Aucun chrome cast trouvé sur google-cast
il y a rien d’écris dessus. je pense que j’ai du effacer ce qui avait dedans.
je refait un install complet avec restauration de jeedom au 01/01/20 et je supprime également le dossier googlecast dans html/plugins.
voici le résultat dans googlecast_update
merci pour ton aide se plugin à l’air super à voir sur le Fofo
Launch install of googlecast dependancies
-- Updating repo...
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Fetched 40.3 kB in 2s (15.4 kB/s)
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
python-dev is already the newest version (2.7.13-2).
python3 is already the newest version (3.5.3-1).
The following packages were automatically installed and are no longer required:
lxkeymap python-cairo python-gtk2 python-xklavier realpath
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
-- Installed version of Python :
Python 3.5.3
-- Installation of pip for python3 and necessary libraries
python3-dev is already the newest version (3.5.3-1).
-- Installation of TTS libraries
sox is already the newest version (14.4.1-5+deb9u2).
libttspico-utils is already the newest version (1.0+git20130326-5).
-- Installation of libav/ffmpeg libraries
libav-tools is already the newest version (7:3.2.14-1~deb9u1+rpt1).
libavcodec-extra is already the newest version (7:3.2.14-1~deb9u1+rpt1).
-- Upgrade setuptools with command pip3 if not up to date
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages
-- Installed version of pip :
pip 9.0.1 from /usr/lib/python3/dist-packages (python 3.5)
-- Installation of python library 'netifaces' with command pip3
Requirement already satisfied: netifaces in /usr/local/lib/python3.5/dist-packages
-- Installation of python library 'requests' with command pip3
Requirement already satisfied: requests in /usr/lib/python3/dist-packages
-- Installation of python library 'protobuf' with command pip3
Requirement already satisfied: protobuf in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: six>=1.9 in /usr/lib/python3/dist-packages (from protobuf)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from protobuf)
-- Installation of python library 'zeroconf' with command pip3
Requirement already satisfied: zeroconf in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: ifaddr in /usr/local/lib/python3.5/dist-packages (from zeroconf)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3
Requirement already satisfied: click in /usr/lib/python3/dist-packages
Requirement already satisfied: bs4 in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: six in /usr/lib/python3/dist-packages
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python3.5/dist-packages (from bs4)
Requirement already satisfied: soupsieve>=1.2 in /usr/local/lib/python3.5/dist-packages (from beautifulsoup4->bs4)
-- Installation of python library 'tqdm, websocket-client' for plex with command pip3
Requirement already satisfied: tqdm in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: websocket-client in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from websocket-client)
-- Installation of dependencies is done !
