[Thu Feb 15 11:21:15.705580 2024] [access_compat:error] [pid 26356] [client 192.168.1.11:47840] AH01797: client denied by server configuration: /var/www/html/plugins/rfxcom/core/config/devices/undefined, referer: http://jeedomatlas.local/index.php?v=d&m=rfxcom&p=rfxcom
[Thu Feb 15 11:24:46.429840 2024] [access_compat:error] [pid 26356] [client 192.168.1.11:56020] AH01797: client denied by server configuration: /var/www/html/plugins/zigbee/core/config/devices/undefined, referer: http://jeedomatlas.local/index.php?v=d&p=zigbee&m=zigbee&id=1324
[Thu Feb 15 11:25:12.963901 2024] [access_compat:error] [pid 25867] [client 192.168.1.11:56016] AH01797: client denied by server configuration: /var/www/html/plugins/zigbee/core/config/devices/undefined, referer: http://jeedomatlas.local/index.php?v=d&p=zigbee&m=zigbee&id=1324
[Thu Feb 15 11:26:28.626269 2024] [access_compat:error] [pid 29709] [client 192.168.1.11:42428] AH01797: client denied by server configuration: /var/www/html/plugins/zigbee/core/config/devices/undefined, referer: http://jeedomatlas.local/index.php?v=d&m=zigbee&p=zigbee
[Thu Feb 15 11:26:43.228138 2024] [access_compat:error] [pid 25867] [client 192.168.1.11:56016] AH01797: client denied by server configuration: /var/www/html/plugins/zigbee/core/config/devices/undefined, referer: http://jeedomatlas.local/index.php?v=d&m=zigbee&p=zigbee&id=1324
[Thu Feb 15 12:40:53.913117 2024] [access_compat:error] [pid 29157] [client 192.168.1.11:39102] AH01797: client denied by server configuration: /var/www/html/plugins/zigbee/core/config/devices/undefined, referer: http://jeedomatlas.local/index.php?v=d&p=zigbee&m=zigbee&id=1324
[Thu Feb 15 14:47:41.505791 2024] [access_compat:error] [pid 26356] [client 192.168.1.11:58640] AH01797: client denied by server configuration: /var/www/html/plugins/zigbee/core/config/devices/undefined, referer: http://jeedomatlas.local/index.php?v=d&p=zigbee&m=zigbee&id=1324
[Thu Feb 15 19:49:50.531500 2024] [access_compat:error] [pid 26598] [client 192.168.1.11:54248] AH01797: client denied by server configuration: /var/www/html/plugins/zigbee/core/config/devices/undefined, referer: http://jeedomatlas.local/index.php?v=d&m=zigbee&p=zigbee
[Sat Feb 17 23:43:55.939939 2024] [access_compat:error] [pid 3809] [client 66.249.93.224:0] AH01797: client denied by server configuration: /var/www/html/.well-known
[Sat Feb 17 23:43:55.973820 2024] [access_compat:error] [pid 8575] [client 66.249.93.224:0] AH01797: client denied by server configuration: /var/www/html/.well-known
[Sun Feb 18 01:32:30.563283 2024] [access_compat:error] [pid 637] [client 66.249.93.224:0] AH01797: client denied by server configuration: /var/www/html/.well-known
[Sun Feb 18 01:32:30.703672 2024] [access_compat:error] [pid 1331] [client 66.102.9.226:0] AH01797: client denied by server configuration: /var/www/html/.well-known
sudo: yarn: command not found
[Sun Feb 18 18:16:03.978344 2024] [php7:error] [pid 14154] [client 192.168.1.11:58040] PHP Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 84, referer: http://jeedomatlas.local/index.php?v=d&p=object
[Sun Feb 18 18:19:49.465120 2024] [php7:error] [pid 32748] [client 192.168.1.11:36348] PHP Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 84, referer: http://jeedomatlas.local/index.php?v=d&p=plugin&id=espeasy
[Tue Feb 20 06:04:08.688175 2024] [mpm_prefork:notice] [pid 1804] AH00163: Apache/2.4.38 (Debian) configured -- resuming normal operations
[Tue Feb 20 06:04:08.688955 2024] [core:notice] [pid 1804] AH00094: Command line: '/usr/sbin/apache2'
[Tue Feb 20 09:48:29.480605 2024] [mpm_prefork:notice] [pid 1832] AH00163: Apache/2.4.38 (Debian) configured -- resuming normal operations
[Tue Feb 20 09:48:29.481314 2024] [core:notice] [pid 1832] AH00094: Command line: '/usr/sbin/apache2'
--- Logging error ---
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 177, in emit
self.console.print(renderable, overflow="ignore", crop=False, style=style)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1673, in print
