Je possède 2 antennes Raspberry PI.
Les 2 ont un utilisateur qui ne tape pas le mdp en sudo.
Elles tournent sous Debian11 à jour.
J’utilise le BT interne.
Le statut de l’installation est OK, le service en ligne.
Mais je n’ai aucune configuration du service.
ERROR:BLEGateway:Disconnected from MQTT broker with reason code = Keep alive timeout
ERROR:BLEGateway:Connection error
File "/opt/TheengsGateway/lib/python3.9/site-packages/TheengsGateway/ble_gateway.py", line 208, in connect_mqtt
self.client.connect(
File "/opt/TheengsGateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 1435, in connect
return self.reconnect()
File "/opt/TheengsGateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 1598, in reconnect
self._sock = self._create_socket()
File "/opt/TheengsGateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 4609, in _create_socket
sock = self._create_socket_connection()
File "/opt/TheengsGateway/lib/python3.9/site-packages/paho/mqtt/client.py", line 4640, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File "/usr/lib/python3.9/socket.py", line 843, in create_connection
raise err
File "/usr/lib/python3.9/socket.py", line 831, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network is unreachable
ERROR:BLEGateway:[org.bluez.Error.Failed] No discovery started
ERROR:BLEGateway:Disconnected from MQTT broker with reason code = Unspecified error
raise err
sock.connect(sa)
Le update :
[2024-09-15 18:33:56] *************************************
[2024-09-15 18:33:56] * Launch install of dependencies *
[2024-09-15 18:33:56] == Version Debian:11
[2024-09-15 18:33:56] == Version Python:3.9.2
[2024-09-15 18:34:04] Reading package lists...
[2024-09-15 18:34:06] Building dependency tree...
[2024-09-15 18:34:06] Reading state information...
[2024-09-15 18:34:09] curl is already the newest version (7.74.0-1.3+deb11u12).
[2024-09-15 18:34:09] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 2 100 2 0 0 4 0 --:--:-- --:--:-- --:--:-- 4
[2024-09-15 18:34:15] Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [39.0 kB]
[2024-09-15 18:34:15] Get:2 http://security.debian.org/debian-security bullseye-security InRelease [27.2 kB]
[2024-09-15 18:34:15] Get:3 http://deb.debian.org/debian bullseye InRelease [116 kB]
[2024-09-15 18:34:16] Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
[2024-09-15 18:34:16] Get:5 http://security.debian.org/debian-security bullseye-security/main armhf Packages [283 kB]
[2024-09-15 18:34:16] Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [285 kB]
[2024-09-15 18:34:16] Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [186 kB]
[2024-09-15 18:34:17] Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [326 kB]
[2024-09-15 18:34:17] Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [318 kB]
[2024-09-15 18:34:17] Get:10 http://deb.debian.org/debian bullseye/main arm64 Packages [7,955 kB]
[2024-09-15 18:34:20] Get:11 http://deb.debian.org/debian bullseye/main armhf Packages [7,841 kB]
[2024-09-15 18:34:21] Get:12 http://deb.debian.org/debian bullseye/main Translation-en [6,235 kB]
[2024-09-15 18:34:23] Get:13 http://deb.debian.org/debian bullseye/non-free arm64 Packages [72.4 kB]
[2024-09-15 18:34:23] Get:14 http://deb.debian.org/debian bullseye/non-free Translation-en [92.5 kB]
[2024-09-15 18:34:37] Fetched 23.8 MB in 20s (1,181 kB/s)
[2024-09-15 18:34:43] Reading package lists...
[2024-09-15 18:34:43] ********************************
[2024-09-15 18:34:43] * Install dependencies & venv *
100 2 100 2 0 0 5 0 --:--:-- --:--:-- --:--:-- 5
[2024-09-15 18:34:44] Reading package lists...
[2024-09-15 18:34:45] Building dependency tree...
[2024-09-15 18:34:46] Reading state information...
[2024-09-15 18:34:47] logrotate is already the newest version (3.18.0-2+deb11u2).
[2024-09-15 18:34:47] python3 is already the newest version (3.9.2-3).
[2024-09-15 18:34:47] python3 set to manually installed.
[2024-09-15 18:34:47] The following additional packages will be installed:
[2024-09-15 18:34:47] javascript-common libexpat1-dev libjs-jquery libjs-sphinxdoc
[2024-09-15 18:34:47] libjs-underscore libpython3-dev libpython3.9-dev python-pip-whl python3-dev
[2024-09-15 18:34:47] python3-distutils python3-lib2to3 python3-pkg-resources python3-setuptools
[2024-09-15 18:34:47] python3-wheel python3.9-dev python3.9-venv
[2024-09-15 18:34:47] Suggested packages:
[2024-09-15 18:34:47] apache2 | lighttpd | httpd python-setuptools-doc
[2024-09-15 18:34:48] The following NEW packages will be installed:
[2024-09-15 18:34:48] javascript-common libexpat1-dev libjs-jquery libjs-sphinxdoc
[2024-09-15 18:34:48] libjs-underscore libpython3-dev libpython3.9-dev python-pip-whl python3-dev
[2024-09-15 18:34:48] python3-distutils python3-lib2to3 python3-pip python3-setuptools
[2024-09-15 18:34:48] python3-venv python3-wheel python3.9-dev python3.9-venv
[2024-09-15 18:34:48] The following packages will be upgraded:
[2024-09-15 18:34:48] python3-pkg-resources
[2024-09-15 18:34:48] 1 upgraded, 17 newly installed, 0 to remove and 33 not upgraded.
[2024-09-15 18:34:48] Need to get 8,220 kB of archives.
[2024-09-15 18:34:48] After this operation, 27.8 MB of additional disk space will be used.
[2024-09-15 18:34:48] Get:1 http://archive.raspberrypi.org/debian bullseye/main arm64 python-pip-whl all 20.3.4-4+rpt1+deb11u1 [2,002 kB]
[2024-09-15 18:34:48] Get:2 http://security.debian.org/debian-security bullseye-security/main arm64 python3-pkg-resources all 52.0.0-4+deb11u1 [190 kB]
[2024-09-15 18:34:48] Get:3 http://deb.debian.org/debian bullseye/main arm64 javascript-common all 11+nmu1 [6,260 B]
[2024-09-15 18:34:48] Get:4 http://deb.debian.org/debian bullseye/main arm64 libexpat1-dev arm64 2.2.10-2+deb11u5 [128 kB]
[2024-09-15 18:34:48] Get:5 http://deb.debian.org/debian bullseye/main arm64 libjs-jquery all 3.5.1+dfsg+~3.5.5-7 [315 kB]
[2024-09-15 18:34:48] Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 python3-setuptools all 52.0.0-4+deb11u1 [367 kB]
[2024-09-15 18:34:48] Get:7 http://deb.debian.org/debian bullseye/main arm64 libjs-underscore all 1.9.1~dfsg-3 [100 kB]
[2024-09-15 18:34:49] Get:8 http://deb.debian.org/debian bullseye/main arm64 libjs-sphinxdoc all 3.4.3-2 [127 kB]
[2024-09-15 18:34:49] Get:9 http://deb.debian.org/debian bullseye/main arm64 libpython3.9-dev arm64 3.9.2-1 [3,835 kB]
[2024-09-15 18:34:49] Get:10 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-pip all 20.3.4-4+rpt1+deb11u1 [337 kB]
[2024-09-15 18:34:50] Get:11 http://deb.debian.org/debian bullseye/main arm64 libpython3-dev arm64 3.9.2-3 [21.7 kB]
[2024-09-15 18:34:50] Get:12 http://deb.debian.org/debian bullseye/main arm64 python3.9-dev arm64 3.9.2-1 [515 kB]
[2024-09-15 18:34:50] Get:13 http://deb.debian.org/debian bullseye/main arm64 python3-lib2to3 all 3.9.2-1 [77.8 kB]
[2024-09-15 18:34:50] Get:14 http://deb.debian.org/debian bullseye/main arm64 python3-distutils all 3.9.2-1 [143 kB]
[2024-09-15 18:34:50] Get:15 http://deb.debian.org/debian bullseye/main arm64 python3-dev arm64 3.9.2-3 [24.8 kB]
[2024-09-15 18:34:50] Get:16 http://deb.debian.org/debian bullseye/main arm64 python3-wheel all 0.34.2-1 [24.0 kB]
[2024-09-15 18:34:50] Get:17 http://deb.debian.org/debian bullseye/main arm64 python3.9-venv arm64 3.9.2-1 [5,396 B]
[2024-09-15 18:34:50] Get:18 http://deb.debian.org/debian bullseye/main arm64 python3-venv arm64 3.9.2-3 [1,188 B]
[2024-09-15 18:34:56] apt-listchanges: Reading changelogs...
