Je viens d’effectuer l’upgrade vers 4.0.45 et j’ai les messages suivants dans le fichier log cron_execution provenant du plugin jeelog
Je pense qu’il y a un problème.
Je suis sous Strech et Jeedom 4.0.45.
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 115
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 130
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 131
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 149
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 263
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 273
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 158
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 334
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 177
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 233
PHP Deprecated: Non-static method jeelog::logger() should not be called statically in /var/www/html/plugins/jeelog/core/class/jeelog.class.php on line 237
