AxiosError
Depuis qq temps le plugin mqqt2 rempli le log avec cette erreur déjà connu.
J’ai fait des recherches mais j’ai pas de trouvé de solution.
vm proxmox debain 12, uptodate
mqtt2 version 2025-05-17 01:20:31
Jeedom 4.4.20
axios 1.11.0
0017|[2025-09-11 18:22:46][ERROR] : Error on send to jeedom : {"message":"Request failed with status code 500","name":"AxiosError","stack":"AxiosError: Request failed with status code 500\n    at settle (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/axios/dist/node/axios.cjs:1913:12)\n    at IncomingMessage.handleStreamEnd (/var/www/html/plugins/mqtt2/resources/mqtt2d/node_modules/axios/dist/node/axios.cjs:2995:11)\n    at IncomingMessage.emit (node:events:536:35)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/x-www-form-urlencoded","User-Agent":"axios/1.5.1","Content-Length":"644","Accept-Encoding":"gzip, compress, deflate, br"},"httpAgent":{"_events":{},"_eventsCount":2,"defaultPort":80,"protocol":"http:","options":{"keepAlive":false,"noDelay":true,"path":null},"requests":{},"sockets":{"127.0.0.1:80:":[{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_closeAfterHandlingError":false,"_events":{"close":[null,null]},"_readableState":{"highWaterMark":16384,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null},"_writableState":{"highWaterMark":16384,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":1},"allowHalfOpen":false,"_eventsCount":7,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null,"parser":null,"_httpMessage":{"_events":{},"_eventsCount":7,"outputData":[],"outputSize":0,"writable":true,"destroyed":false,"_last":true,"chunkedEncoding":false,"shouldKeepAlive":false,"maxRequestsOnConnectionReached":false,"_defaultKeepAlive":true,"useChunkedEncodingByDefault":true,"sendDate":false,"_removedConnection":false,"_removedContLen":false,"_removedTE":false,"strictContentLength":false,"_contentLength":"644","_hasBody":true,"_trailer":"","finished":true,"_headerSent":true,"_closed":false,"_header":"POST /plugins/mqtt2/core/php/jeeMqtt2.php?apikey=6PNZSt2aquSdxYkLGpLhMjSXlsBTVpXCwgPtmWL9utZVtrS4mIwNW4rQSGa8E8nG HTTP/1.1\r\nAccept: application/json, text/plain, */*\r\nContent-Type: application/x-www-form-urlencoded\r\nUser-Agent: axios/1.5.1\r\nContent-Length: 644\r\nAccept-Encoding: gzip, compress, deflate, br\r\nHost: 127.0.0.1\r\nConnection: close\r\n\r\n","_keepAliveTimeout":0,"method":"POST","path":"/plugins/mqtt2/core/php/jeeMqtt2.php?apikey=6PNZSt2aquSdxYkLGpLhMjSXlsBTVpXCwgPtmWL9utZVtrS4mIwNW4rQSGa8E8nG","_ended":true,"res":{"_events":{"end":[null,null]},"_readableState":{"highWaterMark":16384,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null},"httpVersionMajor":1,"httpVersionMinor":0,"httpVersion":"1.0","complete":true,"rawHeaders":["Date","Thu, 11 Sep 2025 18:22:46 GMT","Server","Apache","X-Content-Type-Options","nosniff","X-Frame-Options","sameorigin","X-XSS-Protection","1; mode=block","Referrer-Policy","strict-origin-when-cross-origin","Permissions-Policy","accelerometer=(),battery=(),fullscreen=(self),geolocation=(),camera=(),ambient-light-sensor=(self),autoplay=(self)","Content-Security-Policy","default-src 'self' file: data: blob: filesystem:;script-src-attr 'self' 'unsafe-inline' 'unsafe-eval' *.google.com *.google.fr *.googleapis.com;script-src 'self' 'unsafe-inline' 'unsafe-eval' *.google.com *.google.fr;script-src-elem 'self' 'unsafe-inline' 'unsafe-eval' *.google.com *.google.fr;img-src 'self' * data:;style-src 'self' 'unsafe-inline';style-src-attr 'self' 'unsafe-inline';worker-src blob:;frame-src 'self' *.jeedom.com *.google.com *.google.fr *.googleapis.com data:;","Access-Control-Allow-Origin","*","Access-Control-Allow-Credentials","true","Access-Control-Allow-Headers","origin, x-requested-with, content-type","Access-Control-Allow-Methods","PUT, GET, POST, DELETE, OPTIONS","Content-Length","0","Connection","close","Content-Type","text/html; charset=UTF-8"],"rawTrailers":[],"aborted":false,"upgrade":false,"url":"","method":null,"statusCode":500,"statusMessage":"Internal Server Error","_consuming":false,"_dumped":false,"_eventsCount":4,"responseUrl":"http://127.0.0.1/plugins/mqtt2/core/php/jeeMqtt2.php?apikey=6PNZSt2aquSdxYkLGpLhMjSXlsBTVpXCwgPtmWL9utZVtrS4mIwNW4rQSGa8E8nG","redirects":[]},"aborted":false,"timeoutCb":null,"upgradeOrConnect":false,"parser":null,"maxHeadersCount":null,"reusedSocket":false,"host":"127.0.0.1","protocol":"http:","_redirectable":{"_events":{},"_writableState":{"highWaterMark":16384,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":0},"_options":{"maxRedirects":21,"maxBodyLength":null,"protocol":"http:","path":"/plugins/mqtt2/core/php/jeeMqtt2.php?apikey=6PNZSt2aquSdxYkLGpLhMjSXlsBTVpXCwgPtmWL9utZVtrS4mIwNW4rQSGa8E8nG","method":"POST","headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/x-www-form-urlencoded","User-Agent":"axios/1.5.1","Content-Length":"644","Accept-Encoding":"gzip, compress, deflate, br"},"agents":{},"beforeRedirects":{},"hostname":"127.0.0.1","port":"","nativeProtocols":{"http:":{"METHODS":["ACL","BIND","CHECKOUT","CONNECT","COPY","DELETE","GET","HEAD","LINK","LOCK","M-SEARCH","MERGE","MKACTIVITY","MKCALENDAR","MKCOL","MOVE","NOTIFY","OPTIONS","PATCH","POST","PROPFIND","PROPPATCH","PURGE","PUT","QUERY","REBIND","REPORT","SEARCH","SOURCE","SUBSCRIBE","TRACE","UNBIND","UNLINK","UNLOCK","UNSUBSCRIBE"],"STATUS_CODES":{"100":"Continue","101":"Switching