Pour info, hier ça a fonctionné,
Voila ce que j’ai ce matin :
[2023-12-07 11:16:31]DEBUG : #####---------------------------------------------------------#####
[2023-12-07 11:16:51]DEBUG : #####---------------------------------------------------------#####
[2023-12-07 11:16:51]INFO : [template] Affichage du template pour Prévision Solaire [START]
[2023-12-07 11:16:51]DEBUG : [template] Heures ajustées : 9 17
[2023-12-07 11:16:51]DEBUG : [template] json_array_pv_reliability : [{"7":{"ecart":0,"percent":100},"8":{"ecart":0,"percent":100},"9":{"ecart":57,"percent":67},"10":{"ecart":105,"percent":100},"11":{"ecart":57,"percent":100},"12":{"ecart":720,"percent":50},"13":{"ecart":484,"percent":43},"14":{"ecart":769,"percent":40},"15":{"ecart":950,"percent":40},"16":{"ecart":621,"percent":32},"17":{"ecart":20,"percent":20},"18":{"ecart":0,"percent":100},"19":{"ecart":0,"percent":100},"20":{"ecart":0,"percent":100},"21":{"ecart":0,"percent":100}}]
[2023-12-07 11:16:51]DEBUG : [template] Fiabilité de la prévision à J+0 : 44%
[2023-12-07 11:16:51]DEBUG : [template] Indice de fiabilité de la prévision à J+0 : 1/4
[2023-12-07 11:16:51]DEBUG : [template] d0_percent_number_prod_forecast : 0
[2023-12-07 11:16:51]DEBUG : [template] Fiabilité de la prévision à J+1 : 47%
[2023-12-07 11:16:51]DEBUG : [template] json_array_prod_watt_hours : {"lastvalue":0,"00":0,"01":0,"02":0,"03":0,"04":0,"05":0,"06":0,"07":0,"08":0,"09":0,"10":0,"11":0}
[2023-12-07 11:16:51]DEBUG : [template] json_array_forecast_6h : {"7":0,"8":0,"9":65,"10":323,"11":574,"12":816,"13":888,"14":850,"15":613,"16":309,"17":9,"18":0,"19":0,"20":0,"21":0}
[2023-12-07 11:16:51]DEBUG : [template] dataForecast : 0, 307, 920, 1272, 848, 480, 545, 569, 269, 9
[2023-12-07 11:16:51]DEBUG : [template] dataForecast6h : 0, 65, 323, 574, 816, 888, 850, 613, 309, 9
[2023-12-07 11:16:51]DEBUG : [template] json_array_watt_month : {"prev":{"05":"","06":3264},"prev6h":{"05":null,"06":1954},"prod":{"05":"","06":263}}
[2023-12-07 11:16:51]DEBUG : [template] json_array_watt_year : {"prev":{"12":3264},"prev6h":{"12":1954},"prod":{"12":263}}
[2023-12-07 11:16:51]INFO : [template] Affichage du template pour Prévision Solaire [END]
[2023-12-07 11:16:54]DEBUG : #####---------------------------------------------------------#####
[2023-12-07 11:16:54]INFO : [template] Affichage du template pour Prévision Solaire [START]
[2023-12-07 11:16:54]DEBUG : [template] Heures ajustées : 9 17
[2023-12-07 11:16:54]DEBUG : [template] json_array_pv_reliability : [{"7":{"ecart":0,"percent":100},"8":{"ecart":0,"percent":100},"9":{"ecart":57,"percent":67},"10":{"ecart":105,"percent":100},"11":{"ecart":57,"percent":100},"12":{"ecart":720,"percent":50},"13":{"ecart":484,"percent":43},"14":{"ecart":769,"percent":40},"15":{"ecart":950,"percent":40},"16":{"ecart":621,"percent":32},"17":{"ecart":20,"percent":20},"18":{"ecart":0,"percent":100},"19":{"ecart":0,"percent":100},"20":{"ecart":0,"percent":100},"21":{"ecart":0,"percent":100}}]
[2023-12-07 11:16:54]DEBUG : [template] Fiabilité de la prévision à J+0 : 44%
[2023-12-07 11:16:54]DEBUG : [template] Indice de fiabilité de la prévision à J+0 : 1/4
[2023-12-07 11:16:54]DEBUG : [template] d0_percent_number_prod_forecast : 0
