[13-12-2023 22:28:11][DEBUG] : MàJ Client a4:cc:b3:9f:13:bc(Téléphone Cyril) : {"anomalies":null,"ap_mac":"f4:92:bf:29:55:27","assoc_time":null,"authorized":true,"blocked":false,"bssid":null,"ccq":null,"channel":40,"channel_width":"80","dhcpend_time":null,"display_name":"Téléphone Cyril","essid":"PLOUCBOX","fingerprint":{"computed_dev_id":283,"dev_cat":1,"dev_family":4,"dev_id":283,"dev_vendor":1,"has_override":false,"os_class":3,"os_name":3},"first_seen":1701269199,"fixed_ap_enabled":false,"fixed_ip":"192.168.80.85","gw_mac":"74:ac:b9:3c:cc:cf","hostname":"Xiaomi-13T","id":"a4:cc:b3:9f:13:bc","idletime":null,"ip":"192.168.80.85","is_guest":false,"is_wired":false,"last_seen":1702502891,"latest_assoc_time":null,"local_dns_record_enabled":false,"mac":"a4:cc:b3:9f:13:bc","mimo":"MIMO_2","name":"Téléphone Cyril","network_id":"60b7bab74dfb450015a2bb95","network_name":null,"noise":null,"noted":true,"oui":"","powersave_enabled":null,"radio":"na","radio_name":"wifi1","radio_proto":"ac","rate_imbalance":null,"rssi":null,"rx_bytes":null,"rx_bytes-r":4,"rx_packets":null,"rx_rate":null,"signal":null,"site_id":"60b7bab04dfb450015a2bb84","status":"online","tx_bytes":null,"tx_bytes-r":0,"tx_mcs_index":null,"tx_packets":null,"tx_rate":null,"type":"WIRELESS","unifi_device":false,"uplink_mac":null,"uptime":6907,"use_fixedip":false,"user_id":"65674ecfe3ab14001747b5c8","usergroup_id":"","virtual_network_override_enabled":false,"wifi_experience_average":null,"wifi_experience_score":null,"wifi_tx_attempts":null,"wlanconf_id":"60b7bb514dfb450015a2bbae","satisfaction":null,"_last_seen_by_uap":null,"_last_seen_by_ugw":null,"_last_seen_by_usw":null,"_uptime_by_uap":null,"_uptime_by_ugw":null,"_uptime_by_usw":null,"hostname_source":null,"satisfaction_now":null,"satisfaction_real":null,"satisfaction_reason":null,"satisfaction_avg":null,"last_connection_network_name":null,"usage_bytes":null,"tx_mcs":null,"tx_retries":null,"bytes-r":null,"tx_retry_burst_count":null,"wired-tx_bytes":null,"wired-rx_bytes":null,"wired-tx_packets":null,"wired-rx_packets":null}
[13-12-2023 22:28:11][DEBUG] : MàJ Device f4:92:bf:29:55:27(Borne Bureau){"required_version":"3.4.21","port_table":[],"heightInMeters":2.4,"has_speaker":false,"license_state":"registered","lcm_brightness_override":false,"mesh_sta_vap_enabled":true,"type":"uap","board_rev":12,"setup_id":"f968daec-7fff-4b32-a6fb-925b9d8fa452","hw_caps":2048,"reboot_duration":30,"config_network":{"netmask":"255.255.255.0","ip":"192.168.80.201","dns1":"192.168.80.254","type":"static","dnssuffix":"rebreyend.lan","gateway":"192.168.80.254"},"syslog_key":"32f3a667756f165edd3dbcd940115f41083bc65301dffb6711a99395128f1c81","model":"U7MSH","outdoor_mode_override":"default","manufacturer_id":2,"ip":"192.168.80.201","fw2_caps":0,"support_wifi6e":false,"last_connection_network_name":"Default","led_override_color":"#0000ff","version":"6.5.62.14788","unsupported_reason":0,"scan_radio_table":[],"adoption_completed":true,"x_vwirekey":"463b6a59c2f1a3011f3f24897a35d8b5","anon_id":"a5a76243-73a7-463d-8a63-1e05d46e0b3d","supports_fingerprint_ml":false,"last_connection_network_id":"60b7bab74dfb450015a2bb95","country_code":0,"wlangroup_id_na":"60b7bab74dfb450015a2bb97","countrycode_table":[],"antenna_table":[{"wifi1_gain":4,"default":true,"name":"Standard (included)","id":4,"wifi0_gain":3},{"wifi1_gain":15,"name":"UMA-D","id":3,"wifi0_gain":10}],"wifi_caps":22986461,"site_id":"60b7bab04dfb450015a2bb84","name":"Borne Bureau","fw_caps":-1476461505,"_id":"60b7bec34dfb450015a2bbb4","internet":true,"wlangroup_id_ng":"60b7bab74dfb450015a2bb97","gateway_mac":"74:ac:b9:3c:cc:d0","atf_enabled":true,"radio_table":[{"antenna_gain":3,"builtin_antenna":false,"vwire_enabled":false,"tx_power":17,"channel":11,"max_txpower":20,"channel_optimization_enabled":true,"min_rssi_enabled":false,"builtin_ant_gain":0,"ht":20,"radio":"ng","nss":2,"tx_power_mode":"high","backup_channel":0,"name":"wifi0","min_txpower":4,"radio_caps":4116,"antenna_id":4,"radio_caps2":27,"current_antenna_gain":3},{"antenna_gain":4,"builtin_antenna":false,"has_dfs":true,"vwire_enabled":true,"hard_noise_floor_enabled":false,"tx_power":16,"channel":40,"max_txpower":20,"channel_optimization_enabled":true,"min_rssi_enabled":false,"is_11ac":true,"builtin_ant_gain":0,"ht":80,"radio":"na","nss":2,"tx_power_mode":"high","backup_channel":0,"name":"wifi1","min_txpower":4,"has_fccdfs":true,"radio_caps":50466836,"antenna_id":4,"radio_caps2":27,"current_antenna_gain":4}],"x_fingerprint":"8e:bd:ec:01:38:8f:a9:12:45:1c:4f:fe:c7:87:40:80:1c:db:5f:c3","connected_at":1702496005,"two_phase_adopt":false,"inform_ip":"192.168.80.252","cfgversion":"eb0c712dace09dd0","mac":"f4:92:bf:29:55:27","provisioned_at":1702485237,"inform_url":"http://192.168.80.252:8080/inform","ethernet_table":[{"num_port":1,"name":"eth0","mac":"f4:92:bf:29:55:27"}],"upgrade_duration":150,"unsupported":false,"sys_error_caps":0,"ble_caps":0,"dot1x_portctrl_enabled":false,"map_id":"60bf7c4f4dd35600165ef971","last_uplink":{"uplink_mac":"74:ac:b9:3c:cc:cf","port_idx":1,"type":"wire"},"led_override":"default","disconnected_at":1702495985,"architecture":"mips","x_aes_gcm":true,"has_fan":false,"lcm_idle_timeout_override":false,"has_eth1":false,"model_incompatible":false,"x_authkey":"c3353b5c53ffbf22dbfee209c17930bb","x_ssh_hostkey_fingerprint":"7d:31:37:39:23:8e:4b:3f:f0:2f:6b:ab:88:0f:8f:e7","model_in_eol":false,"vwire_table":[],"has_temperature":false,"switch_caps":{},"model_in_lts":false,"kernel_version":"4.4.153","serial":"F492BF295527","x":55.000002844703374,"y":189.64285982080375,"fixed_ap_available":true,"led_override_color_brightness":100,"adopted":true,"hash_id":"da631e05d46e0b3d","device_id":"60b7bec34dfb450015a2bbb4","uplink":{"full_duplex":true,"ip":"0.0.0.0","mac":"f4:92:bf:29:55:27","name":"eth0","netmask":"0.0.0.0","num_port":1,"rx_bytes":1729157,"rx_dropped":0,"rx_errors":0,"rx_multicast":0,"rx_packets":10074,"speed":1000,"tx_bytes":1430925,"tx_dropped":0,"tx_errors":0,"tx_packets":4972,"up":true,"max_speed":1000,"type":"wire","tx_bytes-r":215.1328273244782,"rx_bytes-r":215.0853889943074,"uplink_source":"lldp_uplink","uplink_mac":"74:ac:b9:3c:cc:cf","port_idx":1,"uplink_device_name":"Firewall"},"state":1,"start_disconnected_millis":1702495985566,"start_connected_millis":1702496005346,"last_seen":1702502891,"next_interval":21,"disconnection_reason":"MISSED_INFORM, last_seen '1702495921', considered_lost '1702495941', state: 1","credential_caps":0,"default":false,"discovered_via":"l2","adopt_ip":"192.168.80.201","adopt_url":"http://192.168.80.252:8080/inform","min_inform_interval_seconds":5,"upgradable":false,"adoptable_when_upgraded":false,"rollupgrade":false,"known_cfgversion":"eb0c712dace09dd0","uptime":6927,"_uptime":6927,"locating":false,"sys_stats":{"loadavg_1":"0.00","loadavg_15":"0.00","loadavg_5":"0.02","mem_buffer":0,"mem_total":128593920,"mem_used":54415360},"system-stats":{"cpu":"4.0","mem":"42.3","uptime":"6927"},"ssh_session_table":[],"lldp_table":[{"chassis_descr":"UBNT UniFi-Gateway-3 running on v4.4.57.5578372.230112.0823","chassis_id":"74:ac:b9:3c:cc:cf","is_wired":true,"local_port_idx":1,"local_port_name":"eth0","port_descr":"LAN","port_id":"eth1"},{"chassis_descr":"UAP-AC-Mesh, 6.5.62.14788","chassis_id":"f4:92:bf:29:56:c4","is_wired":true,"local_port_idx":1,"local_port_name":"eth0","port_descr":"eth0","port_id":"f4:92:bf:29:56:c4"},{"chassis_id":"00:00:00:00:00:00","is_wired":true,"local_port_idx":1,"local_port_name":"eth0","port_id":"d8:50:e6:40:3b:25"}],"displayable_version":"6.5.62","connection_network_id":"60b7bab74dfb450015a2bb95","connection_network_name":"Default","startup_timestamp":1702495965,"is_access_point":true,"safe_for_autoupgrade":true,"scanning":false,"spectrum_scanning":false,"meshv3_peer_mac":"","element_peer_mac":"","guest_kicks":0,"guest_token":"C2245DC8E3A04CBEF56A77F7BFC60458","satisfaction":100,"hide_ch_width":"none","isolated":false,"radio_table_stats":[{"name":"wifi0","channel":11,"radio":"ng","ast_txto":null,"ast_cst":null,"ast_be_xmit":412,"cu_total":12,"cu_self_rx":7,"cu_self_tx":0,"gain":3,"satisfaction":-1,"state":"RUN","extchannel":0,"tx_power":17,"tx_packets":0,"tx_retries":0,"num_sta":0,"guest-num_sta":0,"user-num_sta":0},{"name":"wifi1","channel":40,"radio":"na","ast_txto":null,"ast_cst":null,"ast_be_xmit":618,"cu_total":1,"cu_self_rx":0,"cu_self_tx":1,"gain":4,"satisfaction":100,"state":"RUN","extchannel":-1,"tx_power":19,"tx_packets":0,"tx_retries":0,"num_sta":1,"guest-num_sta":0,"user-num_sta":1}],"downlink_lldp_macs":["f4:92:bf:29:56:c4","00:00:00:00:00:00","74:ac:b9:3c:cc:cf"],"vap_table":[{"anomalies_bar_chart":{"high_disconnect_count":0,"high_dns_latency":0,"high_icmp_rtt":0,"high_tcp_latency":0,"high_tcp_packet_loss":0,"high_wifi_latency":0,"high_wifi_retries":0,"low_phy_rate":0,"no_dhcp_response":0,"poor_stream_eff":0,"sleepy_client":0,"sta_arp_timeout":0,"sta_dns_timeout":0,"sta_ip_timeout":0,"weak_signal":0},"anomalies_bar_chart_now":{"high_disconnect_count":0,"high_dns_latency":0,"high_icmp_rtt":0,"high_tcp_latency":0,"high_tcp_packet_loss":0,"high_wifi_latency":0,"high_wifi_retries