Protocols","102":"Processing","103":"Early Hints","200":"OK","201":"Created","202":"Accepted","203":"Non-Authoritative Information","204":"No Content","205":"Reset Content","206":"Partial Content","207":"Multi-Status","208":"Already Reported","226":"IM Used","300":"Multiple Choices","301":"Moved Permanently","302":"Found","303":"See Other","304":"Not Modified","305":"Use Proxy","307":"Temporary Redirect","308":"Permanent Redirect","400":"Bad Request","401":"Unauthorized","402":"Payment Required","403":"Forbidden","404":"Not Found","405":"Method Not Allowed","406":"Not Acceptable","407":"Proxy Authentication Required","408":"Request Timeout","409":"Conflict","410":"Gone","411":"Length Required","412":"Precondition Failed","413":"Payload Too Large","414":"URI Too Long","415":"Unsupported Media Type","416":"Range Not Satisfiable","417":"Expectation Failed","418":"I'm a Teapot","421":"Misdirected Request","422":"Unprocessable Entity","423":"Locked","424":"Failed Dependency","425":"Too Early","426":"Upgrade Required","428":"Precondition Required","429":"Too Many Requests","431":"Request Header Fields Too Large","451":"Unavailable For Legal Reasons","500":"Internal Server Error","501":"Not Implemented","502":"Bad Gateway","503":"Service Unavailable","504":"Gateway Timeout","505":"HTTP Version Not Supported","506":"Variant Also Negotiates","507":"Insufficient Storage","508":"Loop Detected","509":"Bandwidth Limit Exceeded","510":"Not Extended","511":"Network Authentication Required"},"maxHeaderSize":16384,"globalAgent":{"_events":{},"_eventsCount":2,"defaultPort":80,"protocol":"http:","options":{"keepAlive":true,"scheduling":"lifo","timeout":5000,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":true,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0}},"https:":{"globalAgent":{"_events":{},"_eventsCount":2,"defaultPort":443,"protocol":"https:","options":{"keepAlive":true,"scheduling":"lifo","timeout":5000,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":true,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}}},"pathname":"/plugins/mqtt2/core/php/jeeMqtt2.php","search":"?apikey=6PNZSt2aquSdxYkLGpLhMjSXlsBTVpXCwgPtmWL9utZVtrS4mIwNW4rQSGa8E8nG"},"_ended":true,"_ending":true,"_redirectCount":0,"_redirects":[],"_requestBodyLength":644,"_requestBodyBuffers":[],"_eventsCount":3,"_currentUrl":"http://127.0.0.1/plugins/mqtt2/core/php/jeeMqtt2.php?apikey=6PNZSt2aquSdxYkLGpLhMjSXlsBTVpXCwgPtmWL9utZVtrS4mIwNW4rQSGa8E8nG"}}}]},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":1},"method":"post","url":"http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php?apikey=6PNZSt2aquSdxYkLGpLhMjSXlsBTVpXCwgPtmWL9utZVtrS4mIwNW4rQSGa8E8nG","data":"{\"netatmo\":{\"70:ee:50:2c:da:48\":{\"temperature\":25.8,\"temptrend\":\"stable\",\"mintemp\":24.9,\"mintemputc\":1757565554,\"maxtemp\":26.2,\"maxtemputc\":1757541891,\"pressure\":1030.2,\"pressureabs\":1027,\"pressuretrend\":\"stable\",\"humidity\":56,\"co2\":681,\"noise\":69,\"timeutc\":1757614393,\"id\":\"70:ee:50:2c:da:48\",\"name\":\"Home (Indoor)\",\"type\":\"NAMain\",\"online\":1,\"wifistatus\":46,\"favorite\":0},\"02:00:00:2c:e8:62\":{\"temperature\":16.9,\"temptrend\":\"down\",\"mintemp\":14.2,\"mintemputc\":1757562793,\"maxtemp\":21.5,\"maxtemputc\":1757597707,\"humidity\":81,\"timeutc\":1757614369,\"id\":\"02:00:00:2c:e8:62\",\"type\":\"NAModule1\",\"online\":1,\"home\":\"Home\",\"rfstatus\":49,\"battery\":78}}}"},"code":"ERR_BAD_RESPONSE","status":500}
Merci d’éditer votre post et de mettre le/les logs en Texte préformaté (Balise </>) :
Cela sera bien plus lisible ! :wink:
Bonjour.
J’ai volontairement modifié la mise en page du log en question. Il n’était que sur une seule ligne, en le plaçant comme je viens de la faire, ce log est plus lisible maintenant.
L’auteur d’origine l’avait bien formaté (mais illisible à cause du format même de ce log).
Pinaise ! pas facile à lire tout de même ! :sweat_smile:
Sinon en reformatté json c’est plus long mais plus lisible :
Voir les détails
0017|[
   "2025-09-11 18":"22":46
   "ERROR"
]:"Error on send to jeedom":{
   "config":{
      "transitional":{
      "adapter":[
