Merci votre réponse.
Pour le config.txt, le disbale-bt est bien en place. Pour l’uart c’est un rajout comme pour mon PiZero avec Pizigate. Je l’ai levé ,relacé, toujours pareil Ci dessous journal des dépendances
Lancement de l'installation/mise à jour des dépendances openzwave
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 http://packages.microsoft.com/repos/code stable InRelease
Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
Fetched 15.0 kB in 2s (7623 B/s)
Reading package lists...
Installation des dependances
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
g++ is already the newest version (4:8.3.0-1+rpi2).
gcc is already the newest version (4:8.3.0-1+rpi2).
git is already the newest version (1:2.20.1-2+deb10u3).
libjpeg-dev is already the newest version (1:1.5.2-2+deb10u1).
libudev-dev is already the newest version (241-7~deb10u6+rpi1).
make is already the newest version (4.2.1-1.2).
python-dev is already the newest version (2.7.16-1).
python-louie is already the newest version (1.1-4).
python-lxml is already the newest version (4.3.2-1+deb10u2).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.21.0-1).
python-serial is already the newest version (3.4-4).
python-setuptools is already the newest version (40.8.0-1).
unzip is already the newest version (6.0-23+deb10u2).
python-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Installation des dependances Python
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: urwid in /usr/local/lib/python3.7/dist-packages (2.1.2)
Requirement already satisfied: louie in /usr/local/lib/python3.7/dist-packages (2.0)
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (1.15.0)
Requirement already satisfied: tornado in /usr/local/lib/python3.7/dist-packages (6.1)
mkdir: cannot create directory '/opt': File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
WARNING: Skipping Cython as it is not installed.
apt-get install --force-yes -y cython
cython is already the newest version (0.29.2-2).
W: --force-yes is deprecated, use one of the options starting with --allow instead.
Installing dependencies for python : 2 7 16
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
python-docutils is already the newest version (0.14+dfsg-4).
apt-get install --force-yes -y build-essential libudev-dev g++
pip install nose-html
Requirement already satisfied: nose-html in /usr/local/lib/python3.7/dist-packages (1.1)
Requirement already satisfied: nose>=0.11.1 in /usr/local/lib/python3.7/dist-packages (from nose-html) (1.3.7)
pip install nose-progressive
Requirement already satisfied: nose-progressive in /usr/local/lib/python3.7/dist-packages (1.5.2)
Requirement already satisfied: nose>=1.2.1 in /usr/local/lib/python3.7/dist-packages (from nose-progressive) (1.3.7)
Requirement already satisfied: blessings<2.0,>=1.3 in /usr/local/lib/python3.7/dist-packages (from nose-progressive) (1.7)
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (from blessings<2.0,>=1.3->nose-progressive) (1.15.0)
pip install coverage
Requirement already satisfied: coverage in /usr/local/lib/python3.7/dist-packages (5.4)
pip install nose
Requirement already satisfied: nose in /usr/local/lib/python3.7/dist-packages (1.3.7)
pip install pylint
Requirement already satisfied: pylint in /usr/local/lib/python3.7/dist-packages (2.6.0)
Requirement already satisfied: astroid<=2.5,>=2.4.0 in /usr/local/lib/python3.7/dist-packages (from pylint) (2.4.2)
Requirement already satisfied: toml>=0.7.1 in /usr/local/lib/python3.7/dist-packages (from pylint) (0.10.2)
Requirement already satisfied: mccabe<0.7,>=0.6 in /usr/local/lib/python3.7/dist-packages (from pylint) (0.6.1)
Requirement already satisfied: isort<6,>=4.2.5 in /usr/local/lib/python3.7/dist-packages (from pylint) (5.7.0)
Requirement already satisfied: wrapt~=1.11 in /usr/local/lib/python3.7/dist-packages (from astroid<=2.5,>=2.4.0->pylint) (1.12.1)
Requirement already satisfied: typed-ast<1.5,>=1.4.0 in /usr/local/lib/python3.7/dist-packages (from astroid<=2.5,>=2.4.0->pylint) (1.4.2)
Requirement already satisfied: six~=1.12 in /usr/local/lib/python3.7/dist-packages (from astroid<=2.5,>=2.4.0->pylint) (1.15.0)
Requirement already satisfied: lazy-object-proxy==1.4.* in /usr/local/lib/python3.7/dist-packages (from astroid<=2.5,>=2.4.0->pylint) (1.4.3)
#pip install docutils
#pip install setuptools
#The following line crashes with a core dump
#pip install "Cython==0.22"
Dependencies for users installed (python 2 7 16)
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building Proprietary.o
Building UserCode.o
Building ThermostatSetpoint.o
Building Language.o
Building WakeUp.o
Building MultiCmd.o
Building Indicator.o
Building SensorBinary.o
Building DeviceResetLocally.o
Building Configuration.o
Building SensorAlarm.o
Building Hail.o
Building SwitchToggleBinary.o
Building SensorMultilevel.o
Building TimeParameters.o
Building ClimateControlSchedule.o
Building Color.o
Building ManufacturerSpecific.o
In file included from /usr/include/c++/8/map:60,
from /opt/python-openzwave/openzwave/cpp/src/command_classes/CommandClasses.h:32,
from /opt/python-openzwave/openzwave/cpp/src/command_classes/ManufacturerSpecific.cpp:28:
/usr/include/c++/8/bits/stl_tree.h: In function 'std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::iterator std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_M_emplace_hint_unique(std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::const_iterator, _Args&& ...) [with _Args = {const std::piecewise_construct_t&, std::tuple<long long int&&>, std::tuple<>}; _Key = long long int; _Val = std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>; _KeyOfValue = std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >; _Compare = std::less<long long int>; _Alloc = std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >]':
