Suite à la mise à jour du plugin avec la dernière bêta, le démon s’arrête avec l’erreur suivante
2023-09-16 12:08:36]INFO[devolo_cpld ] ============== begin getWifiConnectedDevices ==============
[2023-09-16 12:08:36]DEBUG[device ] Browsing for ['_dvl-deviceapi._tcp.local.', '_dvl-plcnetapi._tcp.local.']
[2023-09-16 12:08:39]DEBUG[device ] Having trouble getting results via unicast messages. Switching to multicast for this device.
[2023-09-16 12:08:39]DEBUG[device ] Browsing for ['_dvl-deviceapi._tcp.local.', '_dvl-plcnetapi._tcp.local.']
[2023-09-16 12:08:42]ERROR[devolo_cpld ] Fatal error : The device 192.168.1.197 did not answer.
[2023-09-16 12:08:42]INFO[devolo_cpld ] Traceback (most recent call last):
File "/var/www/html/plugins/devolo_cpl/resources/bin/devolo_cpld.py", line 373, in <module>
listen()
File "/var/www/html/plugins/devolo_cpl/resources/bin/devolo_cpld.py", line 268, in listen
time.sleep(0.5)
File "/var/www/html/plugins/devolo_cpl/resources/bin/devolo_cpld.py", line 290, in alrm_handler
asyncio.run (getWifiConnectedDevices(message))
File "/usr/lib/python3.9/asyncio/runners.py", line 44, in run
return loop.run_until_complete(main)
File "/usr/lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete
return future.result()
File "/var/www/html/plugins/devolo_cpl/resources/bin/devolo_cpld.py", line 101, in getWifiConnectedDevices
async with Device(ip=message['ip']) as dpa:
File "/var/www/html/plugins/devolo_cpl/3rdparty/devolo_plc_api-1.3.2/devolo_plc_api/device.py", line 74, in __aenter__
await self.async_connect()
File "/var/www/html/plugins/devolo_cpl/3rdparty/devolo_plc_api-1.3.2/devolo_plc_api/device.py", line 137, in async_connect
raise DeviceNotFound(self.ip)
devolo_plc_api.exceptions.device.DeviceNotFound: The device 192.168.1.197 did not answer.
[2023-09-16 12:08:42]DEBUG[devolo_cpld ] Shutdown
[2023-09-16 12:08:42]DEBUG[devolo_cpld ] Removing PID file /tmp/jeedom/devolo_cpl/daemon.pid
[2023-09-16 12:08:42]INFO[jeedom ] LoopNetServer Thread stopped
[2023-09-16 12:08:42]DEBUG[devolo_cpld ] Exit 0
je n’ai pas de devolo wifi.
jeedom beta 4.4