         "xhr",
         "http"
         null
         null
      "timeout":0,
      "maxBodyLength":-1,
      "env":{
      "headers":{
      "httpAgent":{
         "_events":{
         "_eventsCount":2,
         "defaultPort":80,
         "protocol":"http:",
         "options":{
            "keepAlive":false,
            "noDelay":true,
            "path":null
         "requests":{
         "sockets":{
            "127.0.0.1:80:":[
                  "connecting":false,
                  "_hadError":false,
                  "_parent":null,
                  "_host":null,
                  "_events":{
                     "close":[
                        null,
                        null
                  "_readableState":{
                     "buffer":[
                     "bufferIndex":0,
                     "length":0,
                     "pipes":[
                  "_writableState":{
                     "length":0,
                     "corked":0,
                     "writelen":0,
                     "bufferedIndex":0,
                     "pendingcb":1
                  "_eventsCount":7,
                  "_sockname":null,
                  "server":null,
                  "_server":null,
                  "parser":null,
                  "_httpMessage":{
                     "_events":{
                     "_eventsCount":7,
                     "outputData":[
                     "outputSize":0,
                     "writable":true,
                     "destroyed":false,
                     "_last":true,
                     "sendDate":false,
                     "_removedTE":false,
                     "_hasBody":true,
                     "_trailer":"",
                     "finished":true,
                     "_headerSent":true,
                     "_closed":false,
                     "method":"POST",
                     "_ended":true,
                     "res":{
                        "_events":{
                           "end":[
                              null,
                              null
                        "_readableState":{
                           "buffer":[
                           "bufferIndex":0,
                           "length":0,
                           "pipes":[
                        "complete":true,
                        "rawHeaders":[
                           "Date",
                           "Server",
                           "Apache",
                           "nosniff",
                           "X-Frame-Options",
                           "sameorigin",
                           "X-XSS-Protection",
                           "1; mode=block",
                           "Referrer-Policy",
                           "true",
                           "Content-Length",
                           "0",
                           "Connection",
                           "close",
                           "Content-Type",
                        "rawTrailers":[
                        "aborted":false,
                        "upgrade":false,
                        "url":"",
                        "method":null,
                        "statusCode":500,
                        "_consuming":false,
                        "_dumped":false,
                        "_eventsCount":4,
                        "redirects":[
                     "aborted":false,
                     "timeoutCb":null,
                     "parser":null,
                     "host":"127.0.0.1",
                     "protocol":"http:",
                     "_redirectable":{
                        "_events":{
                        "_writableState":{
                           "length":0,
                           "corked":0,
                           "writelen":0,
                           "bufferedIndex":0,
                           "pendingcb":0
                        "_options":{
                           "maxRedirects":21,
                           "protocol":"http:",
                           "method":"POST",
                           "headers":{
                           "agents":{
                           "beforeRedirects":{
                           "port":"",
                           "nativeProtocols":{
                              "http:":{
                                 "METHODS":[
                                    "ACL",
                                    "BIND",
                                    "CHECKOUT",
                                    "CONNECT",
                                    "COPY",
                                    "DELETE",
                                    "GET",
                                    "HEAD",
                                    "LINK",
                                    "LOCK",
