Arlo Le flux n'a pas pu être initialisé
Bonjour @Mips,
Depuis quelques jours, je n’arrive plus à accéder aux flux vidéo de mes caméras ARLO. Le message d’erreur : Le flux n’a pas pu être initialisé. est mon seul résultat. J’ai tenté la réinstalle, la suppression, mais rien n’y fait.
Je te joins mes logs et config ci dessous.
Log arlo_update:
*   Launch install of dependencies  *
Sun Oct 4 15:58:02 CEST 2020
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian-security buster/updates InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Hit:4 http://deb.debian.org/debian buster-updates InRelease
Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
Reading package lists...
Install modules using apt-get
Building dependency tree...
Reading state information...
python3-setuptools is already the newest version (40.8.0-1).
python3 is already the newest version (3.7.3-1).
python3-requests is already the newest version (2.21.0-1).
python3-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up gammu-smsd (1.40.0-1) ...
Configuration file '/etc/gammu-smsdrc'
 ==> File on system created by you or by a script.
 ==> File also in package provided by package maintainer.
   What would you like to do about it ?  Your options are:
    Y or I  : install the package maintainer's version
    N or O  : keep your currently-installed version
      D     : show the differences between the versions
      Z     : start a shell to examine the situation
 The default action is to keep your current version.
*** gammu-smsdrc (Y/I/N/O/D/Z) [default=N] ? dpkg: error processing package gammu-smsd (--configure):
 end of file on stdin at conffile prompt
Errors were encountered while processing:
 gammu-smsd
E: Sub-process /usr/bin/dpkg returned an error code (1)
Install the required python libraries
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: monotonic>=1.5 in /usr/local/lib/python3.7/dist-packages (1.5)
Requirement already satisfied: requests>=2.12.4 in /usr/lib/python3/dist-packages (2.21.0)
Requirement already satisfied: sseclient==0.0.18 in /usr/local/lib/python3.7/dist-packages (0.0.18)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from sseclient==0.0.18) (1.12.0)
Install ffmpeg 4
ffmpeg version 4.3.1-static https://johnvansickle.com/ffmpeg/  Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 8 (Debian 8.3.0-6)
configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gmp --enable-libgme --enable-gray --enable-libaom --enable-libfribidi --enable-libass --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librubberband --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libdav1d --enable-libxvid --enable-libzimg
libavutil      56. 51.100 / 56. 51.100
libavcodec     58. 91.100 / 58. 91.100
libavformat    58. 45.100 / 58. 45.100
libavdevice    58. 10.100 / 58. 10.100
libavfilter     7. 85.100 /  7. 85.100
libswscale      5.  7.100 /  5.  7.100
libswresample   3.  7.100 /  3.  7.100
libpostproc    55.  7.100 / 55.  7.100
Sun Oct 4 15:58:20 CEST 2020
