BlueSwim : Pas de remontée de conductivité
j’utilise depuis le début le plugin BlueSwim (d’ailleurs, un grand merci au dev :slight_smile: )
La mesure de la conductivité ne remonte pas. Je viens de tenter de supprimer le plugin et de le remettre en place.
Dans les logs, je ne vois pas de trace de conductivité dans les data remontés. Est-ce normal ?
Est-ce une mesure calculée ?
Dernière trace :
[2021-10-19 09:30:05][DEBUG] : updateInfo:{"status":"OK","last_blue_measure_timestamp":"2021-10-18T15:24:00.000Z","blue_device_serial":"003935CF","swimming_pool_id":"1921c281-768b-47d7-a910-788308f3d72a","data":[{"name":"temperature","priority":10,"timestamp":"2021-10-18T15:24:00.000Z","expired":true,"value":19,"trend":"increase","ok_min":18,"ok_max":29,"warning_high":50,"warning_low":5,"gauge_max":50,"gauge_min":0,"issuer":"gateway"},{"name":"ph","priority":20,"timestamp":"2021-10-18T15:24:00.000Z","expired":true,"value":7.3,"trend":"stable","ok_min":7,"ok_max":7.4,"warning_high":8.4,"warning_low":6.6,"gauge_max":10,"gauge_min":5,"issuer":"gateway"},{"name":"orp","priority":30,"timestamp":"2021-10-18T15:24:00.000Z","expired":true,"value":753,"trend":"stable","ok_min":690,"ok_max":750,"warning_high":900,"warning_low":400,"gauge_max":1000,"gauge_min":300,"issuer":"gateway"},{"name":"salinity","priority":50,"timestamp":"2021-10-18T15:24:00.000Z","expired":true,"value":4.2,"trend":"decrease","ok_min":4,"ok_max":6,"warning_high":9,"warning_low":2,"gauge_max":10,"gauge_min":0,"issuer":"gateway"}]}
[2021-10-19 09:30:05][INFO] : temperature: 19 en date du 2021-10-18T15:24:00.000Z
[2021-10-19 09:30:05][INFO] : orp: 753 en date du 2021-10-18T15:24:00.000Z
[2021-10-19 09:30:05][INFO] : ph: 7.3 en date du 2021-10-18T15:24:00.000Z
[2021-10-19 09:30:05][INFO] : salinity: 4.2 en date du 2021-10-18T15:24:00.000Z
bonjour,
Merci de modifier votre message en utilisant le code </> pour encadrer vos codes ou logs.
tutoriel cliquez ici
Ou vous pouvez envoyer un message privé à @sheldon-bot démarrer tutoriel avancé pour apprendre à utiliser les menus :wink:
Corrigé.
Pardon :slight_smile:
Ma version du plugin :
Personne pour aider ?
@Kitof ?
Petite relance :slight_smile:
Merci !
Tu es au sel ?
C’est donc normal, tu ne peux pas avoir la salinité ET la conductivité. Elle ne sert que pour calculer la salinité suivant un abaque assez complexe.
https://community.jeedom.com/t/blueconnect-sonde-piscine/5054/386
Avec un léger retard (vu que la piscine était en hivernage, j’ai zappé le sujet) … Merci pour le retour.
Oui effectivement je suis au sel. Et j’avais bien compris que la remontée de la conductivité ne remontait pas du coup.
Mais j’avais aussi compris que du coup, la mesure ne remontant pas, elle était calculée pour avoir une « estimation ». C’est pourquoi je me demandais si cela était normal de n’avoir aucune valeur (calculée ou pas).
Je crois que c’est l’inverse qu’il faut comprendre. La conductivité est mesurée par la sonde, mais comme elle ne parle à personne et qu’elle est dépendante (température, chlore), ils ont décidé de faire une estimation de la salinité en gramme qui correspond à ce qu’annonce les docs techniques de nos électrolyseur.
Moi aussi je leur avait posé la question, pour le fun je voulais avoir ma conductivité :slight_smile:
reprise de la saison = Mise à jour du plugin en version Beta
  • Ajout de l’état de la batterie (attention,les valeurs semblent erratiques, à prendre avec précaution)
  • Affichage de l’état du blue (sleep/awake)
Si je n’ai pas de retour négatifs dans les prochains jours, je passerai la version en stable.
