Fais-le, ça devrait régler le problème.
J’ai documenté l’installation à réaliser.
Bonjour @Flobul ,
Idem @DuplO le 9 mars sur RPI3 ou PI Zero
En version stable ou Beta même résultat
10 Vérification du système
ARCH=armv7l; BITS=32; USER=root; PWD=/home/pi; SCRIPT_VERSION=0.18
30 Suppression ancienne installation
rm: cannot remove '/usr/local/bin/hdsentinel': Is a directory
50 Récupération URL
70 URL récupérée=https://www.hdsentinel.com/hdslin/hdsentinel-armv7.gz; uncompress=gzip; extension=gz
80 Téléchargement et installation
--2022-04-19 12:35:59-- https://www.hdsentinel.com/hdslin/hdsentinel-armv7.gz
Resolving www.hdsentinel.com (www.hdsentinel.com)... 79.172.252.60
Connecting to www.hdsentinel.com (www.hdsentinel.com)|79.172.252.60|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1433042 (1.4M) [application/x-gzip]
Saving to: ‘/home/pi/hdsentinel.gz’
0K .......... .......... .......... .......... .......... 3% 228K 6s
50K .......... .......... .......... .......... .......... 7% 1.12M 3s
100K .......... .......... .......... .......... .......... 10% 500K 3s
150K .......... .......... .......... .......... .......... 14% 1.58M 2s
200K .......... .......... .......... .......... .......... 17% 362K 2s
250K .......... .......... .......... .......... .......... 21% 853K 2s
300K .......... .......... .......... .......... .......... 25% 1.90M 2s
350K .......... .......... .......... .......... .......... 28% 2.82M 2s
400K .......... .......... .......... .......... .......... 32% 78.3K 3s
450K .......... .......... .......... .......... .......... 35% 3.02M 2s
500K .......... .......... .......... .......... .......... 39% 350K 2s
550K .......... .......... .......... .......... .......... 42% 243K 2s
600K .......... .......... .......... .......... .......... 46% 795K 2s
650K .......... .......... .......... .......... .......... 50% 1.84M 2s
700K .......... .......... .......... .......... .......... 53% 876K 2s
750K .......... .......... .......... .......... .......... 57% 892K 1s
800K .......... .......... .......... .......... .......... 60% 782K 1s
850K .......... .......... .......... .......... .......... 64% 452K 1s
900K .......... .......... .......... .......... .......... 67% 1.11M 1s
950K .......... .......... .......... .......... .......... 71% 2.46M 1s
1000K .......... .......... .......... .......... .......... 75% 860K 1s
1050K .......... .......... .......... .......... .......... 78% 651K 1s
1100K .......... .......... .......... .......... .......... 82% 3.06M 0s
1150K .......... .......... .......... .......... .......... 85% 933K 0s
1200K .......... .......... .......... .......... .......... 89% 483K 0s
1250K .......... .......... .......... .......... .......... 92% 1.08M 0s
1300K .......... .......... .......... .......... .......... 96% 4.52M 0s
1350K .......... .......... .......... .......... ......... 100% 4.30M=2.5s
2022-04-19 12:36:02 (571 KB/s) - ‘/home/pi/hdsentinel.gz’ saved [1433042/1433042]
gzip: /home/pi/hdsentinel: Is a directory
mv: cannot move '/home/pi/hdsentinel' to '/usr/local/bin/hdsentinel/hdsentinel': Directory not empty
100 Installation en erreur
Passe également en installation manuelle, dans ce cas.
Ok dans ce cas je pense qu’il faut faire l’installation manuellement en ssh.
Je le ferai demain.