*      Install ended      *
Log arlo_daemon (au lancement d’une visualisation de flux)
[2020-10-04 16:08:36][DEBUG] : HeartbeatThread : https://myapi.arlo.com:443 "POST /hmsweb/users/devices/notify/4RD3847FA1BD3 HTTP/1.1" 200 None
[2020-10-04 16:09:06][DEBUG] : HeartbeatThread : https://myapi.arlo.com:443 "POST /hmsweb/users/devices/notify/4RD3847FA1BD3 HTTP/1.1" 200 47
[2020-10-04 16:09:08][DEBUG] : ConnectionThread : https://myapi.arlo.com:443 "POST /hmsweb/users/devices/notify/4RD3847FA1BD3 HTTP/1.1" 200 47
[2020-10-04 16:09:08][DEBUG] : EventHandler_4RD3847FA1BD3 : Send to jeedom :  {'event': {'resource': 'basestation', 'properties': {'interfaceVersion': 14, 'apiVersion': 1, 'state': 'idle', 'swVersion': '1.16.3.2_3563_6cd3d19', 'hwVersion': 'VMB4000r3', 'modelId': 'VMB4000', 'capabilities': ['gateway'], 'mcsEnabled': True, 'autoUpdateEnabled': True, 'updateAvailable': None, 'timeZone': 'CET-1CEST,M3.5.0,M10.5.0/3', 'olsonTimeZone': 'Europe/Amsterdam', 'uploadBandwidthSaturated': True, 'antiFlicker': {'mode': 0, 'autoDefault': 2}, 'lowBatteryAlert': {'enabled': True}, 'lowSignalAlert': {'enabled': False}, 'claimed': True, 'timeSyncState': 'synchronized', 'connectivity': [{'type': 'ethernet', 'connected': True}], 'groups': [], 'localCert': {'ownCert': 'ab1a009fa2bd17c9aed75dafad63105d', 'peerCerts': ['7491554e450bc45af107627e4f4b0959', '3ee682efd30a72f241e13ffee2c158d9']}, 'enableHLS': False}, 'action': 'is', 'transId': 'web!ccec6651.17c17!1601820548577', 'to': '98D5U-176-53875195_web', 'from': '4RD3847FA1BD3'}}
[2020-10-04 16:09:08][DEBUG] : EventHandler_4RD3847FA1BD3 : Starting new HTTP connection (1): 127.0.0.1:80
[2020-10-04 16:09:08][DEBUG] : EventHandler_4RD3847FA1BD3 : http://127.0.0.1:80 "POST /plugins/arlo/core/php/jeeArlo.php?apikey=BgupiFx1pbmHkTwMLShpXZuCkT2juLje HTTP/1.1" 200 2
[2020-10-04 16:09:30][DEBUG] : Thread-2  : Client connected to [127.0.0.1:47322]
[2020-10-04 16:09:30][DEBUG] : Thread-2  : Message read from socket: b'{"action":"StartStream","camera":{"parentId":"4RD3847FA1BD3","deviceId":"4N7171S825666","deviceType":"camera","xCloudId":"PK55VCUW-1690-176-115514143","properties":{"modelId":"VMC3030","olsonTimeZone":"Europe\/Amsterdam","hwVersion":"H7"},"modelId":"VMC3030"},"apikey":"BgupiFx1pbmHkTwMLShpXZuCkT2juLje"}'
[2020-10-04 16:09:30][DEBUG] : Thread-2  : Client disconnected from [127.0.0.1:47322]
[2020-10-04 16:09:30][DEBUG] : MainThread : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-10-04 16:09:30][DEBUG] : MainThread : StopStream 4N7171S825666
[2020-10-04 16:09:30][DEBUG] : EventHandler_4RD3847FA1BD3 : Send to jeedom :  {'event': {'resource': 'cameras/4N7171S825666', 'action': 'is', 'properties': {'streamURL': 