lors de l'exécution du cron El nombre del comando no puede estar vacío:homeconnectCmd Object ( [id:protected] => [logicalId:protected] => GET::LaundryCare.Washer.Setting.IDos1BaseLevel [generic_type:protected] => [eqType:protected] => [name:protected] => [order:protected] => [type:protected] => info [subType:protected] => numeric [eqLogic_id:protected] => 453 [isHistorized:protected] => 0 [unite:protected] => ml [configuration:protected] => Array ( [path] => settings/LaundryCare.Washer.Setting.IDos1BaseLevel [key] => LaundryCare.Washer.Setting.IDos1BaseLevel [withAction] => [category] => Setting [unit] => ml ) [template:protected] => [display:protected] => Array ( [generic_type] => DONT ) [value:protected] => [isVisible:protected] => 1 [alert:protected] => [_collectDate:protected] => [_valueDate:protected] => [_eqLogic:protected] => [_needRefreshWidget:protected] => 1 [_needRefreshAlert:protected] => [_changed:protected] => 1 )
[2022-10-18 19:00:26][DEBUG] : cron is due
[2022-10-18 19:00:26][DEBUG] : Fonction updateAppliances()
[2022-10-18 19:00:26][DEBUG] : Fonction majConnected()
[2022-10-18 19:00:26][DEBUG] : Nombre de requêtes envoyées aujourd'hui 95
[2022-10-18 19:00:26][DEBUG] : La requête GET : /api/homeappliances a réussi code = 200 résultat = { "data": { "homeappliances": [{ "brand": "Bosch", "connected": true, "enumber": "WAV28EH0ES/04", "haId": "BOSCH-WAVxxxxxxxxxxxxxxxxx", "name": "Lavadora", "type": "Washer", "vib": "WAV28EH0ES" }] } }
[2022-10-18 19:00:26][DEBUG] : Oui
[2022-10-18 19:00:26][DEBUG] : Fin de la fonction majConnected()
[2022-10-18 19:00:26][DEBUG] : MAJ du programme actif
[2022-10-18 19:00:28][DEBUG] : Nombre de requêtes envoyées aujourd'hui 96
[2022-10-18 19:00:28][DEBUG] : La requête GET : /api/homeappliances/BOSCH-WAV28EH0ES-xxxxxxxxxxxx/programs/active a retourné un code d'erreur 404 résultat = { "error": { "description": "There is no program active", "key": "SDK.Error.NoProgramActive" } }
[2022-10-18 19:00:28][DEBUG] : lookProgramRéponse pour program Active dans lookProgram SDK.Error.NoProgramActive
[2022-10-18 19:00:28][DEBUG] : pas de key ou key = SDK.Error.NoProgramActive
[2022-10-18 19:00:28][DEBUG] : Nombre de requêtes envoyées aujourd'hui 97
[2022-10-18 19:00:28][DEBUG] : La requête GET : /api/homeappliances/BOSCH-WAV28EH0ES-xxxxxxxxxxxxxxxxxx/programs/selected a réussi code = 200 résultat = { "data": { "key": "LaundryCare.Washer.Program.Cotton.Eco4060", "options": [{ "key": "BSH.Common.Option.EnergyForecast", "value": 40, "unit": "%", "name": "Energía" }, { "key": "BSH.Common.Option.FinishInRelative", "value": 13260, "unit": "seconds", "name": "Programación de fin de programa" }, { "key": "BSH.Common.Option.WaterForecast", "value": 40, "unit": "%", "name": "Agua" }, { "key": "LaundryCare.Common.Option.LoadRecommendation", "value": 9000, "unit": "gram", "name": "Carga recomendada" }, { "key": "LaundryCare.Common.Option.ReferToProgram", "value": 0 }, { "key": "LaundryCare.Washer.Option.IDos1.Active", "value": true, "name": "Depósito 1 de i-Dos" }, { "key": "LaundryCare.Washer.Option.IDos2.Active", "value": true, "name": "Depósito 2 de i-Dos" }, { "key": "LaundryCare.Washer.Option.SpinSpeed", "value": "LaundryCare.Washer.EnumType.SpinSpeed.RPM1400", "name": "Velocidad de centrifugado", "displayvalue": "1400 r.p.m." }, { "key": "LaundryCare.Washer.Option.Temperature", "value": "LaundryCare.Washer.EnumType.Temperature.Auto", "name": "Temperatura", "displayvalue": "Auto" }], "name": "Eco 40-60" } }