                                    "M-SEARCH",
                                    "MERGE",
                                    "MKACTIVITY",
                                    "MKCALENDAR",
                                    "MKCOL",
                                    "MOVE",
                                    "NOTIFY",
                                    "OPTIONS",
                                    "PATCH",
                                    "POST",
                                    "PROPFIND",
                                    "PROPPATCH",
                                    "PURGE",
                                    "PUT",
                                    "QUERY",
                                    "REBIND",
                                    "REPORT",
                                    "SEARCH",
                                    "SOURCE",
                                    "SUBSCRIBE",
                                    "TRACE",
                                    "UNBIND",
                                    "UNLINK",
                                    "UNLOCK",
                                    "UNSUBSCRIBE"
                                 "STATUS_CODES":{
                                    "100":"Continue",
                                    "102":"Processing",
                                    "200":"OK",
                                    "201":"Created",
                                    "202":"Accepted",
                                    "204":"No Content",
                                    "226":"IM Used",
                                    "302":"Found",
                                    "303":"See Other",
                                    "305":"Use Proxy",
                                    "403":"Forbidden",
                                    "404":"Not Found",
                                    "409":"Conflict",
                                    "410":"Gone",
                                    "423":"Locked",
                                    "425":"Too Early",
                                 "globalAgent":{
                                    "_events":{
                                    "_eventsCount":2,
                                    "defaultPort":80,
                                    "protocol":"http:",
                                    "options":{
                                       "keepAlive":true,
                                       "timeout":5000,
                                       "noDelay":true,
                                       "path":null
                                    "requests":{
                                    "sockets":{
                                    "freeSockets":{
                                    "keepAlive":true,
                                    "maxSockets":null,
                              "https:":{
                                 "globalAgent":{
                                    "_events":{
                                    "_eventsCount":2,
                                    "defaultPort":443,
                                    "options":{
                                       "keepAlive":true,
                                       "timeout":5000,
                                       "noDelay":true,
                                       "path":null
                                    "requests":{
                                    "sockets":{
                                    "freeSockets":{
                                    "keepAlive":true,
                                    "maxSockets":null,
                                    "_sessionCache":{
                                       "map":{
                                       "list":[
                        "_ended":true,
                        "_ending":true,
                        "_redirectCount":0,
                        "_redirects":[
                        "_eventsCount":3,
         "freeSockets":{
         "keepAlive":false,
         "maxSockets":null,
      "method":"post",
   "status":500
J’ai récemment passé quelques h sur un problème similaire.
L’origine était une exception dans la méthode appelée par le callback send_to_jeedom()
désolé le tag a sauté au depart j’avais coller 5 ligne de log, mais vue la taille fait une modif et le tag a sauté
Putain je suis pas fou, j avais bien fait attention.
Honnêtement il devrais aussi joindre le code source avec au cas ou… :wink:
Franchement c’est inutilisable et la seule ligne vraiment intéressante est a la fin d’un json de 400 lignes.
« data »: "{"netatmo":{"70:ee:50:2c:da:48":{"temperat
j’ai désactivé le plugin MQTTNetatmo et j’ai plus d"erreur, mais je sais pas pourquoi ca deconne.
