Ce jour apres la maj impossible d’installer les dépendances
* Launch install of dependencies *
Thu Mar 26 17:55:04 UTC 2020
E: Could not get lock /var/cache/apt/archives/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/cache/apt/archives/
Ign:2 http://ftp.debian.org/debian stretch InRelease
Get:3 http://ftp.debian.org/debian stretch-updates InRelease [91.0 kB]
Get:4 http://ftp.debian.org/debian stretch-backports InRelease [91.8 kB]
Hit:5 https://deb.nodesource.com/node_12.x stretch InRelease
Get:6 http://ftp.debian.org/debian stretch-proposed-updates InRelease [106 kB]
Hit:7 http://ftp.debian.org/debian stretch Release
Err:3 http://ftp.debian.org/debian stretch-updates InRelease
At least one invalid signature was encountered.
Hit:8 http://www.deb-multimedia.org stretch InRelease
Hit:9 http://security.debian.org stretch/updates InRelease
Err:4 http://ftp.debian.org/debian stretch-backports InRelease
Err:6 http://ftp.debian.org/debian stretch-proposed-updates InRelease
Err:9 http://security.debian.org stretch/updates InRelease
Hit:11 https://oph.mdrjr.net/meveric all InRelease
Hit:12 https://oph.mdrjr.net/meveric stretch InRelease
Ign:1 https://repo.jeedom.com/odroid stable InRelease
Err:13 https://repo.jeedom.com/odroid stable Release
504 Gateway Timeout
Reading package lists...
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ftp.debian.org/debian stretch-updates InRelease: At least one invalid signature was encountered.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ftp.debian.org/debian stretch-backports InRelease: At least one invalid signature was encountered.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://ftp.debian.org/debian stretch-proposed-updates InRelease: At least one invalid signature was encountered.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://security.debian.org stretch/updates InRelease: At least one invalid signature was encountered.
E: The repository 'http://repo.jeedom.com/odroid stable Release' does no longer have a Release file.
Install modules using apt-get
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Install the required python libraries
DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
Requirement already satisfied: monotonic>=1.5 in /usr/local/lib/python2.7/dist-packages (1.5)
Requirement already satisfied: requests>=2.12.4 in /usr/lib/python2.7/dist-packages (2.12.4)
Requirement already satisfied: sseclient==0.0.18 in /usr/local/lib/python2.7/dist-packages (0.0.18)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from sseclient==0.0.18) (1.10.0)
WARNING: You are using pip version 19.1.1, however version 20.0.2 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Install ffmpeg 4
Downloading ffmpeg version(ffmpeg-release-arm64-static.tar.xz) for aarch64...
tar: ffmpeg-4.2.2-arm64-static/GPLv3.txt: Cannot write: No space left on device
tar: ffmpeg-4.2.2-arm64-static/manpages/ffmpeg-all.txt: Cannot write: No space left on device
xz: (stdin): Unexpected end of input
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
Copying to /var/www/html/plugins/arlo/core/class/../../resources/ffmpeg
cp: cannot stat 'ffmpeg': No such file or directory
cp: cannot stat 'ffprobe': No such file or directory
/var/www/html/plugins/arlo/core/class/../../resources/install_apt.sh: line 93: /var/www/html/plugins/arlo/core/class/../../resources/ffmpeg/ffmpeg: No such file or directory
Thu Mar 26 17:57:17 UTC 2020
* Install ended *
Je ne comprends pas rien n’a changé sur l’installation