":0,"low_phy_rate":0,"no_dhcp_response":0,"poor_stream_eff":0,"sleepy_client":0,"sta_arp_timeout":0,"sta_dns_timeout":0,"sta_ip_timeout":0,"weak_signal":0},"avg_client_signal":-41,"bssid":"fa:92:bf:2b:55:27","bw":80,"ccq":333,"channel":40,"dns_avg_latency":-1,"essid":"PLOUCBOX","extchannel":-1,"icmp_avg_rtt":-1,"id":"60b7bb514dfb450015a2bbae","mac_filter_rejections":0,"name":"ath3","num_satisfaction_sta":1,"num_sta":1,"radio":"na","radio_name":"wifi1","reasons_bar_chart":{"no_dhcp_response":0,"phy_rate":0,"signal":0,"sleepy_client":0,"sta_arp_timeout":0,"sta_disconnects":0,"sta_dns_latency":0,"sta_dns_timeout":0,"sta_icmp_rtt":0,"sta_ip_timeout":0,"stream_eff":0,"tcp_latency":0,"tcp_packet_loss":0,"wifi_latency":0,"wifi_retries":0},"reasons_bar_chart_now":{"no_dhcp_response":0,"phy_rate":0,"signal":0,"sleepy_client":0,"sta_arp_timeout":0,"sta_disconnects":0,"sta_dns_latency":0,"sta_dns_timeout":0,"sta_icmp_rtt":0,"sta_ip_timeout":0,"stream_eff":0,"tcp_latency":0,"tcp_packet_loss":0,"wifi_latency":0,"wifi_retries":0},"rx_bytes":61009,"rx_crypts":0,"rx_dropped":0,"rx_errors":0,"rx_frags":0,"rx_nwids":5,"rx_packets":271,"rx_tcp_stats":{"goodbytes":0,"lat_avg":-1,"lat_max":-1,"lat_min":-1,"lat_samples":0,"lat_sum":0,"retries":0,"stalls":0},"satisfaction":100,"sta_table":[{"mac":"a4:cc:b3:9f:13:bc"}],"state":"RUN","tx_bytes":249866,"tx_combined_retries":12,"tx_data_mpdu_bytes":102260,"tx_dropped":2,"tx_errors":3,"tx_packets":1177,"tx_power":19,"tx_retries":12,"tx_rts_retries":0,"tx_success":159,"tx_tcp_stats":{"goodbytes":0,"lat_avg":-1,"lat_max":-1,"lat_min":-1,"lat_samples":0,"lat_sum":0,"retries":0,"stalls":0},"tx_total":159,"up":true,"usage":"user","wifi_tx_attempts":171,"wifi_tx_dropped":0,"wifi_tx_latency_mov":{"avg":134,"max":134,"min":134,"total":134,"total_count":1},"t":"vap","wlanconf_id":"60b7bb514dfb450015a2bbae","is_guest":false,"is_wep":false,"ap_mac":"f4:92:bf:29:55:27","map_id":"60bf7c4f4dd35600165ef971","site_id":"60b7bab04dfb450015a2bb84"},{"anomalies_bar_chart":{"high_disconnect_count":0,"high_dns_latency":0,"high_icmp_rtt":0,"high_tcp_latency":0,"high_tcp_packet_loss":0,"high_wifi_latency":0,"high_wifi_retries":0,"low_phy_rate":0,"no_dhcp_response":0,"poor_stream_eff":0,"sleepy_client":0,"sta_arp_timeout":0,"sta_dns_timeout":0,"sta_ip_timeout":0,"weak_signal":0},"anomalies_bar_chart_now":{"high_disconnect_count":0,"high_dns_latency":0,"high_icmp_rtt":0,"high_tcp_latency":0,"high_tcp_packet_loss":0,"high_wifi_latency":0,"high_wifi_retries":0,"low_phy_rate":0,"no_dhcp_response":0,"poor_stream_eff":0,"sleepy_client":0,"sta_arp_timeout":0,"sta_dns_timeout":0,"sta_ip_timeout":0,"weak_signal":0},"avg_client_signal":0,"bssid":"f4:92:bf:2a:55:27","bw":20,"ccq":0,"channel":11,"dns_avg_latency":-1,"essid":"PLOUCBOX","icmp_avg_rtt":-1,"id":"60b7bb514dfb450015a2bbae","mac_filter_rejections":0,"name":"ath0","num_satisfaction_sta":0,"num_sta":0,"radio":"ng","radio_name":"wifi0","reasons_bar_chart":{"no_dhcp_response":0,"phy_rate":0,"signal":0,"sleepy_client":0,"sta_arp_timeout":0