je viens d’installer le plugin Emporia stable mais le demon ne démarre pas après plusieurs essais
Jeedom V4.3.17 sur Jeedup
J’ai bien renseigné mon email et le mdp mais impossible.
dépendances ok mais pas le demon.
[2023-09-27 09:25:11][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
File "/var/www/html/plugins/emporiapro/resources/emporiaprod/emporiaprod.py", line 31, in <module>
from components import emporia
File "/var/www/html/plugins/emporiapro/resources/emporiaprod/components/emporia/__init__.py", line 23, in <module>
from pyemvue import PyEmVue
File "/usr/local/lib/python3.7/dist-packages/pyemvue/__init__.py", line 2, in <module>
from pyemvue.pyemvue import PyEmVue
File "/usr/local/lib/python3.7/dist-packages/pyemvue/pyemvue.py", line 1, in <module>
from pyemvue.auth import Auth
File "/usr/local/lib/python3.7/dist-packages/pyemvue/auth.py", line 8, in <module>
import boto3
File "/usr/local/lib/python3.7/dist-packages/boto3/__init__.py", line 17, in <module>
from boto3.session import Session
File "/usr/local/lib/python3.7/dist-packages/boto3/session.py", line 17, in <module>
import botocore.session
File "/usr/local/lib/python3.7/dist-packages/botocore/session.py", line 26, in <module>
import botocore.client
File "/usr/local/lib/python3.7/dist-packages/botocore/client.py", line 15, in <module>
from botocore import waiter, xform_name
File "/usr/local/lib/python3.7/dist-packages/botocore/waiter.py", line 18, in <module>
from botocore.docs.docstring import WaiterDocstring
File "/usr/local/lib/python3.7/dist-packages/botocore/docs/__init__.py", line 15, in <module>
from botocore.docs.service import ServiceDocumenter
File "/usr/local/lib/python3.7/dist-packages/botocore/docs/service.py", line 14, in <module>
from botocore.docs.client import ClientDocumenter, ClientExceptionsDocumenter
File "/usr/local/lib/python3.7/dist-packages/botocore/docs/client.py", line 17, in <module>
from botocore.docs.example import ResponseExampleDocumenter
File "/usr/local/lib/python3.7/dist-packages/botocore/docs/example.py", line 13, in <module>
from botocore.docs.shape import ShapeDocumenter
File "/usr/local/lib/python3.7/dist-packages/botocore/docs/shape.py", line 19, in <module>
from botocore.utils import is_json_value_header
File "/usr/local/lib/python3.7/dist-packages/botocore/utils.py", line 37, in <module>
import botocore.httpsession
File "/usr/local/lib/python3.7/dist-packages/botocore/httpsession.py", line 45, in <module>
from urllib3.contrib.pyopenssl import (
File "/usr/local/lib/python3.7/dist-packages/urllib3/contrib/pyopenssl.py", line 50, in <module>
import OpenSSL.crypto
File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1553, in <module>
class X509StoreFlags(object):
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1573, in X509StoreFlags
CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
[2023-09-27 09:25:41][ERROR] : Impossible de démarrer le démon EmporiaPro, vérifiez les logs
