[2025-02-06 16:55:08] INFO : Lancement démon
[2025-02-06 17:50:39] INFO : Début d'activation du plugin
[2025-02-06 17:50:42] INFO : Info sur le démon : {"log":"arlo","state":"nok","launchable":"ok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"2025-01-19 10:30:06"}
[2025-02-06 17:52:07] INFO : Lancement démon
[2025-02-10 04:00:06] INFO : Deleting /var/www/html/plugins/arlo/data/records/52M1817MACC2D/20250110203016054234.jpg
[2025-02-10 04:00:06] INFO : Deleting /var/www/html/plugins/arlo/data/records/52M1817MACC2D/20250110173508.mp4
[2025-02-10 04:00:06] INFO : Deleting /var/www/html/plugins/arlo/data/records/52M1817MACC2D/20250110173530970814.jpg
[2025-02-10 04:00:06] INFO : Deleting /var/www/html/plugins/arlo/data/records/52M1817MACC2D/20250110115527.mp4
[2025-02-10 04:00:06] INFO : Deleting /var/www/html/plugins/arlo/data/records/52M1817MACC2D/20250110115549731038.jpg
[2025-02-12 20:22:44] INFO : Lancement démon
[2025-02-06 17:52:27] INFO : Send async started with a cycle of 0.5s
[2025-02-07 04:00:06] ERROR : Send command to daemon error: 'PyArlo' object has no attribute '_devices'
[2025-02-07 04:00:06] INFO : get available modes for 0 locations
[2025-02-07 04:00:06] INFO : get available modes for 0 basestations
[2025-02-07 04:00:06]WARNING : no device with id 4RD3897HA0E95
[2025-02-07 04:00:06]WARNING : no device with id 4RD3817LA2408
[2025-02-08 04:00:06] ERROR : Send command to daemon error: 'PyArlo' object has no attribute '_devices'
[2025-02-08 04:00:06] INFO : get available modes for 0 locations
[2025-02-08 04:00:06] INFO : get available modes for 0 basestations
[2025-02-08 04:00:06]WARNING : no device with id 4RD3897HA0E95
[2025-02-08 04:00:06]WARNING : no device with id 4RD3817LA2408
[2025-02-09 04:00:06] ERROR : Send command to daemon error: 'PyArlo' object has no attribute '_devices'
[2025-02-09 04:00:06] INFO : get available modes for 0 locations
[2025-02-09 04:00:06] INFO : get available modes for 0 basestations
[2025-02-09 04:00:06]WARNING : no device with id 4RD3897HA0E95
[2025-02-09 04:00:07]WARNING : no device with id 4RD3817LA2408
[2025-02-09 04:00:07]WARNING : no device with id 4RD3897HA0E95
[2025-02-10 04:00:06] ERROR : Send command to daemon error: 'PyArlo' object has no attribute '_devices'
[2025-02-10 04:00:06] INFO : get available modes for 0 locations
[2025-02-10 04:00:06] INFO : get available modes for 0 basestations
[2025-02-10 04:00:06]WARNING : no device with id 4RD3897HA0E95
[2025-02-10 04:00:06]WARNING : no device with id 4RD3817LA2408
[2025-02-11 04:00:06] ERROR : Send command to daemon error: 'PyArlo' object has no attribute '_devices'
[2025-02-11 04:00:06] INFO : get available modes for 0 locations
[2025-02-11 04:00:06] INFO : get available modes for 0 basestations
[2025-02-11 04:00:06]WARNING : no device with id 4RD3897HA0E95
[2025-02-11 04:00:06]WARNING : no device with id 4RD3817LA2408
[2025-02-12 04:00:07] ERROR : Send command to daemon error: 'PyArlo' object has no attribute '_devices'
[2025-02-12 04:00:07] INFO : get available modes for 0 locations
[2025-02-12 04:00:07] INFO : get available modes for 0 basestations
[2025-02-12 04:00:07]WARNING : no device with id 4RD3897HA0E95
[2025-02-12 04:00:07]WARNING : no device with id 4RD3817LA2408
[2025-02-12 13:19:18] INFO : Start stream
[2025-02-12 13:19:18] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 13:20:52] INFO : Stop stream
[2025-02-12 13:20:52] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 13:20:54] INFO : Start stream
[2025-02-12 13:20:54] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 13:21:58] INFO : Stop stream
[2025-02-12 13:21:58] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 13:22:02] INFO : Start stream
[2025-02-12 13:22:02] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 13:22:07] INFO : Stop stream
[2025-02-12 13:22:07] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 13:23:26] INFO : Start stream
[2025-02-12 13:23:26] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 13:24:05] INFO : Stop stream
[2025-02-12 13:24:05] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 13:31:15] INFO : Start stream
[2025-02-12 13:31:15] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 13:36:06] INFO : Stop stream
[2025-02-12 13:36:06] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 14:56:36] INFO : Start stream
[2025-02-12 14:56:36] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 14:57:04] INFO : Stop stream
[2025-02-12 14:57:04] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 20:12:39] INFO : Start stream
[2025-02-12 20:12:39] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 20:22:02] INFO : Signal 15 caught, exiting...