[2022-10-18 19:00:28][DEBUG] : lookProgramRéponse pour program Selected dans lookProgram { "data": { "key": "LaundryCare.Washer.Program.Cotton.Eco4060", "options": [{ "key": "BSH.Common.Option.EnergyForecast", "value": 40, "unit": "%", "name": "Energía" }, { "key": "BSH.Common.Option.FinishInRelative", "value": 13260, "unit": "seconds", "name": "Programación de fin de programa" }, { "key": "BSH.Common.Option.WaterForecast", "value": 40, "unit": "%", "name": "Agua" }, { "key": "LaundryCare.Common.Option.LoadRecommendation", "value": 9000, "unit": "gram", "name": "Carga recomendada" }, { "key": "LaundryCare.Common.Option.ReferToProgram", "value": 0 }, { "key": "LaundryCare.Washer.Option.IDos1.Active", "value": true, "name": "Depósito 1 de i-Dos" }, { "key": "LaundryCare.Washer.Option.IDos2.Active", "value": true, "name": "Depósito 2 de i-Dos" }, { "key": "LaundryCare.Washer.Option.SpinSpeed", "value": "LaundryCare.Washer.EnumType.SpinSpeed.RPM1400", "name": "Velocidad de centrifugado", "displayvalue": "1400 r.p.m." }, { "key": "LaundryCare.Washer.Option.Temperature", "value": "LaundryCare.Washer.EnumType.Temperature.Auto", "name": "Temperatura", "displayvalue": "Auto" }], "name": "Eco 40-60" } }
[2022-10-18 19:00:28][DEBUG] : lookProgramProgram Selected key = LaundryCare.Washer.Program.Cotton.Eco4060
[2022-10-18 19:00:28][DEBUG] : lookProgram Nom de la commande action Coton éco 40-60 °C
[2022-10-18 19:00:28][DEBUG] : Mise à jour de la valeur de la commande action GET::BSH.Common.Root.SelectedProgram = Coton éco 40-60 °C
[2022-10-18 19:00:28][DEBUG] : Il y a un programme sélectionné
[2022-10-18 19:00:29][DEBUG] : Nombre de requêtes envoyées aujourd'hui 98
[2022-10-18 19:00:29][DEBUG] : La requête GET : /api/homeappliances/BOSCH-WAV28EH0ES-xxxxxxxxxxxxxxxx/programs/selected/options a réussi code = 200 résultat = { "data": { "options": [{ "key": "BSH.Common.Option.EnergyForecast", "value": 40, "unit": "%", "name": "Energía" }, { "key": "BSH.Common.Option.FinishInRelative", "value": 13260, "unit": "seconds", "name": "Programación de fin de programa" }, { "key": "BSH.Common.Option.WaterForecast", "value": 40, "unit": "%", "name": "Agua" }, { "key": "LaundryCare.Common.Option.LoadRecommendation", "value": 9000, "unit": "gram", "name": "Carga recomendada" }, { "key": "LaundryCare.Common.Option.ReferToProgram", "value": 0 }, { "key": "LaundryCare.Washer.Option.IDos1.Active", "value": true, "name": "Depósito 1 de i-Dos" }, { "key": "LaundryCare.Washer.Option.IDos2.Active", "value": true, "name": "Depósito 2 de i-Dos" }, { "key": "LaundryCare.Washer.Option.SpinSpeed", "value": "LaundryCare.Washer.EnumType.SpinSpeed.RPM1400", "name": "Velocidad de centrifugado", "displayvalue": "1400 r.p.m." }, { "key": "LaundryCare.Washer.Option.Temperature", "value": "LaundryCare.Washer.EnumType.Temperature.Auto", "name": "Temperatura", "displayvalue": "Auto" }] } }
[2022-10-18 19:00:29][DEBUG] : MAJ des états BOSCH-WAV28EH0ES-xxxxxxxxxxx
[2022-10-18 19:00:29][DEBUG] : Nombre de requêtes envoyées aujourd'hui 99
[2022-10-18 19:00:29][DEBUG] : La requête GET : /api/homeappliances/BOSCH-WAV28EH0ES-xxxxxxxxxxx/status a réussi code = 200 résultat = { "data": { "status": [{ "key": "BSH.Common.Status.DoorState", "value": "BSH.Common.EnumType.DoorState.Closed", "name": "Puerta", "displayvalue": "Cerrado" }, { "key": "BSH.Common.Status.LocalControlActive", "value": false, "name": "Operación local activa" }, { "key": "BSH.Common.Status.OperationState", "value": "BSH.Common.EnumType.OperationState.Ready", "name": "Estado del procedimiento", "displayvalue": "Listo " }, { "key": "BSH.Common.Status.RemoteControlActive", "value": true, "name": "Control" }, { "key": "BSH.Common.Status.RemoteControlStartAllowed", "value": false }] } }
[2022-10-18 19:00:29][DEBUG] : Réponse dans updateStates : { "data": { "status": [{ "key": "BSH.Common.Status.DoorState", "value": "BSH.Common.EnumType.DoorState.Closed", "name": "Puerta", "displayvalue": "Cerrado" }, { "key": "BSH.Common.Status.LocalControlActive", "value": false, "name": "Operación local activa" }, { "key": "BSH.Common.Status.OperationState", "value": "BSH.Common.EnumType.OperationState.Ready", "name": "Estado del procedimiento", "displayvalue": "Listo " }, { "key": "BSH.Common.Status.RemoteControlActive", "value": true, "name": "Control" }, { "key": "BSH.Common.Status.RemoteControlStartAllowed", "value": false }] } }
[2022-10-18 19:00:29][DEBUG] : status : Array ( [key] => BSH.Common.Status.DoorState [value] => BSH.Common.EnumType.DoorState.Closed [name] => Puerta [displayvalue] => Cerrado )