,"sta_disconnects":0,"sta_dns_latency":0,"sta_dns_timeout":0,"sta_icmp_rtt":0,"sta_ip_timeout":0,"stream_eff":0,"tcp_latency":0,"tcp_packet_loss":0,"wifi_latency":0,"wifi_retries":0},"reasons_bar_chart_now":{"no_dhcp_response":0,"phy_rate":0,"signal":0,"sleepy_client":0,"sta_arp_timeout":0,"sta_disconnects":0,"sta_dns_latency":0,"sta_dns_timeout":0,"sta_icmp_rtt":0,"sta_ip_timeout":0,"stream_eff":0,"tcp_latency":0,"tcp_packet_loss":0,"wifi_latency":0,"wifi_retries":0},"rx_bytes":0,"rx_crypts":0,"rx_dropped":0,"rx_errors":0,"rx_frags":0,"rx_nwids":0,"rx_packets":0,"rx_tcp_stats":{"goodbytes":0,"lat_avg":0,"lat_max":-1,"lat_min":-1,"lat_samples":0,"lat_sum":0,"retries":0,"stalls":0},"satisfaction":-1,"sta_table":[],"state":"RUN","tx_bytes":0,"tx_combined_retries":0,"tx_data_mpdu_bytes":0,"tx_dropped":2,"tx_errors":0,"tx_packets":0,"tx_power":17,"tx_retries":0,"tx_rts_retries":0,"tx_success":0,"tx_tcp_stats":{"goodbytes":0,"lat_avg":0,"lat_max":-1,"lat_min":-1,"lat_samples":0,"lat_sum":0,"retries":0,"stalls":0},"tx_total":0,"up":true,"usage":"user","wifi_tx_attempts":0,"wifi_tx_dropped":0,"t":"vap","wlanconf_id":"60b7bb514dfb450015a2bbae","is_guest":false,"is_wep":false,"ap_mac":"f4:92:bf:29:55:27","map_id":"60bf7c4f4dd35600165ef971","site_id":"60b7bab04dfb450015a2bb84"}],"downlink_table":[],"vwire_vap_table":[{"state":"RUN","radio":"na","radio_name":"wifi1","bssid":"02:92:bf:2b:55:27"}],"bytes-d":3623,"tx_bytes-d":3580,"rx_bytes-d":43,"bytes-r":172523.80952380953,"connect_request_ip":"192.168.80.201","connect_request_port":"40066","lcm_brightness":80,"stat":{"ap":{"site_id":"60b7bab04dfb450015a2bb84","o":"ap","oid":"f4:92:bf:29:55:27","ap":"f4:92:bf:29:55:27","time":1702484700000,"datetime":"2023-12-13T16:25:00Z","user-wifi1-rx_packets":35305,"user-wifi0-rx_packets":2295,"user-rx_packets":37600,"guest-rx_packets":0,"wifi0-rx_packets":2295,"wifi1-rx_packets":35305,"rx_packets":37600,"user-wifi1-rx_bytes":20351518,"user-wifi0-rx_bytes":372736,"user-rx_bytes":20724254,"guest-rx_bytes":0,"wifi0-rx_bytes":372736,"wifi1-rx_bytes":20351518,"rx_bytes":20724254,"user-wifi1-rx_errors":142,"user-wifi0-rx_errors":0,"user-rx_errors":142,"guest-rx_errors":0,"wifi0-rx_errors":0,"wifi1-rx_errors":142,"rx_errors":142,"user-wifi1-rx_dropped":142,"user-wifi0-rx_dropped":0,"user-rx_dropped":142,"guest-rx_dropped":0,"wifi0-rx_dropped":0,"wifi1-rx_dropped":142,"rx_dropped":142,"user-wifi1-rx_crypts":142,"user-wifi0-rx_crypts":0,"user-rx_crypts":142,"guest-rx_crypts":0,"wifi0-rx_crypts":0,"wifi1-rx_crypts":142,"rx_crypts":142,"user-wifi1-rx_frags":0,"user-wifi0-rx_frags":0,"user-rx_frags":0,"guest-rx_frags":0,"wifi0-rx_frags":0,"wifi1-rx_frags":0,"rx_frags":0,"user-wifi1-tx_packets":68683,"user-wifi0-tx_packets":25235,"user-tx_packets":93918,"guest-tx_packets":0,"wifi0-tx_packets":25235,"wifi1-tx_packets":68683,"tx_packets":93918,"user-wifi1-tx_bytes":53970563,"user-wifi0-tx_bytes":4555252,"user-tx_bytes":58525815,"guest-tx_bytes":0,"wifi0-tx_bytes":4555252,"wifi1-tx_bytes":53970563,"tx_bytes":58525815,"user