Je suppose qu’il s’agit de mymodbus-uptade, cela semble ok.
0000|++++++++++++++++++++++++++++++++++++++
0001|+ MyModbus Install dependancies
0002|+ v1.3
0003|+ By Bebel27
0004|++++++++++++++++++++++++++++++++++++++
0005|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0006|MyModbus - Debut de l'installation des dependances ...
0007|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0008|-
0009|Mon Oct 31 00:01:33 CET 2022
0010|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0011|Mises a jour du systeme en cours ...
0012|/!\ Peut etre long suivant l'anciennete de votre systeme.
0013|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0014|-
0015|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0016|Installation dependance python-pip
0017|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0018|Reading package lists...
0019|Building dependency tree...
0020|Reading state information...
0021|python3-pip is already the newest version (18.1-5+rpt1).
0022|The following package was automatically installed and is no longer required:
0023|raspi-gpio
0024|Use 'sudo apt autoremove' to remove it.
0025|0 upgraded, 0 newly installed, 0 to remove and 90 not upgraded.
0026|-
0027|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0028|Installation dependance pypModbusTCP
0029|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0030|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0031|Collecting pyModbus
0032|Using cached https://files.pythonhosted.org/packages/fb/0f/28190d06bbc3b78834d384cb04bb15e5dcdea4f5d370094dbf5debc3af10/pymodbus-2.5.3-py2.py3-none-any.whl
0033|Requirement already satisfied: six>=1.15.0 in /usr/local/lib/python2.7/dist-packages (from pyModbus) (1.16.0)
0034|Requirement already satisfied: pyserial>=3.4 in /usr/lib/python2.7/dist-packages (from pyModbus) (3.4)
0035|Installing collected packages: pyModbus
0036|Successfully installed pyModbus-2.5.3
0037|Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
0038|Collecting pyModbusTCP
0039|Downloading https://files.pythonhosted.org/packages/47/d0/b1fb0eb5178a6acbce7a6f392aa39d45c9e8e3f4f62d5415d8c8d035165a/pyModbusTCP-0.2.0.tar.gz
0040|Building wheels for collected packages: pyModbusTCP
0041|Running setup.py bdist_wheel for pyModbusTCP: started
0042|Running setup.py bdist_wheel for pyModbusTCP: finished with status 'done'
0043|Stored in directory: /root/.cache/pip/wheels/99/dc/f3/30bfd2bbc0ad00a9bf11f669bcef0aa4f0a7677b0a17b1da18
0044|Successfully built pyModbusTCP
0045|Installing collected packages: pyModbusTCP
0046|Successfully installed pyModbusTCP-0.2.0
0047|-
0048|-
0049|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0050|Installation dependance git
0051|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0052|Reading package lists...
0053|Building dependency tree...
0054|Reading state information...
0055|The following package was automatically installed and is no longer required:
0056|raspi-gpio
0057|Use 'sudo apt autoremove' to remove it.
0058|Suggested packages:
0059|git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk
0060|gitweb git-cvs git-mediawiki git-svn
0061|The following packages will be upgraded:
0062|git
0063|1 upgraded, 0 newly installed, 0 to remove and 89 not upgraded.
0064|Need to get 4195 kB of archives.
0065|After this operation, 4096 B of additional disk space will be used.
0066|Get:1 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf git armhf 1:2.20.1-2+deb10u4 [4195 kB]
0067|apt-listchanges: Reading changelogs...
0068|debconf: unable to initialize frontend: Dialog
0069|debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
0070|debconf: falling back to frontend: Readline
0071|debconf: unable to initialize frontend: Readline
0072|debconf: (This frontend requires a controlling tty.)
0073|debconf: falling back to frontend: Teletype
0074|dpkg-preconfigure: unable to re-open stdin:
0075|Fetched 4195 kB in 13s (332 kB/s)
0076|(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 67251 files and directories currently installed.)
0077|Preparing to unpack .../git_1%3a2.20.1-2+deb10u4_armhf.deb ...
0078|Unpacking git (1:2.20.1-2+deb10u4) over (1:2.20.1-2+deb10u3) ...
0079|Setting up git (1:2.20.1-2+deb10u4) ...
0080|-
0081|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0082|Clonage de mbtget
0083|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0084|-
0085|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0086|Fin de l'installation des dependances MyModbus...