'rtsp://arlostreaming440-z1-prod.ar.arlo.com:443/vzmodulelive/4N7171S825666_1601820689369?ingressToken=d6909a85_691d_4f15_980a_da79434a8a72&smartToken=_EHULngri8J7cTQjtaD3s9Y2muxfa_R40FaIPgdGGCKqhfvyIUG-JIuIjvkwyeP8q0zIJLxejxG7-V1ztWYh7wVsMJ8G1nmxMkP4M7sqcHYuHh4bhZmkHfsU4YPXOsAB4UdOP4ZmUKqc2Ea2mA3HCv7oKVSLm3EsH9QWSrmr9ktbCQihGI9PwJ-BJquxvw34dz4H_7bhybt_lGo7lM2hiuO2WpbK9bpx0RNTIA8nohuaDnq4P_eMTMkjmlmoNAKu-D25tkET6FdPbmwNuJ9nkGzx2AlwtThcFvXeEBckKOMmqGeD5ZT_7_Vy9sSK42rffONdrrsgCDnwZxGg_5YtR-j5XVefc4HMyNKhmZMVoQ07QKaTD1sUXUnxRmRbu-GIBHUCjel2urc6_WYOdoJdAVSw-t6t9hE_BUsMmkokxOybn4bBzR5zFi1xy7cbX71yl1cyg9iaVgODW6PdXPB91ojMz-0KThBUFjApTBaRyTVWOFffKq0K-w3zxHpqqtXA5JkS1kAkRhbEY5NIfytxH-s08zBk2pQsodEulXVPkN_ViCMyQmoBCAhDITfT-pyFCjqaLM0L34iHR4h81bD4PePPjF0gY9fioVehvuoA1mqj2Y7lMS41IFXD502y_eXAwFjKxg9JXTf6zRFBDlPfvWn2UOGRzORfWmDPniULgdSE5FfW8ok1NHUKRBkuWmx345uioJsmiWtZ8EKCJxpcBwA9g-xebJ94vcj59kqwROZzGZ0Hvy-a2MrqoW6HVTIYRXlViHFMVCIMFelZsQhwlLCTdeidYqLeHKRBQRFN6v5ny6eD3Kv8tOGVMwJe_tsbCvJHvCSwECx6OvwHZ3ollWDZW5A_thI15kUswKJ__tCt_zVNz9k1W67-LW7PHpwHAXjUtQVsm7RjKzltl57zLW-KlyxIII9mf9a1c0VCgbq7lH50O4LHlbvLUU6hd8jVhcpK01kSzBPXwSLCYQ_eGx2AxD-jLZ7j1s1udBuq3KvjgUh-gXb_Ka2_4K0Ss2LoQThsFSxPi66dQerRAqbC_WoR-7ErD4wKOefxHLh89og07L36HVjTXn9xAz2b_sKWbey84tiv-RvrCdFNbsn5UZQ3PUv5WasbE3e1_Q9_k1ccDlMyLD2FtqhADCrKXDPsAQeo28MN1PSKapihCirFo0zX0I0s6SW_gXvZrdNjjdpYfV1AgW2tcgDgqZvHv0lD&version=v1&cameraId=4N7171S825666', 'activityState': 'startUserStream'}, 'transId': 'web!1fbbdf36.4ea96!1601820570157', 'to': '98D5U-176-53875195_web', 'from': '4RD3847FA1BD3'}}
[2020-10-04 16:09:30][DEBUG] : EventHandler_4RD3847FA1BD3 : Starting new HTTP connection (1): 127.0.0.1:80
[2020-10-04 16:09:30][DEBUG] : EventHandler_4RD3847FA1BD3 : http://127.0.0.1:80 "POST /plugins/arlo/core/php/jeeArlo.php?apikey=BgupiFx1pbmHkTwMLShpXZuCkT2juLje HTTP/1.1" 200 2
[2020-10-04 16:09:30][DEBUG] : EventHandler_4RD3847FA1BD3 : Send to jeedom :  {'event': {'from': '4RD3847FA1BD3', 'action': 'is', 'resource': 'cameras/4N7171S825666', 'properties': {'activityState': 'startUserStream', 'dateStarted': 1601820689438}, 'transId': '4RD3847FA1BD3!b2bc5079!1601820689443'}}
[2020-10-04 16:09:32][DEBUG] : MainThread : https://myapi.arlo.com:443 "POST /hmsweb/users/devices/startStream HTTP/1.1" 200 None
[2020-10-04 16:09:32][DEBUG] : MainThread : StartStream 4N7171S825666
[2020-10-04 16:09:32][DEBUG] : EventHandler_4RD3847FA1BD3 : Send to jeedom :  {'event': {'from': '4RD3847FA1BD3', 'action': 'is', 'resource': 'cameras/4N7171S825666', 'properties': {'activityState': 'userStreamActive', 'dateStarted': 1601820691195}, 'transId': '4RD3847FA1BD3!42a4e93d!1601820691198'}}
[2020-10-04 16:09:32][DEBUG] : EventHandler_4RD3847FA1BD3 : Starting new HTTP connection (1): 127.0.0.1:80
[2020-10-04 16:09:32][DEBUG] : EventHandler_4RD3847FA1BD3 : http://127.0.0.1:80 "POST /plugins/arlo/core/php/jeeArlo.php?apikey=BgupiFx1pbmHkTwMLShpXZuCkT2juLje HTTP/1.1" 200 2
[2020-10-04 16:09:35][DEBUG] : StreamingThread : Starting ffmpeg['/opt/ffmpeg4/ffmpeg4', '-loglevel', 'error', '-nostdin', '-re', '-t', '300', '-headers', 'Origin: https://my.arlo.com', '-headers', 'Egress-Token: d6909a85_691d_4f15_980a_da79434a8a72', '-fflags', '+genpts', '-i', 'https://arlostreaming440-z1-prod.wowza.arlo.com:80/stream/4N7171S825666_1601820689369.mpd?egressToken=d6909a85_691d_4f15_980a_da79434a8a72&userAgent=web&cameraId=4N7171S825666_1601820689369&txnId=be!90e88cce-3955-4dff-b7e8-b4d886d6ccb9', '-y', '-codec', 'copy', '-map', '0', '-f', 'segment', '-segment_list', '/var/www/html/plugins/arlo/data/stream/4N7171S825666.m3u8', '-segment_list_flags', '+live', '-segment_time', '2', '/var/www/html/plugins/arlo/data/stream/4N7171S825666%03d.ts']