-wifi1-tx_errors":1420,"user-wifi0-tx_errors":0,"user-tx_errors":1420,"guest-tx_errors":0,"wifi0-tx_errors":0,"wifi1-tx_errors":1420,"tx_errors":1420,"user-wifi1-tx_dropped":0,"user-wifi0-tx_dropped":0,"user-tx_dropped":0,"guest-tx_dropped":0,"wifi0-tx_dropped":0,"wifi1-tx_dropped":0,"tx_dropped":0,"user-wifi1-tx_retries":2792,"user-wifi0-tx_retries":1414,"user-tx_retries":4206,"guest-tx_retries":0,"wifi0-tx_retries":1414,"wifi1-tx_retries":2792,"tx_retries":4206,"user-wifi1-mac_filter_rejections":0,"user-wifi0-mac_filter_rejections":0,"user-mac_filter_rejections":0,"guest-mac_filter_rejections":0,"wifi0-mac_filter_rejections":0,"wifi1-mac_filter_rejections":0,"mac_filter_rejections":0,"user-wifi1-wifi_tx_attempts":33347,"user-wifi0-wifi_tx_attempts":2705,"user-wifi_tx_attempts":36052,"guest-wifi_tx_attempts":0,"wifi0-wifi_tx_attempts":2705,"wifi1-wifi_tx_attempts":33347,"wifi_tx_attempts":36052,"user-wifi1-wifi_tx_dropped":11,"user-wifi0-wifi_tx_dropped":17,"user-wifi_tx_dropped":28,"guest-wifi_tx_dropped":0,"wifi0-wifi_tx_dropped":17,"wifi1-wifi_tx_dropped":11,"wifi_tx_dropped":28,"na-wifi_tx_attempts":33347,"ng-wifi_tx_attempts":2705,"na-wifi_tx_dropped":11,"ng-wifi_tx_dropped":17,"na-tx_retries":2792,"ng-tx_retries":1414,"na-tx_packets":68683,"ng-tx_packets":25235,"na-tx_bytes":53970563,"ng-tx_bytes":4555252,"bytes":79250069,"duration":17922000,"user-wifi0-ath0-60b7bb514dfb450015a2bbae-rx_packets":2295,"user-wifi0-ath0-60b7bb514dfb450015a2bbae-rx_bytes":372736,"user-wifi0-ath0-60b7bb514dfb450015a2bbae-tx_packets":25235,"user-wifi0-ath0-60b7bb514dfb450015a2bbae-tx_bytes":4555252,"user-wifi0-ath0-60b7bb514dfb450015a2bbae-tx_retries":1414,"user-wifi0-ath0-60b7bb514dfb450015a2bbae-wifi_tx_attempts":2705,"ng-WIFI_4-rx_bytes":314065,"ng-WIFI_4-tx_bytes":210941,"client-tx_bytes":87899,"client-rx_bytes":128219,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-rx_packets":35305,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-rx_bytes":20351518,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-tx_packets":68683,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-tx_bytes":53970563,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-wifi_tx_attempts":33347,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-tx_retries":2792,"na-WIFI_5-rx_bytes":10530012,"na-WIFI_5-tx_bytes":38262994,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-rx_errors":142,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-rx_dropped":142,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-rx_crypts":142,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-tx_errors":1418,"num_wifi_roam_to_events":6,"user-wifi0-ath0-60b7bb514dfb450015a2bbae-wifi_tx_dropped":17,"user-wifi1-ath4-60b7bab74dfb450015a2bb8c-tx_errors":2,"user-wifi1-ath3-60b7bb514dfb450015a2bbae-wifi_tx_dropped":11}},"tx_bytes":58525815,"rx_bytes":20724254,"bytes":79250069,"vwireEnabled":true,"uplink_table":[],"num_sta":1,"user-num_sta":1,"user-wlan-num_sta":1,"guest-num_sta":0,"guest-wlan-num_sta":0,"x_has_ssh_hostkey":true}
