J’utilise le plugin zigbeelinker, mais je pense que mon pb est sur zigbee2mqtt.
Il m’est impossible de binder et unbinder des matériels.
Ca à fonctionner sur quelques lampes et sans que je ne sache trop pourquoi, plus rien ne marche, avec des message d’erreur TIMEOUT
Logs z2m
Error 2024-01-23 21:56:49Failed to bind cluster 'genOnOff' from '0xdc8e95fffe2e1139' to 'Lampe boule' (Error: Bind 0xdc8e95fffe2e1139/1 genOnOff from '0x7cb03eaa0a09e326/3' failed (waiting for response TIMEOUT))
Error 2024-01-23 21:58:24Failed to bind cluster 'genLevelCtrl' from 'Télécommande' to 'Bandeau LED' (Error: Bind 0xa4c1381a38609da1/1 genLevelCtrl from '0x9035eafffec38ea7/1' failed (waiting for response TIMEOUT))
Error 2024-01-23 21:58:24Failed to unbind cluster 'genOnOff' from '0xdc8e95fffe2e1139' to 'Coordinator' (Error: Unbind 0xdc8e95fffe2e1139/1 genOnOff from '0x00212effff060dcc/1' failed (Error: status: 136))
Error 2024-01-23 21:59:25Failed to bind cluster 'genOnOff' from 'Télécommande' to 'Bandeau LED' (Error: Bind 0xa4c1381a38609da1/1 genOnOff from '0x9035eafffec38ea7/1' failed (waiting for response TIMEOUT))
Error 2024-01-23 21:59:34Failed to bind cluster 'genOnOff' from '0xdc8e95fffe2e1139' to 'Lampe boule' (Error: Bind 0xdc8e95fffe2e1139/1 genOnOff from '0x7cb03eaa0a09e326/3' failed (waiting for response TIMEOUT))
Error 2024-01-23 22:00:01Failed to bind cluster 'genLevelCtrl' from 'Télécommande' to 'Bandeau LED' (Error: Bind 0xa4c1381a38609da1/1 genLevelCtrl from '0x9035eafffec38ea7/1' failed (waiting for response TIMEOUT))
Error 2024-01-23 22:00:25Failed to bind cluster 'lightingColorCtrl' from 'Télécommande' to 'Bandeau LED' (Error: Bind 0xa4c1381a38609da1/1 lightingColorCtrl from '0x9035eafffec38ea7/1' failed (waiting for response TIMEOUT))
tous mes equipememnts fonctionnent bien malgré celà
une idée ?
je suis en dernier version de z2m en docker, clé conbee2
