depuis quelques temps, peut être une mise à jour, j’ai pas fait attention, mon antenne locale fonctionne bien et les antennes déportées ne voient pas les device : eg. rssi à 200 dans mqtt discovery
Voici le logs de l’update et d’une antenne déportée
[2023-12-19 06:31:50] *************************************
[2023-12-19 06:31:50] * Launch install of dependencies *
[2023-12-19 06:31:51] Reading package lists...
[2023-12-19 06:31:52] Building dependency tree...
[2023-12-19 06:31:52] Reading state information...
[2023-12-19 06:31:53] curl is already the newest version (7.74.0-1.3+deb11u10).
[2023-12-19 06:31:53] 0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
100 2 100 2 0 0 1 0 0:00:02 0:00:01 0:00:01 1
[2023-12-19 06:31:56] Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
[2023-12-19 06:31:56] Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
[2023-12-19 06:31:56] Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [313 kB]
[2023-12-19 06:31:57] Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main Sources [12.2 MB]
[2023-12-19 06:32:27] Get:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
[2023-12-19 06:33:06] Fetched 25.8 MB in 1min 10s (370 kB/s)
[2023-12-19 06:33:12] Reading package lists...
[2023-12-19 06:33:12] *****************************
[2023-12-19 06:33:12] Install modules using apt-get
[2023-12-19 06:33:14] Reading package lists...
[2023-12-19 06:33:15] Building dependency tree...
[2023-12-19 06:33:15] Reading state information...
[2023-12-19 06:33:17] logrotate is already the newest version (3.18.0-2+deb11u2).
[2023-12-19 06:33:17] python3 is already the newest version (3.9.2-3).
[2023-12-19 06:33:17] python3-venv is already the newest version (3.9.2-3).
[2023-12-19 06:33:17] bluez is already the newest version (5.55-3.1+rpt2).
[2023-12-19 06:33:17] python3-pip is already the newest version (20.3.4-4+rpt1+deb11u1).
[2023-12-19 06:33:17] 0 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
[2023-12-19 06:33:18] Version debian:11
[2023-12-19 06:33:19] Install pipx via pip
[2023-12-19 06:33:24] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2023-12-19 06:33:24] Requirement already satisfied: pipx in /usr/local/lib/python3.9/dist-packages (1.2.1)
[2023-12-19 06:33:25] Requirement already satisfied: userpath>=1.6.0 in /usr/local/lib/python3.9/dist-packages (from pipx) (1.9.1)
[2023-12-19 06:33:25] Requirement already satisfied: packaging>=20.0 in /usr/local/lib/python3.9/dist-packages (from pipx) (21.3)
[2023-12-19 06:33:25] Requirement already satisfied: argcomplete>=1.9.4 in /usr/local/lib/python3.9/dist-packages (from pipx) (3.1.6)
[2023-12-19 06:33:25] Requirement already satisfied: pyparsing!=3.0.5,>=2.0.2 in /usr/local/lib/python3.9/dist-packages (from packaging>=20.0->pipx) (3.0.7)
[2023-12-19 06:33:25] Requirement already satisfied: click in /usr/local/lib/python3.9/dist-packages (from userpath>=1.6.0->pipx) (8.0.4)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
WARNING: You are using pip version 22.0.4; however, version 23.3.2 is available.
You should consider upgrading via the '/usr/bin/python3 -m pip install --upgrade pip' command.
[2023-12-19 06:33:32] /root/.local/bin has been been added to PATH, but you need to open a new
[2023-12-19 06:33:32] terminal or re-login for this PATH change to take effect.
[2023-12-19 06:33:32] You will need to open a new terminal or re-login for the PATH changes to take
[2023-12-19 06:33:32] effect.
[2023-12-19 06:33:32] Otherwise pipx is ready to go! ✨ 🌟 ✨
[2023-12-19 06:33:32] *************************************
[2023-12-19 06:33:32] Install the required python libraries
[2023-12-19 06:33:35] 'theengsgateway' already seems to be installed. Not modifying existing
[2023-12-19 06:33:35] installation in '/root/.local/pipx/venvs/theengsgateway'. Pass '--force' to
[2023-12-19 06:33:35] force installation.
[2023-12-19 06:33:35] ***************************
[2023-12-19 06:33:35] * Install ended *
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:04 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0
Accueil
Analyse
Outils
Plugins
Réglages
19:42:53
Maison
Gestion
Ajouter
Configuration
Documentation
Community
Mes antennes
Bureau
BLEA Local
Chambre
BLEA Chambre
Salon
BLEA Salon
Configuration du plugin
Theengs Gateway (tgw) - stable
Etat
Statut
Action
Catégorie
Programmation
Source
market
Auteur
Mips
Version
2023-12-16 01:20:38
License
AGPL
Prérequis
4.2.0
Logs et surveillance
Niveau log
Aucun Defaut Debug Info Warning Error
Logs
Heartbeat (min)
Configuration
Configuration utilisée pour les antennes
Authentification
Fonctionnalités
interact
Non
cron
Oui
Activer
cron5
Non
cron10
Non
cron15
Non
cron30
Non
cronHourly
Non
cronDaily
Non
deadcmd
Non
health
Oui
Log du plugin tgw_1030
Log brut
ERROR:BLEGateway:Connection error
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/TheengsGateway/ble_gateway.py", line 111, in connect_mqtt
self.client.connect(self.broker, self.port)
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 914, in connect
return self.reconnect()
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 1044, in reconnect
sock = self._create_socket_connection()
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File "/usr/lib/python3.9/socket.py", line 843, in create_connection
raise err
File "/usr/lib/python3.9/socket.py", line 831, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network is unreachable
ERROR:root:A message handler raised an exception: Invalid control character at: line 1 column 82 (char 81)
File "src/dbus_fast/message_bus.py", line 789, in dbus_fast.message_bus.BaseMessageBus._process_message
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/bleak/backends/bluezdbus/manager.py", line 979, in _parse_msg
self._run_advertisement_callbacks(
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/bleak/backends/bluezdbus/manager.py", line 1028, in _run_advertisement_callbacks
callback(device_path, device.copy())
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/bleak/backends/bluezdbus/scanner.py", line 270, in _handle_advertising_data
self.call_detection_callbacks(device, advertisement_data)
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/bleak/backends/scanner.py", line 210, in call_detection_callbacks
callback(device, advertisement_data)
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.9/site-packages/TheengsGateway/ble_gateway.py", line 350, in detection_callback
decoded_json = json.loads(decoded_json)
File "/usr/lib/python3.9/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.9/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.9/json/decoder.py", line 353, in raw_decode
obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Invalid control character at: line 1 column 82 (char 81)
Jeedom stable 4.3.21
Merci d’avance
