Apc ne remonte plus le statut de l’onduleur
j’ai effectuer la migration de mon rpi 3 jeedom v3 > v4
j’ai pas eu trop de soucis
mis a part pour le plugin apc qui me remonte plu le status de l’onduleur !
bien sûr j’ai cherché comment résoudre sur le forum et le community : rien trouvé d’equivanlent
j’ai essayer de désinstaller/reinstaller : rien de neuf
pour infos :
en ssh quand je fais :
sudo apcaccess status
APC      : 001,018,0451
DATE     : 2020-02-29 10:20:56 +0100
HOSTNAME : KiJeedom4
VERSION  : 3.14.14 (31 May 2016) debian
UPSNAME  : jeedom UPS_IDEN
CABLE    : USB Cable
DRIVER   : USB UPS Driver
UPSMODE  : Stand Alone
STARTTIME: 2020-02-29 10:20:29 +0100
STATUS   : COMMLOST
MBATTCHG : 5 Percent
MINTIMEL : 3 Minutes
MAXTIME  : 0 Seconds
NUMXFERS : 0
TONBATT  : 0 Seconds
CUMONBATT: 0 Seconds
XOFFBATT : N/A
STATFLAG : 0x05000100
END APC  : 2020-02-29 11:02:44 +0100
et avec cette commande:
sudo /etc/init.d/apcupsd status
* apcupsd.service - UPS power management daemon
   Loaded: loaded (/lib/systemd/system/apcupsd.service; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2020-02-29 10:20:29 CET; 33min ago
     Docs: man:apcupsd(8)
  Process: 20509 ExecStartPre=/lib/apcupsd/prestart (code=exited, status=0/SUCCESS)
  Process: 20515 ExecStart=/sbin/apcupsd (code=exited, status=0/SUCCESS)
 Main PID: 20516 (apcupsd)
    Tasks: 4 (limit: 2319)
   Memory: 1.2M
   CGroup: /system.slice/apcupsd.service
           `-20516 /sbin/apcupsd
Feb 29 10:20:29 KiJeedom4 systemd[1]: Starting UPS power management daemon...
Feb 29 10:20:29 KiJeedom4 systemd[1]: apcupsd.service: Can't open PID file /run/apcupsd.pid (yet?) after start: No such file or directory
Feb 29 10:20:29 KiJeedom4 apcupsd[20516]: apcupsd 3.14.14 (31 May 2016) debian startup succeeded
Feb 29 10:20:29 KiJeedom4 apcupsd[20516]: NIS server startup succeeded
Feb 29 10:20:29 KiJeedom4 systemd[1]: Started UPS power management daemon.
Feb 29 10:21:39 KiJeedom4 apcupsd[20516]: Communications with UPS lost.
Feb 29 10:31:39 KiJeedom4 apcupsd[20516]: Communications with UPS lost.
Feb 29 10:41:39 KiJeedom4 apcupsd[20516]: Communications with UPS lost.
Feb 29 10:51:40 KiJeedom4 apcupsd[20516]: Communications with UPS lost.
j’ai la ligne : apcupsd.service: Can’t open PID file /run/apcupsd.pid (yet?) after start: No such file or directory
qui me parait être le problème mais comment le règler :confused:
Merci de votre aide
Bonjour personne peut m’aider ? pour mon problème ci-dessus !
Je suis en v3 et j’ai exactement le même problème.
Perso je ne peux même plus enlever le plugin- → 500 : Internal Server Error
On peut avoir une copie d’écran de la page santé pour vous 2?
Voila ce que j’ai dans le log :
Dans ma console debian en tapant apcacess statut :
et mon widget :
Donc tu n’as pas du tout le même problème contrairement à ce que tu disais: le statut remonte bien dans apcaccess, tu n’as pas de commlost. Merci de créer un autre sujet si besoin
Comment as tu migré raspbian ? Nouvelle install ou upgrade?
As tu réinstallé les dépendances ? Peut on voir le log ?
Pour la migration j’ai pris une image neuve de Rasbian en buster j’ai restauré une backup de v3 puis basculé sur la V4 de Jeedom et réinstallé les dépendances !
je vous envoi les logs que je trouve dans mon prochain post
voila les log du plugin:
apcups_dep.log (229 Octets) apcups.log (17,2 Ko)
Voici la page santé :
Tout à l’air installé, soit un problème de cable ou de port usb?
as-tu essayé via un hub?
éteindre et redémarrer l’onduleur peut aider aussi parfois
le cable n’as pas changer depuis la MAJ donc peut de risque que cela le problème je vais tenté de redémarré l’onduleur
J’ai tenter de redémarré l’onduleur
ça n’as rien changé :confused:
le cable usb était branché (depuis toujours) sur un port usb du pi
j’ai tenté sur le hub usb mais rien de plus
mais il me semble que sur le forum (ici) j’ai vu qq qui avais un soucis avec son APC suite au passage au ssd
choses que j’ai fait aussi dans la foulé suite a ma migration V3>V4
donc je vais creuser
J’ai effectivement eu un problème avec mon onduleur APC 700 lors du passage en SSD.
C’est enfin fonctionnel avec mon SSD en faisant les manipulations ci-dessous.
  1. Tout éteint même onduleur avec prise courant débranchée et voyant devant éteint
  2. j’ai enlevé le SSD et remis ma carte SD jeedom V3
  3. redémarré avec ma V3 qui était fonctionnelle = j’ai retrouvé les valeurs de l’APC
  4. éteint le RPI + enlevé la SD + rebrancher le SSD sur le même port USB que précédemment.
    → Miracle les valeurs APC remontent !!
    Par contre pas d’explication !
    A ta dispo
    Stéphane
C’est good j’ai trouver j’ai mis ma cle bluetooth (pour mon BLEA) sur le hub et l’APC est réapparu
Super
Content pour toi :grin:
