Box Luna impossible de faire fonctionner Jeezigbee depuis 2 jours
Je suis sur la box Luna en v4.4.19.
Version plugin :
  • JeeZigbee : 2025-01-07 16:45:29
  • MQTT Manager : 2024-11-26 01:20:08
Depuis 2 jours, mon plugin JeeZigbee ne fonctionne plus (impossible de démarrer le démon).
J’ai relancer les dépendances de JeeZigbee et MQTT Manager, en vain…
Voici ce qui apparaît dans la log Z2md lorsque j’essaye de démarrer :
Starting Zigbee2MQTT without watchdog.
[2025-01-16 15:15:24] e[31merrore[39m: 	zh:ezsp:driv: Configuration is not consistent with adapter backup!
[2025-01-16 15:15:24] e[31merrore[39m: 	zh:ezsp:driv: - PAN ID: configured=6754, adapter=22318, backup=22318
[2025-01-16 15:15:24] e[31merrore[39m: 	zh:ezsp:driv: - Extended PAN ID: configured=dddddddddddddddd, adapter=f2e90ac5fde19b94, backup=f2e90ac5fde19b94
[2025-01-16 15:15:24] e[31merrore[39m: 	zh:ezsp:driv: - Channel: configured=11, adapter=11, backup=11
[2025-01-16 15:15:24] e[31merrore[39m: 	zh:ezsp:driv: - Network key: configured=01030507090b0d0f00020406080a0c0d, adapter=5a473e4de54bf6f574ac12b0a69de160, backup=5a473e4de54bf6f574ac12b0a69de160
[2025-01-16 15:15:24] e[31merrore[39m: 	zh:ezsp:driv: Please update configuration to prevent further issues.
[2025-01-16 15:15:24] e[31merrore[39m: 	zh:ezsp:driv: If you wish to re-commission your network, please remove coordinator backup.
[2025-01-16 15:15:24] e[31merrore[39m: 	zh:ezsp:driv: Re-commissioning your network will require re-pairing of all devices!
[2025-01-16 15:15:24] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2025-01-16 15:15:24] e[31merrore[39m: 	z2m: Failed to start zigbee-herdsman
[2025-01-16 15:15:24] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-01-16 15:15:24] e[31merrore[39m: 	z2m: Exiting...
[2025-01-16 15:15:24] e[31merrore[39m: 	z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
at Driver.needsToBeRestore (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:984:19)
at Driver.startup (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:244:29)
at EZSPAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:145:16)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@3.2.1/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:69:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:142:13)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:161:5)
Voici ma configuration de JeeZigbee :
Merci pour votre aide !!
As tu fais une recherche ici?
https://community.jeedom.com/tag/plugin-z2m
Capture d’écran du 2025-01-16 16-40-32
Je suis en train de repasser en v1.42.0 je vais voir le comportement
ça ne fonctionne toujours pas, voilà le message que j’ai dans la log Z2md :
> zigbee2mqtt@1.42.0 start
> node index.js
[2025-01-17 08:56:52] e[31merrore[39m: 	zh:ezsp:driv: Configuration is not consistent with adapter backup!
[2025-01-17 08:56:52] e[31merrore[39m: 	zh:ezsp:driv: - PAN ID: configured=6754, adapter=22318, backup=22318
[2025-01-17 08:56:52] e[31merrore[39m: 	zh:ezsp:driv: - Extended PAN ID: configured=dddddddddddddddd, adapter=f2e90ac5fde19b94, backup=f2e90ac5fde19b94
[2025-01-17 08:56:52] e[31merrore[39m: 	zh:ezsp:driv: - Channel: configured=11, adapter=11, backup=11
[2025-01-17 08:56:52] e[31merrore[39m: 	zh:ezsp:driv: - Network key: configured=01030507090b0d0f00020406080a0c0d, adapter=5a473e4de54bf6f574ac12b0a69de160, backup=5a473e4de54bf6f574ac12b0a69de160
[2025-01-17 08:56:52] e[31merrore[39m: 	zh:ezsp:driv: Please update configuration to prevent further issues.
[2025-01-17 08:56:52] e[31merrore[39m: 	zh:ezsp:driv: If you wish to re-commission your network, please remove coordinator backup.
[2025-01-17 08:56:52] e[31merrore[39m: 	zh:ezsp:driv: Re-commissioning your network will require re-pairing of all devices!
[2025-01-17 08:56:52] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2025-01-17 08:56:52] e[31merrore[39m: 	z2m: Failed to start zigbee
[2025-01-17 08:56:52] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2025-01-17 08:56:52] e[31merrore[39m: 	z2m: Exiting...
[2025-01-17 08:56:53] e[31merrore[39m: 	z2m: Error: startup failed - configuration-adapter mismatch - see logs above for more information
at Driver.needsToBeRestore (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:985:19)
at Driver.startup (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:244:29)
at EZSPAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:152:16)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:161:27)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:154:5)
Pas de solution ?
J’ai le même problème …
Même problème ? En es -tu bien sûr ?!
Sans créer ton propre sujet et en donnant page santé et log, tu risques de ne pas avoir de réponse
Bonjour @jdelcourt
En 2 ans il s’est passé beaucoup de choses au niveau des versions de jeedom, de debian, de zigbee2mqtt.
Ouvre ton propre sujet et on va voir si oui ou non le problème est le même : en l’état les symptômes sont peut être les mêmes mais la cause source pas sur :slight_smile:
