I found a tricky bug :
On the dashboard, if I wait few minutes, the humidity (and temperature sometime) is not updated properly in the top left corner (drop list with objects).
You can have a better understanding on that video (can’t upload mp4 … so it has been converted to a gif ^^') :
After a refresh (F5), the right value is loaded back.
It seems to be an issue with the JS part I suppose ?
Hi. Does temperature summary update correctly ?
These comes from same function. Does it update on your equipment when showing it on dashboard ? Which sort of equipment is it ?
Oh cool, I had a hard time to find a « reproductible » scenario !
The first time it occurred I saw the outside temperature going from -14° to +23° …
I was like : "Well … i suppose the world is ending now " … but then I pressed F5 and everything was fine