[2022-10-18 19:00:29][DEBUG] : Mise à jour setting : GET::BSH.Common.Status.DoorState - Valeur :Fermée
[2022-10-18 19:00:29][DEBUG] : status : Array ( [key] => BSH.Common.Status.LocalControlActive [value] => [name] => Operación local activa )
[2022-10-18 19:00:29][DEBUG] : Mise à jour setting : GET::BSH.Common.Status.LocalControlActive - Valeur :false
[2022-10-18 19:00:29][DEBUG] : status : Array ( [key] => BSH.Common.Status.OperationState [value] => BSH.Common.EnumType.OperationState.Ready [name] => Estado del procedimiento [displayvalue] => Listo )
[2022-10-18 19:00:29][DEBUG] : Mise à jour setting : GET::BSH.Common.Status.OperationState - Valeur :Prêt
[2022-10-18 19:00:29][DEBUG] : status : Array ( [key] => BSH.Common.Status.RemoteControlActive [value] => 1 [name] => Control )
[2022-10-18 19:00:29][DEBUG] : Mise à jour setting : GET::BSH.Common.Status.RemoteControlActive - Valeur :true
[2022-10-18 19:00:29][DEBUG] : status : Array ( [key] => BSH.Common.Status.RemoteControlStartAllowed [value] => )
[2022-10-18 19:00:29][DEBUG] : Mise à jour setting : GET::BSH.Common.Status.RemoteControlStartAllowed - Valeur :false
[2022-10-18 19:00:29][DEBUG] : MAJ des réglages BOSCH-WAV28EH0ES-xxxxxxxxx
[2022-10-18 19:00:29][DEBUG] : Nombre de requêtes envoyées aujourd'hui 100
[2022-10-18 19:00:29][DEBUG] : La requête GET : /api/homeappliances/BOSCH-WAV28EH0ES-xxxxxxxxxx/settings a réussi code = 200 résultat = { "data": { "settings": [{ "key": "BSH.Common.Setting.ChildLock", "value": false, "name": "Seguro para niños" }, { "key": "BSH.Common.Setting.PowerState", "value": "BSH.Common.EnumType.PowerState.On", "name": "Estado del electrodoméstico", "displayvalue": "Activado" }, { "key": "LaundryCare.Washer.Setting.IDos1BaseLevel", "value": 65, "unit": "ml" }, { "key": "LaundryCare.Washer.Setting.IDos2BaseLevel", "value": 65, "unit": "ml", "name": "Volumen de dosificación i-DOS: detergente o suavizante" }] } }
[2022-10-18 19:00:29][DEBUG] : Réponse updateSettings : { "data": { "settings": [{ "key": "BSH.Common.Setting.ChildLock", "value": false, "name": "Seguro para niños" }, { "key": "BSH.Common.Setting.PowerState", "value": "BSH.Common.EnumType.PowerState.On", "name": "Estado del electrodoméstico", "displayvalue": "Activado" }, { "key": "LaundryCare.Washer.Setting.IDos1BaseLevel", "value": 65, "unit": "ml" }, { "key": "LaundryCare.Washer.Setting.IDos2BaseLevel", "value": 65, "unit": "ml", "name": "Volumen de dosificación i-DOS: detergente o suavizante" }] } }
[2022-10-18 19:00:29][DEBUG] : setting : Array ( [key] => BSH.Common.Setting.ChildLock [value] => [name] => Seguro para niños )
[2022-10-18 19:00:29][DEBUG] : Mise à jour setting : GET::BSH.Common.Setting.ChildLock - Valeur :false
[2022-10-18 19:00:29][DEBUG] : setting : Array ( [key] => BSH.Common.Setting.PowerState [value] => BSH.Common.EnumType.PowerState.On [name] => Estado del electrodoméstico [displayvalue] => Activado )
[2022-10-18 19:00:29][DEBUG] : Mise à jour setting : GET::BSH.Common.Setting.PowerState - Valeur :Activé
[2022-10-18 19:00:29][DEBUG] : setting : Array ( [key] => LaundryCare.Washer.Setting.IDos1BaseLevel [value] => 65 [unit] => ml )
[2022-10-18 19:00:29][DEBUG] : Création d'une commande info key=LaundryCare.Washer.Setting.IDos1BaseLevel path=settings/LaundryCare.Washer.Setting.IDos1BaseLevel category= Setting
[2022-10-18 19:00:29][DEBUG] : getCmdDetailTranslation La clé LaundryCare.Washer.Setting.IDos1BaseLevel est introuvable
[2022-10-18 19:00:29][DEBUG] : Nom de la nouvelle commande :
[2022-10-18 19:00:29][DEBUG] : Nouvelle commande info : logicalId GET::LaundryCare.Washer.Setting.IDos1BaseLevel et nom tableau {"key":"LaundryCare.Washer.Setting.IDos1BaseLevel","value":65,"unit":"ml"}
[2022-10-18 19:00:29][DEBUG] : Type de création : isset(action) ou isset(type) ou isset(value) 1
[2022-10-18 19:00:29][DEBUG] : Création d'une commande numeric à partir de la value