/usr/include/c++/8/bits/stl_tree.h:2411:7: note: parameter passing for argument of type 'std::_Rb_tree<long long int, std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>, std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >, std::less<long long int>, std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> > >::const_iterator' {aka 'std::_Rb_tree_const_iterator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >'} changed in GCC 7.1
In file included from /usr/include/c++/8/map:61,
/usr/include/c++/8/bits/stl_map.h: In static member function 'static bool OpenZWave::ManufacturerSpecific::LoadProductXML()':
/usr/include/c++/8/bits/stl_map.h:518:8: note: parameter passing for argument of type 'std::_Rb_tree<long long int, std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*>, std::_Select1st<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >, std::less<long long int>, std::allocator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> > >::const_iterator' {aka 'std::_Rb_tree_const_iterator<std::pair<const long long int, OpenZWave::ManufacturerSpecific::Product*> >'} changed in GCC 7.1
__i = _M_t._M_emplace_hint_unique(__i, std::piecewise_construct,
Building Lock.o
Building SwitchToggleMultilevel.o
Building ApplicationStatus.o
Building NodeNaming.o
Building DoorLockLogging.o
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp: In member function 'virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)':
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:312:15: warning: passing argument 1 to restrict-qualified parameter aliases with argument 4 [-Wrestrict]
snprintf(usercode, sizeof(usercode), "%s %d", usercode, (int)_data[12+i]);
Building MultiChannelAssociation.o
Building Protection.o
Building MeterPulse.o
Building ManufacturerProprietary.o
Building BarrierOperator.o
Building BasicWindowCovering.o
Building Association.o
Building Clock.o
Building SceneActivation.o
Building CentralScene.o
Building Powerlevel.o
Building Meter.o
Building AssociationCommandConfiguration.o
Building ThermostatOperatingState.o
Building SwitchMultilevel.o
Building Battery.o
Building ThermostatFanMode.o
Building CRC16Encap.o
Building ZWavePlusInfo.o
Building Security.o
Building SoundSwitch.o
Building MultiInstance.o
Building Version.o
Building Alarm.o
Building CommandClasses.o
Building ThermostatFanState.o
Building NoOperation.o
Building EnergyProduction.o
Building Basic.o
Building SwitchAll.o
Building CommandClass.o
Building DoorLock.o
Building ThermostatMode.o
Building ControllerReplication.o
Building SwitchBinary.o
Building Value.o
Building ValueList.o
Building ValueButton.o
Building ValueInt.o
Building ValueStore.o
Building ValueDecimal.o
Building ValueRaw.o
Building ValueString.o
Building ValueByte.o
Building ValueBool.o
Building ValueSchedule.o
Building ValueShort.o
Building Controller.o
Building Wait.o
Building Thread.o
Building Stream.o
Building Log.o
Building HidController.o
Building Mutex.o
Building SerialController.o
Building Event.o
Building FileOps.o
Building TimeStamp.o
Building FileOpsImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building ThreadImpl.o
Building LogImpl.o
Building MutexImpl.o
Building SerialControllerImpl.o
Building EventImpl.o
Building Options.o
Building Scene.o
Building Utils.o
Building Driver.o
Building ZWSecurity.o
Building Group.o
Building Node.o
Building Manager.o
Building Msg.o
Building Notification.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
Making ozw_config file
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build
running build
running build_ext
cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
/usr/lib/python2.7/dist-packages/Cython/Compiler/Main.py:367: FutureWarning: Cython directive 'language_level' not set, using 2 for now (Py2). This will change in a later release! File: /opt/python-openzwave/src-lib/libopenzwave/libopenzwave.pyx
tree = Parsing.p_module(s, pxd, full_module_name)
building 'libopenzwave' extension
creating build
creating build/temp.linux-armv7l-2.7
creating build/temp.linux-armv7l-2.7/src-lib
creating build/temp.linux-armv7l-2.7/src-lib/libopenzwave
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-InigCj/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DPY_SSIZE_T_CLEAN=1 -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o
cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
src-lib/libopenzwave/libopenzwave.cpp:3: warning: "PY_SSIZE_T_CLEAN" redefined
#define PY_SSIZE_T_CLEAN
<command-line>: note: this is the location of the previous definition
In file included from openzwave/cpp/src/aes/aescpp.h:26,
from openzwave/cpp/src/Driver.h:42,
from src-lib/libopenzwave/libopenzwave.cpp:638:
openzwave/cpp/src/aes/aes.h:75: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( disable : 4324 )
openzwave/cpp/src/aes/aes.h:93: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function 'PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)':
src-lib/libopenzwave/libopenzwave.cpp:30325:204: warning: 'bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)' is deprecated [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) __PYX_ERR(0, 4120, __pyx_L1_error)
In file included from src-lib/libopenzwave/libopenzwave.cpp:643:
openzwave/cpp/src/Manager.h:1731:19: note: declared here
DEPRECATED bool BeginControllerCommand( uint32 const _homeId, Driver::ControllerCommand _command, Driver::pfnControllerCallback_t _callback = NULL, void* _context = NULL, bool _highPower = false, uint8 _nodeId = 0xff, uint8 _arg = 0 );
creating build/lib.linux-armv7l-2.7
arm-linux-gnueabihf-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-InigCj/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-InigCj/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-armv7l-2.7/src-lib/libopenzwave/libopenzwave.o openzwave/libopenzwave.a -ludev -lstdc++ -o build/lib.linux-armv7l-2.7/libopenzwave.so