[2020-10-04 16:09:37][DEBUG] : HeartbeatThread : https://myapi.arlo.com:443 "POST /hmsweb/users/devices/notify/4RD3847FA1BD3 HTTP/1.1" 200 None
Ma config:
  • rpi 4b sur ssd avec image jeedom-debian-buster-rpi-64
  • jeedom 3.3.53
  • OS Linux jeedom 5.4.51-v8+ #1333 SMP PREEMPT Mon Aug 10 16:58:35 BST 2020 aarch64 GNU/Linux [10.6]
  • plugin Arlo en stable
N’hésites pas à revenir vers moi si tu as besoin d’informations.
A lire point n°11
Merci @olive pour cette précision, je n’y parvenais pas.
On ne voit aucune erreur dans le log, rien qui puisse dire que cela c’est mal passé (je ne dis pas que tout fonctionne bien mais donc cela ne donne aucune piste)
Cela fonctionnait donc il y a quelques jours? la dernière mise à jour date du 22/09, si cette version était déjà installée cela ne vient donc pas d’un changement sur le code du plugin.
  1. Le reste fonctionne bien?
  2. Qu’est-ce qui a changé sur ton installation depuis?
Sinon autre possibilité cela pourrait être lié au 2FA, mais je ne pense pas car cela empêcherait le login et donc le démarrage du démon et pas juste le streaming.
l’as-tu activé? moi j’ai encore un jeedom qui tourne sans le 2FA activé et ce n’est toujours pas bloqué donc Arlo n’a pas (encore) imposé cela comme annoncé.
Et petit retour avec ma casquette de modérateur cette fois:
  • de manière générale, pas la peine de tag le développeur en plus du tag du plugin, ce dernier suffit (perso, je surveille tous les tags de mes plugins de toute façon)
  • le message en privé reçu il y a quelques minutes est de trop: une relance en privé 1 journée après un poste, c’est pas très correcte
    surtout en sachant que le premier message a été posté un dimanche fin de journée, même si souvent je répond dans les minutes ou heures qui suivent ca peut m’arriver d’avoir d’autre occupation (et on a le droit de profiter de son dimanche aussi); rentré chez moi le soir, ajd boulot, rentré il y a 20min et voici ma réponse environ 26h après la demande, toute les assistances n’offrent pas un tel délai :wink:
Merci de ton retour, et désolé d’être pressant (j’avoue que quand j’ai un problème j’ai du mal a être patient…:sweat_smile:)
Pour essayer de faire avancer les choses, pas d’identification à 2 facteurs, j’ai d’ailleurs vérifié mes deux comptes Arlo pour m’en assurer. Concernant les changements, j’ai fait une réinstalle complète sur mon SSD car mon blea ne reconnaissait ni mon Bluetooth interne rpi, ni ma clé. Aujourd’hui ceci est fonctionnel comme tout le reste, seul mon flux Arlo pose soucis, mais je ne pense pas que cette réinstallation en soit la cause. Qu’en pensez-vous? Que puis-je vous fournir?