[2022-10-18 19:00:29][ERROR] : Erreur lors de l'exécution du cron El nombre del comando no puede estar vacío:homeconnectCmd Object ( [id:protected] => [logicalId:protected] => GET::LaundryCare.Washer.Setting.IDos1BaseLevel [generic_type:protected] => [eqType:protected] => [name:protected] => [order:protected] => [type:protected] => info [subType:protected] => numeric [eqLogic_id:protected] => 453 [isHistorized:protected] => 0 [unite:protected] => ml [configuration:protected] => Array ( [path] => settings/LaundryCare.Washer.Setting.IDos1BaseLevel [key] => LaundryCare.Washer.Setting.IDos1BaseLevel [withAction] => [category] => Setting [unit] => ml ) [template:protected] => [display:protected] => Array ( [generic_type] => DONT ) [value:protected] => [isVisible:protected] => 1 [alert:protected] => [_collectDate:protected] => [_valueDate:protected] => [_eqLogic:protected] => [_needRefreshWidget:protected] => 1 [_needRefreshAlert:protected] => [_changed:protected] => 1 )
[2022-10-18 19:15:04][DEBUG] : cron is due
[2022-10-18 19:15:04][DEBUG] : Fonction updateAppliances()
[2022-10-18 19:15:04][DEBUG] : Fonction majConnected()
[2022-10-18 19:15:04][DEBUG] : Nombre de requêtes envoyées aujourd'hui 101
[2022-10-18 19:15:04][DEBUG] : La requête GET : /api/homeappliances a réussi code = 200 résultat = { "data": { "homeappliances": [{ "brand": "Bosch", "connected": true, "enumber": "WAV28EH0ES/04", "haId": "BOSCH-WAV28EH0ES-xxxxxxxxxxx", "name": "Lavadora", "type": "Washer", "vib": "WAV28EH0ES" }] } }
[2022-10-18 19:15:04][DEBUG] : Oui
[2022-10-18 19:15:04][DEBUG] : Fin de la fonction majConnected()
[2022-10-18 19:15:04][DEBUG] : MAJ du programme actif
[2022-10-18 19:15:06][DEBUG] : Nombre de requêtes envoyées aujourd'hui 102
homeconnectd
PHP Notice: Accessing static property homeconnect_capabilities::$appliancesList as non static in /var/www/html/plugins/homeconnect/core/class/homeconnect.capabilities.php on line 26
PHP Notice: Accessing static property homeconnect_capabilities::$appliancesCapabilities as non static in /var/www/html/plugins/homeconnect/core/class/homeconnect.capabilities.php on line 50
PHP Notice: Accessing static property homeconnect_capabilities::$appliancesCapabilities as non static in /var/www/html/plugins/homeconnect/core/class/homeconnect.class.php on line 50
[2022-10-18 18:26:06]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:26:06]INFO : Événements capturés : Array ( )
[2022-10-18 18:26:07]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:26:07]INFO : Événements capturés : Array ( )
[2022-10-18 18:27:02]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:27:02]INFO : Événements capturés : Array ( )
[2022-10-18 18:27:57]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:27:57]INFO : Événements capturés : Array ( )
[2022-10-18 18:28:52]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:28:52]INFO : Événements capturés : Array ( )
[2022-10-18 18:29:47]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:29:47]INFO : Événements capturés : Array ( )
[2022-10-18 18:30:42]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:30:42]INFO : Événements capturés : Array ( )
[2022-10-18 18:31:06]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:31:06]INFO : Événements capturés : Array ( )
[2022-10-18 18:31:37]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:31:37]INFO : Événements capturés : Array ( )
[2022-10-18 18:32:32]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:32:32]INFO : Événements capturés : Array ( )
[2022-10-18 18:33:27]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:33:27]INFO : Événements capturés : Array ( )
[2022-10-18 18:34:22]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:34:22]INFO : Événements capturés : Array ( )
[2022-10-18 18:35:17]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:35:17]INFO : Événements capturés : Array ( )
[2022-10-18 18:36:06]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:36:06]INFO : Événements capturés : Array ( )
[2022-10-18 18:36:12]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:36:12]INFO : Événements capturés : Array ( )
[2022-10-18 18:37:07]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:37:07]INFO : Événements capturés : Array ( )
