Voici les logs de MQTTdiscovery (j’ai du le faire en deux fois car trop de caractères):
[2024-03-29 06:26:16]INFO : Arrêt démon
[2024-03-29 06:26:20]INFO : Lancement démon
[2024-03-29 06:26:21]DEBUG : test from daemon
[2024-03-29 06:26:22]DEBUG : new message:{"homeassistant":{"sensor":{"D496A00D9FBC-mode":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","name":"X1-mode","uniq_id":"D496A00D9FBC-mode","val_tpl":"{{ value_json.mode | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}},"D496A00D9FBC-state":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","name":"X1-state","uniq_id":"D496A00D9FBC-state","val_tpl":"{{ value_json.state | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}},"D496A00D9FBC-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"X1-batt","uniq_id":"D496A00D9FBC-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}},"D364721125A3-mode":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","name":"X1-mode","uniq_id":"D364721125A3-mode","val_tpl":"{{ value_json.mode | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}},"D364721125A3-state":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","name":"X1-state","uniq_id":"D364721125A3-state","val_tpl":"{{ value_json.state | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}},"D364721125A3-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"X1-batt","uniq_id":"D364721125A3-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}},"A4C13895A4C2-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C13895A4C2-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}},"A4C13895A4C2-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C13895A4C2-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}},"A4C13895A4C2-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C13895A4C2-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}},"A4C13895A4C2-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C13895A4C2-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}},"A4C1383E6E16-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C1383E6E16-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}},"A4C1383E6E16-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C1383E6E16-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}},"A4C1383E6E16-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C1383E6E16-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}},"A4C1383E6E16-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C1383E6E16-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}},"A4C138AA1739-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C138AA1739-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}},"A4C138AA1739-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C138AA1739-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}},"A4C138AA1739-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C138AA1739-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}},"A4C138AA1739-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C138AA1739-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}},"A4C13877ECC4-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13877ECC4","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C13877ECC4-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C13877ECC4"],"cns":[["mac","A4C13877ECC4"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-77ECC4","via_device":"antennelocale"}}},"A4C13877ECC4-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13877ECC4","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C13877ECC4-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C13877ECC4"],"cns":[["mac","A4C13877ECC4"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-77ECC4","via_device":"antennelocale"}}},"A4C13877ECC4-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13877ECC4","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C13877ECC4-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C13877ECC4"],"cns":[["mac","A4C13877ECC4"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-77ECC4","via_device":"antennelocale"}}},"A4C13877ECC4-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13877ECC4","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C13877ECC4-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C13877ECC4"],"cns":[["mac","A4C13877ECC4"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-77ECC4","via_device":"antennelocale"}}},"A4C13845B129-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13845B129","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C13845B129-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C13845B129"],"cns":[["mac","A4C13845B129"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-45B129","via_device":"antennelocale"}}},"A4C13845B129-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13845B129","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C13845B129-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C13845B129"],"cns":[["mac","A4C13845B129"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-45B129","via_device":"antennelocale"}}},"A4C13845B129-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13845B129","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C13845B129-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C13845B129"],"cns":[["mac","A4C13845B129"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-45B129","via_device":"antennelocale"}}},"A4C13845B129-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13845B129","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C13845B129-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C13845B129"],"cns":[["mac","A4C13845B129"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-45B129","via_device":"antennelocale"}}},"A4C138C60E56-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138C60E56","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C138C60E56-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C138C60E56"],"cns":[["mac","A4C138C60E56"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-C60E56","via_device":"antennelocale"}}},"A4C138C60E56-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138C60E56","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C138C60E56-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C138C60E56"],"cns":[["mac","A4C138C60E56"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-C60E56","via_device":"antennelocale"}}},"A4C138C60E56-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138C60E56","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C138C60E56-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C138C60E56"],"cns":[["mac","A4C138C60E56"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-C60E56","via_device":"antennelocale"}}},"A4C138C60E56-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138C60E56","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C138C60E56-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C138C60E56"],"cns":[["mac","A4C138C60E56"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-C60E56","via_device":"antennelocale"}}}},"device_tracker":{"21AD6499E7A2-tracker":{"config":{"stat_t":"+\/+\/BTtoMQTT\/21AD6499E7A2","name":"NUT-tracker","uniq_id":"21AD6499E7A2-tracker","val_tpl":"{% if value_json.get('rssi') -%}home{%- else -%}not_home{%- endif %}","source_type":"bluetooth_le","device":{"ids":["21AD6499E7A2"],"cns":[["mac","21AD6499E7A2"]],"mf":"nut","mdl":"NUT","name":"Smart Tracker-99E7A2","via_device":"antennelocale"}}}}}}
