Je n’arrive pas à appairer ma prise Legrand, alors qu’elle est donnée comme compatible.
J’ai passé les log en debug, relancé le demon mais pas de détection.
[2022-03-30 10:02:31]INFO : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device auto --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey yjbU8f4giHmwkbpZ2hnLA0GwTywyLIsi --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller deconz --sub_controller auto --channel 15 --folder_OTA /var/www/html/plugins/zigbee/data/ota
[2022-03-30 10:02:35]DEBUG : null
[2022-03-30 10:02:52]DEBUG : http://127.0.0.1:8089/application/include type : PUT
[2022-03-30 10:02:52]DEBUG : {"duration":180}
[2022-03-30 10:02:53]DEBUG : ""
[2022-03-30 10:04:14]DEBUG : http://127.0.0.1:8089/application/info type : GET
[2022-03-30 10:04:14]DEBUG : null
[2022-03-30 10:04:14]DEBUG : http://127.0.0.1:8089/device/all?with_attributes=0 type : GET
[2022-03-30 10:04:14]DEBUG : http://127.0.0.1:8089/network/map type : GET
[2022-03-30 10:04:15]DEBUG : {"ieee":"00:21:2e:ff:ff:04:23:21","zigpy_version":"0.43.0","zha_version":"0.0.67","nwk":0,"config":{"database_path":"\/var\/www\/html\/plugins\/zigbee\/data\/1\/network_deconz.db","device":{"path":"\/dev\/ttyACM0"},"network":{"channel":15,"extended_pan_id":null,"key":null,"update_id":0,"tc_link_key":"5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39","key_sequence_number":0,"tc_address":null,"channels":34635776,"pan_id":null},"ota":{"otau_directory":"\/var\/www\/html\/plugins\/zigbee\/data\/ota","ikea_provider":true,"ikea_update_url":"http:\/\/fw.ota.homesmart.ikea.net\/feed\/version_info.json","ledvance_provider":true,"salus_provider":false},"topology_scan_period":240,"watchdog_ttl":600,"topology_scan_skip_coordinator":false,"topology_scan_enabled":true},"deconz":{"zigpy_deconz_version":"0.14.0","version":"0x26720700","extendedPanId":"21:23:04:ff:ff:2e:21:00","panId":"0x6cab","radioChannel":15,"nwkUpdateId":"0x0"}}
[2022-03-30 10:04:15]DEBUG : [{"ieee":"00:21:2e:ff:ff:04:23:21","nwk":"0x0000","lqi":null,"rssi":null,"device_type":"Coordinator","manufacturer":"dresden elektronik","model":"RaspBee II","offline":false,"neighbours":[{"ieee":"00:15:8d:00:04:7d:e4:27","nwk":"0xd8a2","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:04:7b:c3:65","nwk":"0xd3b6","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:04:4d:1c:8e","nwk":"0xd39b","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:04:7b:c2:b2","nwk":"0x94f2","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:04:86:ac:d7","nwk":"0x356b","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true}]},{"ieee":"00:15:8d:00:04:4d:1c:8e","nwk":"0xd39b","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:04:86:ac:d7","nwk":"0x356b","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:04:7b:c3:65","nwk":"0xd3b6","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:04:7d:e4:27","nwk":"0xd8a2","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:04:7b:c2:b2","nwk":"0x94f2","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]}]
[2022-03-30 10:04:15]DEBUG : [{"ieee":"00:21:2e:ff:ff:04:23:21","nwk":0,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"10:40:0f:35:11:59:3d:00:40:00:3d:00:00","endpoints":[{"id":1,"status":1,"device_type":5,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[{"id":1,"name":"Power Configuration","attributes":[]},{"id":32,"name":"Poll Control","attributes":[]},{"id":1280,"name":"IAS Zone","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":10,"name":"Time","attributes":[]},{"id":25,"name":"Ota","attributes":[]}]},{"id":242,"status":1,"device_type":100,"profile_id":41440,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[]}],"signature":{"model":"RaspBee II","node_desc":{"logical_type":0,"complex_descriptor_available":0,"user_descriptor_available":1,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":15,"manufacturer_code":4405,"maximum_buffer_size":89,"maximum_incoming_transfer_size":61,"server_mask":64,"maximum_outgoing_transfer_size":61,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":5,"input_clusters":[0,10,25],"output_clusters":[1,32,1280]},"242":{"profile_id":41440,"device_type":100,"input_clusters":[],"output_clusters":[33]}}},"class":"zigpy_deconz.zigbee.application"},{"ieee":"00:15:8d:00:04:4d:1c:8e","nwk":54171,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":24321,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":5},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.8},{"id":33,"name":"battery_percentage_remaining","value":182}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2397}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":981.65}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":2936}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":24321,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:04:86:ac:d7","nwk":13675,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":24321,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":5},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.4},{"id":33,"name":"battery_percentage_remaining","value":161}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2314}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":969}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":3159}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":24321,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:04:7b:c3:65","nwk":54198,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":24321,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":5},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.4},{"id":33,"name":"battery_percentage_remaining","value":161}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2373}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":970}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":2954}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":24321,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:04:7d:e4:27","nwk":55458,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":24321,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":5},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":30.4},{"id":33,"name":"battery_percentage_remaining","value":161}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2471}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":970}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":2761}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":24321,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"},{"ieee":"00:15:8d:00:04:7b:c2:b2","nwk":38130,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"02:40:80:37:10:7f:64:00:00:00:64:00:00","endpoints":[{"id":1,"status":1,"device_type":24321,"profile_id":260,"manufacturer":"LUMI","model":"lumi.weather","output_clusters":[{"id":0,"name":"Basic","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}],"input_clusters":[{"id":0,"name":"BasicCluster","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":5},{"id":2,"name":"stack_version","value":2},{"id":3,"name":"hw_version","value":30},{"id":4,"name":"manufacturer","value":"LUMI"},{"id":5,"name":"model","value":"lumi.weather"},{"id":6,"name":"date_code","value":"20191205"},{"id":7,"name":"power_source","value":3},{"id":16384,"name":"sw_build_id","value":"3000-0001"}]},{"id":1,"name":"Power Configuration","attributes":[{"id":32,"name":"battery_voltage","value":29.6},{"id":33,"name":"battery_percentage_remaining","value":104}]},{"id":3,"name":"Identify","attributes":[]},{"id":1026,"name":"Temperature Measurement","attributes":[{"id":0,"name":"measured_value","value":2768}]},{"id":1027,"name":"Pressure Measurement","attributes":[{"id":0,"name":"measured_value","value":971.13}]},{"id":1029,"name":"Relative Humidity Measurement","attributes":[{"id":0,"name":"measured_value","value":2414}]},{"id":65535,"name":"Manufacturer Specific","attributes":[]}]}],"signature":{"manufacturer":"LUMI","model":"lumi.weather","node_desc":{"logical_type":2,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":128,"manufacturer_code":4151,"maximum_buffer_size":127,"maximum_incoming_transfer_size":100,"server_mask":0,"maximum_outgoing_transfer_size":100,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":24321,"input_clusters":[0,1,3,1026,1027,1029,65535],"output_clusters":[0,4,65535]}}},"class":"zhaquirks.xiaomi.aqara.weather"}]
[2022-03-30 10:04:21]DEBUG : http://127.0.0.1:8089/network/map type : GET
[2022-03-30 10:04:21]DEBUG : null
[2022-03-30 10:04:21]DEBUG : [{"ieee":"00:21:2e:ff:ff:04:23:21","nwk":"0x0000","lqi":null,"rssi":null,"device_type":"Coordinator","manufacturer":"dresden elektronik","model":"RaspBee II","offline":false,"neighbours":[{"ieee":"00:15:8d:00:04:7d:e4:27","nwk":"0xd8a2","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:04:7b:c3:65","nwk":"0xd3b6","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:04:4d:1c:8e","nwk":"0xd39b","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:04:7b:c2:b2","nwk":"0x94f2","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true},{"ieee":"00:15:8d:00:04:86:ac:d7","nwk":"0x356b","lqi":252,"rssi":null,"pan_id":"00:21:2e:ff:ff:04:23:21","device_type":"EndDevice","rx_on_when_idle":"Off","relation":"Child","new_joins_accepted":"NotAccepting","depth":1,"model":"lumi.weather","manufacturer":"LUMI","offline":false,"supported":true}]},{"ieee":"00:15:8d:00:04:4d:1c:8e","nwk":"0xd39b","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:04:86:ac:d7","nwk":"0x356b","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:04:7b:c3:65","nwk":"0xd3b6","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:04:7d:e4:27","nwk":"0xd8a2","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]},{"ieee":"00:15:8d:00:04:7b:c2:b2","nwk":"0x94f2","lqi":null,"rssi":null,"device_type":"EndDevice","manufacturer":"LUMI","model":"lumi.weather","offline":false,"neighbours":[]}]
[2022-03-30 10:07:01]DEBUG : {"devices":{"00:15:8d:00:04:7b:c2:b2":{"1":{"1026":[{"value":"2765","cluster_name":"Temperature Measurement"}],"1029":[{"value":"2428","cluster_name":"Relative Humidity Measurement"}],"1027":[{"value":"970","cluster_name":"Pressure Measurement"}]}}}}
[2022-03-30 10:07:01]DEBUG : Search attribut for 00:15:8d:00:04:7b:c2:b2 logicalId : 1::1026::0 => 2765 convert to 2765
[2022-03-30 10:07:01]DEBUG : Search attribut for 00:15:8d:00:04:7b:c2:b2 logicalId : 1::1029::0 => 2428 convert to 2428
[2022-03-30 10:07:01]DEBUG : Search attribut for 00:15:8d:00:04:7b:c2:b2 logicalId : 1::1027::0 => 970 convert to 970
[2022-03-30 10:07:05]DEBUG : {"devices":{"00:15:8d:00:04:4d:1c:8e":{"1":{"1026":[{"value":"2428","cluster_name":"Temperature Measurement"}],"1029":[{"value":"2955","cluster_name":"Relative Humidity Measurement"}],"1027":[{"value":"981","cluster_name":"Pressure Measurement"}]}}}}
[2022-03-30 10:07:05]DEBUG : Search attribut for 00:15:8d:00:04:4d:1c:8e logicalId : 1::1026::0 => 2428 convert to 2428
[2022-03-30 10:07:05]DEBUG : Search attribut for 00:15:8d:00:04:4d:1c:8e logicalId : 1::1029::0 => 2955 convert to 2955
[2022-03-30 10:07:06]DEBUG : Search attribut for 00:15:8d:00:04:4d:1c:8e logicalId : 1::1027::0 => 981 convert to 981
Le plugin fonctionne sans soucis pour mes températures (Combee II)
Avez-vous une idée pour avancer ?
Pas de changement après redémarrage de la box.