0087|++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
0088|Version de python
0089|Python 2.7.16
0090|Version de PIP
0091|pip 18.1 from /usr/lib/python2.7/dist-packages/pip (python 2.7)
0092|-- test install --
0093|OK
Les logs du plugin en debug:
0110|[2023-09-23 20:12:15][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0111|[2023-09-23 20:12:15][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0112|[2023-09-23 20:12:17][ERROR] : sendToDaemon: socket_write ERROR: Broken pipe
0113|[2023-09-23 20:12:20][INFO] : deamon_stop: Démon arrêté
0114|[2023-09-23 20:12:20][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0115|[2023-09-23 20:12:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0116|[2023-09-23 20:12:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0117|[2023-09-23 20:12:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0118|[2023-09-23 20:12:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0119|[2023-09-23 20:12:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0120|[2023-09-23 20:12:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0121|[2023-09-23 20:12:39][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0122|[2023-09-23 20:12:39][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0123|[2023-09-23 20:12:44][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0124|[2023-09-23 20:12:44][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0125|[2023-09-23 20:12:49][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0126|[2023-09-23 20:12:49][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0127|[2023-09-23 20:12:55][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0128|[2023-09-23 20:12:55][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0129|[2023-09-23 20:13:01][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0130|[2023-09-23 20:13:01][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0131|[2023-09-23 20:13:07][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0132|[2023-09-23 20:13:07][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0133|[2023-09-23 20:13:12][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0134|[2023-09-23 20:13:12][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0135|[2023-09-23 20:13:18][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0136|[2023-09-23 20:13:18][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0137|[2023-09-23 20:13:24][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0138|[2023-09-23 20:13:24][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0139|[2023-09-23 20:13:29][ERROR] : sendToDaemon: socket_write ERROR: Broken pipe
0140|[2023-09-23 20:13:30][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0141|[2023-09-23 20:13:30][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0142|[2023-09-23 20:13:36][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0143|[2023-09-23 20:13:36][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0144|[2023-09-23 20:13:42][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0145|[2023-09-23 20:13:42][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0146|[2023-09-23 20:13:48][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0147|[2023-09-23 20:13:48][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0148|[2023-09-23 20:13:54][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0149|[2023-09-23 20:13:54][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0150|[2023-09-23 20:14:00][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0151|[2023-09-23 20:14:00][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0152|[2023-09-23 20:14:06][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0153|[2023-09-23 20:14:06][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0154|[2023-09-23 20:14:12][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0155|[2023-09-23 20:14:12][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0156|[2023-09-23 20:14:18][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0157|[2023-09-23 20:14:18][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0158|[2023-09-23 20:14:24][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0159|[2023-09-23 20:14:24][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0160|[2023-09-23 20:14:30][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0161|[2023-09-23 20:14:30][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0162|[2023-09-23 20:14:36][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0163|[2023-09-23 20:14:36][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0164|[2023-09-23 20:14:41][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0165|[2023-09-23 20:14:41][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0166|[2023-09-23 20:14:46][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0167|[2023-09-23 20:14:46][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0168|[2023-09-23 20:14:51][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0169|[2023-09-23 20:14:51][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0170|[2023-09-23 20:14:56][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0171|[2023-09-23 20:14:56][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0172|[2023-09-23 20:15:01][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0173|[2023-09-23 20:15:01][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0174|[2023-09-23 20:15:05][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0175|[2023-09-23 20:15:06][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0176|[2023-09-23 20:15:07][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0177|[2023-09-23 20:15:11][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0178|[2023-09-23 20:15:12][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0179|[2023-09-23 20:15:16][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0180|[2023-09-23 20:15:17][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0181|[2023-09-23 20:15:17][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0182|[2023-09-23 20:15:17][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0183|[2023-09-23 20:15:17][INFO] : deamon_stop: Début
0184|[2023-09-23 20:15:17][DEBUG] : deamon_stop $deamon_state ok
0185|[2023-09-23 20:15:17][INFO] : deamon_stop: Arrêt du démon...