[2024-03-29 06:26:22]DEBUG : ==> type='sensor' - content= {"D496A00D9FBC-mode":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","name":"X1-mode","uniq_id":"D496A00D9FBC-mode","val_tpl":"{{ value_json.mode | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}},"D496A00D9FBC-state":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","name":"X1-state","uniq_id":"D496A00D9FBC-state","val_tpl":"{{ value_json.state | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}},"D496A00D9FBC-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"X1-batt","uniq_id":"D496A00D9FBC-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}},"D364721125A3-mode":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","name":"X1-mode","uniq_id":"D364721125A3-mode","val_tpl":"{{ value_json.mode | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}},"D364721125A3-state":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","name":"X1-state","uniq_id":"D364721125A3-state","val_tpl":"{{ value_json.state | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}},"D364721125A3-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"X1-batt","uniq_id":"D364721125A3-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}},"A4C13895A4C2-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C13895A4C2-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}},"A4C13895A4C2-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C13895A4C2-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}},"A4C13895A4C2-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C13895A4C2-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}},"A4C13895A4C2-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C13895A4C2-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}},"A4C1383E6E16-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C1383E6E16-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}},"A4C1383E6E16-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C1383E6E16-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}},"A4C1383E6E16-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C1383E6E16-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}},"A4C1383E6E16-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C1383E6E16-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}},"A4C138AA1739-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C138AA1739-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}},"A4C138AA1739-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C138AA1739-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}},"A4C138AA1739-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C138AA1739-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}},"A4C138AA1739-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C138AA1739-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}},"A4C13877ECC4-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13877ECC4","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C13877ECC4-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C13877ECC4"],"cns":[["mac","A4C13877ECC4"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-77ECC4","via_device":"antennelocale"}}},"A4C13877ECC4-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13877ECC4","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C13877ECC4-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C13877ECC4"],"cns":[["mac","A4C13877ECC4"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-77ECC4","via_device":"antennelocale"}}},"A4C13877ECC4-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13877ECC4","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C13877ECC4-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C13877ECC4"],"cns":[["mac","A4C13877ECC4"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-77ECC4","via_device":"antennelocale"}}},"A4C13877ECC4-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13877ECC4","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C13877ECC4-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C13877ECC4"],"cns":[["mac","A4C13877ECC4"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-77ECC4","via_device":"antennelocale"}}},"A4C13845B129-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13845B129","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C13845B129-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C13845B129"],"cns":[["mac","A4C13845B129"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-45B129","via_device":"antennelocale"}}},"A4C13845B129-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13845B129","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C13845B129-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C13845B129"],"cns":[["mac","A4C13845B129"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-45B129","via_device":"antennelocale"}}},"A4C13845B129-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13845B129","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C13845B129-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C13845B129"],"cns":[["mac","A4C13845B129"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-45B129","via_device":"antennelocale"}}},"A4C13845B129-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C13845B129","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C13845B129-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C13845B129"],"cns":[["mac","A4C13845B129"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-45B129","via_device":"antennelocale"}}},"A4C138C60E56-tempc":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138C60E56","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C138C60E56-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C138C60E56"],"cns":[["mac","A4C138C60E56"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-C60E56","via_device":"antennelocale"}}},"A4C138C60E56-hum":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138C60E56","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C138C60E56-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C138C60E56"],"cns":[["mac","A4C138C60E56"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-C60E56","via_device":"antennelocale"}}},"A4C138C60E56-batt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138C60E56","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C138C60E56-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C138C60E56"],"cns":[["mac","A4C138C60E56"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-C60E56","via_device":"antennelocale"}}},"A4C138C60E56-volt":{"config":{"stat_t":"+\/+\/BTtoMQTT\/A4C138C60E56","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C138C60E56-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C138C60E56"],"cns":[["mac","A4C138C60E56"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-C60E56","via_device":"antennelocale"}}}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","name":"X1-mode","uniq_id":"D496A00D9FBC-mode","val_tpl":"{{ value_json.mode | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","name":"X1-state","uniq_id":"D496A00D9FBC-state","val_tpl":"{{ value_json.state | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/D496A00D9FBC","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"X1-batt","uniq_id":"D496A00D9FBC-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["D496A00D9FBC"],"cns":[["mac","D496A00D9FBC"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-0D9FBC","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","name":"X1-mode","uniq_id":"D364721125A3-mode","val_tpl":"{{ value_json.mode | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","name":"X1-state","uniq_id":"D364721125A3-state","val_tpl":"{{ value_json.state | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/D364721125A3","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"X1-batt","uniq_id":"D364721125A3-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["D364721125A3"],"cns":[["mac","D364721125A3"]],"mf":"SwitchBot","mdl":"X1","name":"Bot-1125A3","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C13895A4C2-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C13895A4C2-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C13895A4C2-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C13895A4C2","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C13895A4C2-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C13895A4C2"],"cns":[["mac","A4C13895A4C2"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-95A4C2","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C1383E6E16-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"humidity","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-hum","uniq_id":"A4C1383E6E16-hum","val_tpl":"{{ value_json.hum | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"battery","unit_of_meas":"%","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-batt","uniq_id":"A4C1383E6E16-batt","val_tpl":"{{ value_json.batt | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C1383E6E16","dev_cla":"voltage","unit_of_meas":"V","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-volt","uniq_id":"A4C1383E6E16-volt","val_tpl":"{{ value_json.volt | is_defined }}","device":{"ids":["A4C1383E6E16"],"cns":[["mac","A4C1383E6E16"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-3E6E16","via_device":"antennelocale"}}
[2024-03-29 06:26:22]DEBUG : handle config: {"stat_t":"+\/+\/BTtoMQTT\/A4C138AA1739","dev_cla":"temperature","unit_of_meas":"\u00b0C","state_class":"measurement","name":"LYWSD03MMC\/MJWSD05MMC_ATC-tempc","uniq_id":"A4C138AA1739-tempc","val_tpl":"{{ value_json.tempc | is_defined }}","device":{"ids":["A4C138AA1739"],"cns":[["mac","A4C138AA1739"]],"mf":"Xiaomi","mdl":"LYWSD03MMC\/MJWSD05MMC_ATC","name":"TH Sensor-AA1739","via_device":"antennelocale"}}
C.