[2023-12-07 11:16:54]DEBUG : [template] Fiabilité de la prévision à J+1 : 47%
[2023-12-07 11:16:54]DEBUG : [template] json_array_prod_watt_hours : {"lastvalue":0,"00":0,"01":0,"02":0,"03":0,"04":0,"05":0,"06":0,"07":0,"08":0,"09":0,"10":0,"11":0}
[2023-12-07 11:16:54]DEBUG : [template] json_array_forecast_6h : {"7":0,"8":0,"9":65,"10":323,"11":574,"12":816,"13":888,"14":850,"15":613,"16":309,"17":9,"18":0,"19":0,"20":0,"21":0}
[2023-12-07 11:16:54]DEBUG : [template] dataForecast : 0, 307, 920, 1272, 848, 480, 545, 569, 269, 9
[2023-12-07 11:16:54]DEBUG : [template] dataForecast6h : 0, 65, 323, 574, 816, 888, 850, 613, 309, 9
[2023-12-07 11:16:54]DEBUG : [template] json_array_watt_month : {"prev":{"05":"","06":3264},"prev6h":{"05":null,"06":1954},"prod":{"05":"","06":263}}
[2023-12-07 11:16:54]DEBUG : [template] json_array_watt_year : {"prev":{"12":3264},"prev6h":{"12":1954},"prod":{"12":263}}
[2023-12-07 11:16:54]INFO : [template] Affichage du template pour Prévision Solaire [END]
[2023-12-07 11:17:56]DEBUG : --- Création ou mise à jour des commandes pour Prévision Solaire---
[2023-12-07 11:20:04]DEBUG : --- Création ou mise à jour des commandes pour Prévision Solaire---
[2023-12-07 11:20:44]DEBUG : #####---------------------------------------------------------#####
[2023-12-07 11:20:44]INFO : [template] Affichage du template pour Prévision Solaire [START]
[2023-12-07 11:20:44]DEBUG : [template] Heures ajustées : 9 17
[2023-12-07 11:20:44]DEBUG : [template] json_array_pv_reliability : [{"7":{"ecart":0,"percent":100},"8":{"ecart":0,"percent":100},"9":{"ecart":57,"percent":67},"10":{"ecart":105,"percent":100},"11":{"ecart":57,"percent":100},"12":{"ecart":720,"percent":50},"13":{"ecart":484,"percent":43},"14":{"ecart":769,"percent":40},"15":{"ecart":950,"percent":40},"16":{"ecart":621,"percent":32},"17":{"ecart":20,"percent":20},"18":{"ecart":0,"percent":100},"19":{"ecart":0,"percent":100},"20":{"ecart":0,"percent":100},"21":{"ecart":0,"percent":100}}]
[2023-12-07 11:20:44]DEBUG : [template] Fiabilité de la prévision à J+0 : 44%
[2023-12-07 11:20:44]DEBUG : [template] Indice de fiabilité de la prévision à J+0 : 1/4
[2023-12-07 11:20:44]DEBUG : [template] d0_percent_number_prod_forecast : 0
[2023-12-07 11:20:44]DEBUG : [template] Fiabilité de la prévision à J+1 : 47%
[2023-12-07 11:20:44]DEBUG : [template] json_array_prod_watt_hours : {"lastvalue":0,"00":0,"01":0,"02":0,"03":0,"04":0,"05":0,"06":0,"07":0,"08":0,"09":0,"10":0,"11":0}
[2023-12-07 11:20:44]DEBUG : [template] json_array_forecast_6h : {"7":0,"8":0,"9":65,"10":323,"11":574,"12":816,"13":888,"14":850,"15":613,"16":309,"17":9,"18":0,"19":0,"20":0,"21":0}
[2023-12-07 11:20:44]DEBUG : [template] dataForecast : 0, 307, 920, 1272, 848, 480, 545, 569, 269, 9
[2023-12-07 11:20:44]DEBUG : [template] dataForecast6h : 0, 65, 323, 574, 816, 888, 850, 613, 309, 9
[2023-12-07 11:20:44]DEBUG : [template] json_array_watt_month : {"prev":{"05":"","06":3264},"prev6h":{"05":null,"06":1954},"prod":{"05":"","06":263}}
[2023-12-07 11:20:44]DEBUG : [template] json_array_watt_year : {"prev":{"12":3264},"prev6h":{"12":1954},"prod":{"12":263}}
[2023-12-07 11:20:44]INFO : [template] Affichage du template pour Prévision Solaire [END]