python setup-lib.py install
running install
running bdist_egg
running egg_info
creating src-lib/libopenzwave.egg-info
writing requirements to src-lib/libopenzwave.egg-info/requires.txt
writing src-lib/libopenzwave.egg-info/PKG-INFO
writing top-level names to src-lib/libopenzwave.egg-info/top_level.txt
writing dependency_links to src-lib/libopenzwave.egg-info/dependency_links.txt
writing manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
reading manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_ext
skipping 'src-lib/libopenzwave/libopenzwave.cpp' Cython extension (up-to-date)
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
copying build/lib.linux-armv7l-2.7/libopenzwave.so -> build/bdist.linux-armv7l/egg
creating stub loader for libopenzwave.so
byte-compiling build/bdist.linux-armv7l/egg/libopenzwave.py to libopenzwave.pyc
installing package data to build/bdist.linux-armv7l/egg
running install_data
creating build/bdist.linux-armv7l/egg/config
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
writing build/bdist.linux-armv7l/egg/EGG-INFO/native_libs.txt
creating dist
creating 'dist/libopenzwave-0.3.1-py2.7-linux-armv7l.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing libopenzwave-0.3.1-py2.7-linux-armv7l.egg
creating /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Extracting libopenzwave-0.3.1-py2.7-linux-armv7l.egg to /usr/local/lib/python2.7/dist-packages
Adding libopenzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Processing dependencies for libopenzwave==0.3.1
Searching for six==1.12.0
Best match: six 1.12.0
Adding six 1.12.0 to easy-install.pth file
Using /usr/lib/python2.7/dist-packages
Finished processing dependencies for libopenzwave==0.3.1
Installation of lib finished.
python setup-api.py install
running install
running bdist_egg
running egg_info
creating src-api/openzwave.egg-info
writing requirements to src-api/openzwave.egg-info/requires.txt
writing src-api/openzwave.egg-info/PKG-INFO
writing top-level names to src-api/openzwave.egg-info/top_level.txt
writing dependency_links to src-api/openzwave.egg-info/dependency_links.txt
writing manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
reading manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
running install_lib
running build_py
creating build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/node.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/__init__.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/controller.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/option.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/command.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/scene.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/network.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/object.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/group.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/singleton.py -> build/lib.linux-armv7l-2.7/openzwave
copying src-api/openzwave/value.py -> build/lib.linux-armv7l-2.7/openzwave
creating build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/node.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/__init__.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/controller.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/option.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/command.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/scene.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/network.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/object.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/group.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/singleton.py -> build/bdist.linux-armv7l/egg/openzwave
copying build/lib.linux-armv7l-2.7/openzwave/value.py -> build/bdist.linux-armv7l/egg/openzwave
byte-compiling build/bdist.linux-armv7l/egg/openzwave/node.py to node.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/controller.py to controller.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/option.py to option.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/command.py to command.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/scene.py to scene.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/network.py to network.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/object.py to object.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/group.py to group.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/singleton.py to singleton.pyc
byte-compiling build/bdist.linux-armv7l/egg/openzwave/value.py to value.pyc
copying src-api/openzwave.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/not-zip-safe -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/requires.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying src-api/openzwave.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
creating 'dist/openzwave-0.3.1-py2.7.egg' and adding 'build/bdist.linux-armv7l/egg' to it
Processing openzwave-0.3.1-py2.7.egg
creating /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Extracting openzwave-0.3.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding openzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Processing dependencies for openzwave==0.3.1
Searching for libopenzwave==0.3.1
Best match: libopenzwave 0.3.1
libopenzwave 0.3.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-armv7l.egg
Searching for Louie==1.1
Best match: Louie 1.1
Adding Louie 1.1 to easy-install.pth file
Finished processing dependencies for openzwave==0.3.1
Installation of API finished.
sed: can't read /etc/inittab: No such file or directory
Raspberry Pi 3 Detected. If you use a Razberry board you must Disabling Bluetooth
Please add 'dtoverlay=pi3-miniuart-bt' to the end of the file /boot/config.txt
And reboot your Raspberry Pi
Everything is successfully installed!
Merci pour votre aide.