[2025-02-12 20:22:02] INFO : Cancelling 3 tasks
[2025-02-12 20:22:02] INFO : Listening cancelled
[2025-02-12 20:22:02] INFO : Send async cancelled
[2025-02-12 20:22:02] INFO : Shutdown
[2025-02-12 20:22:45] INFO : ffmpeg loglevel: info->info
[2025-02-12 20:22:45] INFO : Starting daemon with log level: info
[2025-02-12 20:22:45] INFO : Listening on 127.0.0.1:55030
[2025-02-12 20:22:54] ERROR : login failed: 403 - possible cloudflare issue
[2025-02-12 20:23:04] ERROR : login failed: 403 - possible cloudflare issue
[2025-02-12 20:23:04] ERROR : Unable to connect to Arlo
[2025-02-12 20:23:04] INFO : Send async started with a cycle of 0.5s
[2025-02-12 20:23:04] INFO : Start stream
[2025-02-12 20:23:04] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 20:23:14] INFO : Stop stream
[2025-02-12 20:23:14] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 20:23:15] INFO : Start stream
[2025-02-12 20:23:15] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 20:23:21] INFO : Stop stream
[2025-02-12 20:23:21] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 20:23:21] INFO : Start stream
[2025-02-12 20:23:21] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 20:23:25] INFO : Stop stream
[2025-02-12 20:23:25] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 20:23:26] INFO : Start stream
[2025-02-12 20:23:26] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 20:23:30] INFO : Stop stream
[2025-02-12 20:23:30] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 20:23:31] INFO : Start stream
[2025-02-12 20:23:31] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 20:23:38] INFO : Stop stream
[2025-02-12 20:23:38] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
[2025-02-12 20:23:38] INFO : Start stream
[2025-02-12 20:23:38] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'start_stream'
[2025-02-12 20:25:16] INFO : Stop stream
[2025-02-12 20:25:16] ERROR : Send command to daemon error: 'NoneType' object has no attribute 'stop_stream'
== 12/02/2025 20:22:08 == Dependencies installation for arlo
[ 5% ] : Clean apt...
[ 9% ] : Clean apt : [ OK ]
[ 10% ] : Update apt...
[ 14% ] : Update apt : [ OK ]
[ 15% ] : Install apt packages...
[ 19% ] : Install apt packages : [ OK ]
[ 20% ] : Init python3 & prerequisites...
[ 29% ] : Init python3 & prerequisites : [ OK ]
[ 30% ] : Init PyEnv...
** PyEnv not required: 3.9.2 >= 3.9 **
** python3 path: python3 **
[ 39% ] : Init PyEnv : [ OK ]
[ 40% ] : Setting up virtual environment...
** Version of python in VENV: Python 3.9.2
[ 69% ] : Setting up virtual environment : [ OK ]
[ 70% ] : Install the required python packages...
[ 79% ] : Install the required python packages : [ OK ]
[ 80% ] : Restoring folders and files rights...
[ 89% ] : Restoring folders and files rights : [ OK ]
[ 90% ] : Summary of installed packages...
aiohappyeyeballs==2.4.0
aiohttp==3.10.5
aiosignal==1.3.1
async-timeout==4.0.3
attrs==24.2.0
certifi==2024.6.2
cffi==1.17.1
charset-normalizer==3.3.2
cloudscraper==1.2.71
cryptography==42.0.8
frozenlist==1.4.1
idna==3.7
jeedomdaemon==1.2.0
monotonic==1.6
multidict==6.1.0
paho-mqtt==2.1.0
pkg_resources==0.0.0
pycparser==2.22
pyparsing==3.1.2
python-slugify==8.0.4
requests==2.32.3
requests-toolbelt==1.0.0
six==1.16.0
sseclient==0.0.18
text-unidecode==1.3
typing_extensions==4.12.2
Unidecode==1.3.8
urllib3==2.2.1
yarl==1.11.1
[ 99% ] : Summary of installed packages : [ OK ]
[100% ] : Finished !
==OK== Installation Successful
Il faudrait le log du démon au démarrage, il n’est probablement pas connecté, il doit y avoir une erreur dans le log.
C’est probablement lié aux nouveaux blocages récents par cloudflare, voir les derniers Sujets avec l'étiquette plugin-arlo
J’ai mis en ligne une nouvelle version qui stop le démon s’il n’est pas connecté, installez cette version et redémarrez pour voir si c’est mieux sinon suivre ceci:
voici le log arlo_deamon aprés un redémarrage du deamon.
0000|[2025-02-13 15:50:23] INFO : Signal 15 caught, exiting...
0001|[2025-02-13 15:50:23] INFO : Cancelling 3 tasks
0002|[2025-02-13 15:50:23] INFO : Send async cancelled
0003|[2025-02-13 15:50:23] INFO : Listening cancelled
0004|[2025-02-13 15:50:23] INFO : Shutdown
0005|[2025-02-13 15:51:45] INFO : ffmpeg loglevel: info->info
0006|[2025-02-13 15:51:45] INFO : Starting daemon with log level: info
0007|[2025-02-13 15:51:45] INFO : Listening on 127.0.0.1:55030
0008|[2025-02-13 15:51:55] ERROR : login failed: 403 - possible cloudflare issue
0009|[2025-02-13 15:52:04] ERROR : login failed: 403 - possible cloudflare issue
0010|[2025-02-13 15:52:04] ERROR : Unable to connect to Arlo
0011|[2025-02-13 15:52:04] INFO : Send async started with a cycle of 0.5s
j’ai supposé que vous parliez de la Beta que j’ai installé, coupé le redémarrage auto mais le deamon reste actif. et pas de flux pour l’instant.
ou j’ai raté quelque chose?