[2022-10-18 18:38:02]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:38:02]INFO : Événements capturés : Array ( )
[2022-10-18 18:38:57]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:38:57]INFO : Événements capturés : Array ( )
[2022-10-18 18:39:52]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:39:52]INFO : Événements capturés : Array ( )
[2022-10-18 18:40:47]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:40:47]INFO : Événements capturés : Array ( )
[2022-10-18 18:41:06]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:41:06]INFO : Événements capturés : Array ( )
[2022-10-18 18:41:42]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:41:42]INFO : Événements capturés : Array ( )
[2022-10-18 18:42:37]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:42:37]INFO : Événements capturés : Array ( )
[2022-10-18 18:43:32]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:43:32]INFO : Événements capturés : Array ( )
[2022-10-18 18:44:27]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:44:27]INFO : Événements capturés : Array ( )
[2022-10-18 18:45:22]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:45:22]INFO : Événements capturés : Array ( )
[2022-10-18 18:46:06]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:46:06]INFO : Événements capturés : Array ( )
[2022-10-18 18:46:17]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:46:17]INFO : Événements capturés : Array ( )
[2022-10-18 18:47:12]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:47:12]INFO : Événements capturés : Array ( )
[2022-10-18 18:48:07]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:48:07]INFO : Événements capturés : Array ( )
[2022-10-18 18:49:02]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:49:02]INFO : Événements capturés : Array ( )
[2022-10-18 18:49:57]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:49:57]INFO : Événements capturés : Array ( )
[2022-10-18 18:50:52]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:50:52]INFO : Événements capturés : Array ( )
[2022-10-18 18:51:06]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:51:06]INFO : Événements capturés : Array ( )
[2022-10-18 18:51:47]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:51:47]INFO : Événements capturés : Array ( )
[2022-10-18 18:52:42]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:52:42]INFO : Événements capturés : Array ( )
[2022-10-18 18:53:37]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:53:37]INFO : Événements capturés : Array ( )
[2022-10-18 18:54:32]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:54:32]INFO : Événements capturés : Array ( )
[2022-10-18 18:55:27]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:55:27]INFO : Événements capturés : Array ( )
[2022-10-18 18:56:06]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:56:06]INFO : Événements capturés : Array ( )
[2022-10-18 18:56:22]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:56:22]INFO : Événements capturés : Array ( )
[2022-10-18 18:57:17]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:57:17]INFO : Événements capturés : Array ( )
[2022-10-18 18:58:12]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:58:12]INFO : Événements capturés : Array ( )
[2022-10-18 18:59:07]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 18:59:07]INFO : Événements capturés : Array ( )
[2022-10-18 19:00:02]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 19:00:02]INFO : Événements capturés : Array ( )
[2022-10-18 19:00:57]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 19:00:57]INFO : Événements capturés : Array ( )
[2022-10-18 19:01:06]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 19:01:06]INFO : Événements capturés : Array ( )
[2022-10-18 19:01:52]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 19:01:52]INFO : Événements capturés : Array ( )
[2022-10-18 19:02:47]INFO : Événement brut : event:KEEP-ALIVE data:
[2022-10-18 19:02:47]INFO : Événements capturés : Array ( )
merci Bull