0186|[2023-09-23 20:15:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0187|[2023-09-23 20:15:22][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0188|[2023-09-23 20:15:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0189|[2023-09-23 20:15:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0190|[2023-09-23 20:15:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0191|[2023-09-23 20:15:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0192|[2023-09-23 20:15:39][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0193|[2023-09-23 20:15:39][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0194|[2023-09-23 20:15:45][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0195|[2023-09-23 20:15:45][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0196|[2023-09-23 20:15:51][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0197|[2023-09-23 20:15:51][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0198|[2023-09-23 20:15:57][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0199|[2023-09-23 20:15:57][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0200|[2023-09-23 20:16:03][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0201|[2023-09-23 20:16:03][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0202|[2023-09-23 20:16:09][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0203|[2023-09-23 20:16:09][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0204|[2023-09-23 20:16:15][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0205|[2023-09-23 20:16:15][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0206|[2023-09-23 20:16:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0207|[2023-09-23 20:16:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0208|[2023-09-23 20:16:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0209|[2023-09-23 20:16:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0210|[2023-09-23 20:16:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0211|[2023-09-23 20:16:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0212|[2023-09-23 20:16:39][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0213|[2023-09-23 20:16:39][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0214|[2023-09-23 20:16:45][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0215|[2023-09-23 20:16:45][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0216|[2023-09-23 20:16:51][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0217|[2023-09-23 20:16:51][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0218|[2023-09-23 20:16:57][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0219|[2023-09-23 20:16:57][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0220|[2023-09-23 20:17:03][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0221|[2023-09-23 20:17:03][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0222|[2023-09-23 20:17:09][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0223|[2023-09-23 20:17:09][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0224|[2023-09-23 20:17:15][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0225|[2023-09-23 20:17:15][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0226|[2023-09-23 20:17:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0227|[2023-09-23 20:17:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0228|[2023-09-23 20:17:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0229|[2023-09-23 20:17:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0230|[2023-09-23 20:17:29][ERROR] : sendToDaemon: socket_write ERROR: Broken pipe
0231|[2023-09-23 20:17:32][INFO] : deamon_stop: Démon arrêté
0232|[2023-09-23 20:17:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0233|[2023-09-23 20:17:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0234|[2023-09-23 20:17:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0235|[2023-09-23 20:17:38][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0236|[2023-09-23 20:17:38][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0237|[2023-09-23 20:17:39][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0238|[2023-09-23 20:17:39][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0239|[2023-09-23 20:17:44][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0240|[2023-09-23 20:17:44][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0241|[2023-09-23 20:17:45][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0242|[2023-09-23 20:17:45][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0243|[2023-09-23 20:17:50][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0244|[2023-09-23 20:17:50][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0245|[2023-09-23 20:17:51][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0246|[2023-09-23 20:17:51][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0247|[2023-09-23 20:17:56][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0248|[2023-09-23 20:17:56][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0249|[2023-09-23 20:17:57][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0250|[2023-09-23 20:17:57][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0251|[2023-09-23 20:18:01][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0252|[2023-09-23 20:18:01][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0253|[2023-09-23 20:18:02][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0254|[2023-09-23 20:18:02][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0255|[2023-09-23 20:18:06][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0256|[2023-09-23 20:18:06][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0257|[2023-09-23 20:18:07][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0258|[2023-09-23 20:18:07][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0259|[2023-09-23 20:18:11][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0260|[2023-09-23 20:18:11][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0261|[2023-09-23 20:18:12][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0262|[2023-09-23 20:18:12][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0263|[2023-09-23 20:18:16][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0264|[2023-09-23 20:18:16][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0265|[2023-09-23 20:18:17][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0266|[2023-09-23 20:18:17][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0267|[2023-09-23 20:18:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0268|[2023-09-23 20:18:21][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0269|[2023-09-23 20:18:22][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0270|[2023-09-23 20:18:22][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0271|[2023-09-23 20:18:26][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0272|[2023-09-23 20:18:26][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0273|[2023-09-23 20:18:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0274|[2023-09-23 20:18:27][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0275|[2023-09-23 20:18:31][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0276|[2023-09-23 20:18:31][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0277|[2023-09-23 20:18:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0278|[2023-09-23 20:18:33][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0279|[2023-09-23 20:18:37][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0280|[2023-09-23 20:18:37][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0281|[2023-09-23 20:18:38][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0282|[2023-09-23 20:18:38][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0283|[2023-09-23 20:18:42][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0284|[2023-09-23 20:18:42][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0285|[2023-09-23 20:18:43][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0286|[2023-09-23 20:18:43][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0287|[2023-09-23 20:18:47][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0288|[2023-09-23 20:18:47][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0289|[2023-09-23 20:18:48][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0290|[2023-09-23 20:18:48][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0291|[2023-09-23 20:18:52][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0292|[2023-09-23 20:18:52][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0293|[2023-09-23 20:18:53][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0294|[2023-09-23 20:18:53][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0295|[2023-09-23 20:18:57][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0296|[2023-09-23 20:18:57][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0297|[2023-09-23 20:18:58][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0298|[2023-09-23 20:18:58][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0299|[2023-09-23 20:19:02][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0300|[2023-09-23 20:19:02][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0301|[2023-09-23 20:19:03][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
0302|[2023-09-23 20:19:03][DEBUG] : deamon_info = {"state":"ok","launchable":"ok"}
La page santé de Jeedom n’indique rien de particulier.