Charly
Dans le log d’install des dépendances je vois un problème avec gammu (qui n’est absolument pas installé par le plugin)
donc il y a des « crasses » qui gêne dpkg, peut-être pourrais-tu essayer de fixer cela et relancer les dépendances pour être sur d’avoir quelque chose de clean?
Je vais supprimer complètement ce plugin gammu (testé pour clé 3g) et vais retenter une installation des dépendances. Je te tiens au courant.
la suppression d’un plugin ne supprimera pas les dépendances que le plugin a installé; donc le problème au niveau de dpkg restera après la désinstallation.
Je viens de faire un « sudo apt-get autoremove --purge gammu-smsd » puis réinstallation des dépendances Arlo sans pb dpkg(voir ci-dessous) mais toujours pas de flux…
Mon Oct 5 20:56:28 CEST 2020
Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Hit:3 http://deb.debian.org/debian-security buster/updates InRelease
Get:4 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:6 http://archive.raspberrypi.org/debian buster/main arm64 Packages [239 kB]
Get:7 http://archive.raspberrypi.org/debian buster/main armhf Packages [331 kB]
Fetched 654 kB in 3s (243 kB/s)
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Install ffmpeg 4
Mon Oct 5 20:56:43 CEST 2020
*      Install ended      *
Dois-je tenter une réparation de dpkg?
C’est p-e lié avec l’image jeedom en fait, je viens de remarquer que tu as ca
tu avais quoi avant comme version de linux avant?
peux-tu executer
/usr/bin/ffmpeg -version
si pas encore installé tu peux faire un
apt-get install -y ffmpeg
et tant qu’à faire me donner le résultat de ceci sur cette version
cat /etc/os-release
J’étais sur la même image (jeedom-debian-buster-rpi-64), à la réinstallation j’ai fait un update mais je ne sais pas dire si différente de mon ancienne, qui au passage était également récente (début septembre).
Pour répondre à tes besoins:
ffmpeg version 4.1.6-1~deb10u1+rpt1 Copyright (c) 2000-2020 the FFmpeg developers
configuration: --prefix=/usr --extra-version='1~deb10u1+rpt1' --toolchain=hardened --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --libdir=/usr/lib/aarch64-linux-gnu --arch=arm64 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil      56. 22.100 / 56. 22.100
libavcodec     58. 35.100 / 58. 35.100
libavformat    58. 20.100 / 58. 20.100
libavdevice    58.  5.100 / 58.  5.100
libavfilter     7. 40.101 /  7. 40.101
libavresample   4.  0.  0 /  4.  0.  0
libswscale      5.  3.100 /  5.  3.100
libswresample   3.  3.100 /  3.  3.100
libpostproc    55.  3.100 / 55.  3.100
cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Bonjour @Mips,
Petit retour sur mon dysfonctionnement de flux. Après divers essais et recherches, j’ai enfin résolu mon problème de flux. Il s’agissait vraisemblablement d’un « timeout » d’initialisation de flux. Initialement, ma base Arlo était connecté sur mon routeur Wifi (fortement sollicité par le nombre de « devices » connectés), après avoir branché celle-ci en direct sur ma Freebox, le délai de connexion (sur l’application IOS Arlo) s’est fortement réduit et mon flux vidéo sur le plugin est redevenu fonctionnel.
Merci encore pour ton plugin :wink:
lychar460
Ok super
Désolé ce sujet m’était sorti de l’esprit :face_with_hand_over_mouth:
