Bonjour , tous les soirs à 20h00, le pulg-in s’arrête pendant 2 minutes
Avez vous une idée au vu des log ci-dessous de l’erreur ?
merci
[2022-03-17 20:00:02.649]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 11): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
Can't get device info: No such device
[2022-03-17 20:00:02.690]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 12): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:02.733]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 13): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:02.768]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 14): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:02.804]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 15): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:02.841]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 16): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:02.879]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 17): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:02.915]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 18): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:02.950]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 19): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:02.992]WARNING : GLOBAL------Exception on scanner (trying to resolve by myself 20): Failed to execute management command 'le on' (code: 17, error: Invalid Index)
[2022-03-17 20:00:03.030]ERROR : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute management command 'le on' (code: 17, error: Invalid Index)
Effectivement, Sous debian je perds la clé usb. J’ai l’impression que c’est watchdog qui cause le problème de déconnexion. Je n’ai pas trouvé de solution pour l’instant.
pr 25 19:59:01 jeedom4 CRON[16113]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Apr 25 20:00:01 jeedom4 CRON[17404]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Apr 25 20:00:01 jeedom4 CRON[17405]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Apr 25 20:00:02 jeedom4 systemd[1]: Starting Load/Save RF Kill Switch Status...
Apr 25 20:00:02 jeedom4 kernel: [171674.954706] usb 3-2: USB disconnect, device number 4
Apr 25 20:00:02 jeedom4 systemd[1]: Stopped target Bluetooth.
Apr 25 20:00:02 jeedom4 systemd[1]: Started Load/Save RF Kill Switch Status.
Apr 25 20:00:02 jeedom4 rfkill: unblock set for all
Apr 25 20:00:03 jeedom4 rfkill: unblock set for all
Apr 25 20:00:04 jeedom4 kernel: [171677.478668] usb 3-2: new full-speed USB device number 5 using uhci_hcd
Apr 25 20:00:05 jeedom4 kernel: [171677.650935] usb 3-2: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=82.41
Apr 25 20:00:05 jeedom4 kernel: [171677.650936] usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Apr 25 20:00:05 jeedom4 systemd[1]: Reached target Bluetooth.
Apr 25 20:00:05 jeedom4 bluetoothd[640]: Sap driver initialization failed.
Apr 25 20:00:05 jeedom4 bluetoothd[640]: sap-server: Operation not permitted (1)
Apr 25 20:00:10 jeedom4 systemd[1]: systemd-rfkill.service: Succeeded.
Apr 25 20:01:01 jeedom4 CRON[19013]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Apr 25 20:02:01 jeedom4 CRON[19961]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Apr 25 20:03:01 jeedom4 CRON[20896]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Apr 25 20:04:01 jeedom4 CRON[21823]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Apr 25 20:05:01 jeedom4 CRON[22737]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Apr 25 20:05:01 jeedom4 CRON[22738]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Apr 25 20:05:03 jeedom4 rfkill: unblock set for all
Apr 25 20:06:01 jeedom4 CRON[24268]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Apr 25 20:07:01 jeedom4 CRON[25573]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