extend(render(renderable, render_options))
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1305, in render
for render_output in iter_render:
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 134, in __rich_console__
for line in lines:
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/segment.py", line 249, in split_lines
for segment in segments:
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/console.py", line 1283, in render
renderable = rich_cast(renderable)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/rich/protocol.py", line 36, in rich_cast
renderable = cast_method()
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/self_outdated_check.py", line 130, in __rich__
pip_cmd = get_best_invocation_for_this_pip()
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/entrypoints.py", line 60, in get_best_invocation_for_this_pip
os.path.join(binary_prefix, exe_name),
File "/usr/lib/python3.7/genericpath.py", line 97, in samefile
s2 = os.stat(f2)
FileNotFoundError: [Errno 2] No such file or directory: '/usr/bin/pip'
Call stack:
File "/usr/local/bin/pip3", line 8, in <module>
sys.exit(main())
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/main.py", line 70, in main
return command.main(cmd_args)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/base_command.py", line 101, in main
return self._main(args)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/base_command.py", line 223, in _main
self.handle_pip_version_check(options)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/cli/req_command.py", line 190, in handle_pip_version_check
pip_self_version_check(session, options)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/self_outdated_check.py", line 236, in pip_self_version_check
logger.warning("[present-rich] %s", upgrade_prompt)
File "/usr/lib/python3.7/logging/__init__.py", line 1395, in warning
self._log(WARNING, msg, args, **kwargs)
File "/usr/lib/python3.7/logging/__init__.py", line 1519, in _log
self.handle(record)
File "/usr/lib/python3.7/logging/__init__.py", line 1529, in handle
self.callHandlers(record)
File "/usr/lib/python3.7/logging/__init__.py", line 1591, in callHandlers
hdlr.handle(record)
File "/usr/lib/python3.7/logging/__init__.py", line 905, in handle
self.emit(record)
File "/usr/local/lib/python3.7/dist-packages/pip/_internal/utils/logging.py", line 179, in emit
self.handleError(record)
Message: '[present-rich] %s'
Arguments: (UpgradePrompt(old='22.2.2', new='24.0'),)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
for line in lines:
s2 = os.stat(f2)
Call stack:
sys.exit(main())
self.handle(record)
hdlr.handle(record)
self.emit(record)
[Tue Feb 20 14:30:57.405628 2024] [mpm_prefork:notice] [pid 1799] AH00163: Apache/2.4.38 (Debian) configured -- resuming normal operations
[Tue Feb 20 14:30:57.407598 2024] [core:notice] [pid 1799] AH00094: Command line: '/usr/sbin/apache2'
[Wed Feb 21 17:53:48.464889 2024] [php7:error] [pid 26043] [client 90.49.231.155:0] PHP Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 84, referer: https://f3093b27.eu.jeedom.link/index.php?v=d&p=scenario&id=143
[Thu Feb 22 11:32:46.431086 2024] [php7:error] [pid 20921] [client 92.184.107.228:0] PHP Fatal error: Allowed memory size of 536870912 bytes exhausted (tried to allocate 4096 bytes) in /var/www/html/core/class/DB.class.php on line 84, referer: https://f3093b27.eu.jeedom.link/index.php?v=d&p=solcast&m=solcast&id=1325
[Fri Feb 23 07:52:16.539528 2024] [mpm_prefork:notice] [pid 1838] AH00163: Apache/2.4.38 (Debian) configured -- resuming normal operations
[Fri Feb 23 07:52:16.540057 2024] [core:notice] [pid 1838] AH00094: Command line: '/usr/sbin/apache2'
Warning: password for '802-11-wireless-security.psk' not given in 'passwd-file' and nmcli cannot ask without '--ask' option.
Error: Connection activation failed: Secrets were required, but not provided
Error: Connection activation failed: The base network connection was interrupted