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
[2024-09-15 18:34:57] Fetched 8,220 kB in 2s (3,594 kB/s)
[2024-09-15 18:34:57] Selecting previously unselected package javascript-common.
[2024-09-15 18:34:58] (Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 37781 files and directories currently installed.)
[2024-09-15 18:34:58] Preparing to unpack .../00-javascript-common_11+nmu1_all.deb ...
[2024-09-15 18:34:58] Unpacking javascript-common (11+nmu1) ...
[2024-09-15 18:34:58] Selecting previously unselected package libexpat1-dev:arm64.
[2024-09-15 18:34:58] Preparing to unpack .../01-libexpat1-dev_2.2.10-2+deb11u5_arm64.deb ...
[2024-09-15 18:34:58] Unpacking libexpat1-dev:arm64 (2.2.10-2+deb11u5) ...
[2024-09-15 18:34:58] Selecting previously unselected package libjs-jquery.
[2024-09-15 18:34:58] Preparing to unpack .../02-libjs-jquery_3.5.1+dfsg+~3.5.5-7_all.deb ...
[2024-09-15 18:34:58] Unpacking libjs-jquery (3.5.1+dfsg+~3.5.5-7) ...
[2024-09-15 18:34:58] Selecting previously unselected package libjs-underscore.
[2024-09-15 18:34:58] Preparing to unpack .../03-libjs-underscore_1.9.1~dfsg-3_all.deb ...
[2024-09-15 18:34:58] Unpacking libjs-underscore (1.9.1~dfsg-3) ...
[2024-09-15 18:34:59] Selecting previously unselected package libjs-sphinxdoc.
[2024-09-15 18:34:59] Preparing to unpack .../04-libjs-sphinxdoc_3.4.3-2_all.deb ...
[2024-09-15 18:34:59] Unpacking libjs-sphinxdoc (3.4.3-2) ...
[2024-09-15 18:34:59] Selecting previously unselected package libpython3.9-dev:arm64.
[2024-09-15 18:34:59] Preparing to unpack .../05-libpython3.9-dev_3.9.2-1_arm64.deb ...
[2024-09-15 18:34:59] Unpacking libpython3.9-dev:arm64 (3.9.2-1) ...
[2024-09-15 18:35:01] Selecting previously unselected package libpython3-dev:arm64.
[2024-09-15 18:35:01] Preparing to unpack .../06-libpython3-dev_3.9.2-3_arm64.deb ...
[2024-09-15 18:35:01] Unpacking libpython3-dev:arm64 (3.9.2-3) ...
[2024-09-15 18:35:01] Selecting previously unselected package python-pip-whl.
[2024-09-15 18:35:01] Preparing to unpack .../07-python-pip-whl_20.3.4-4+rpt1+deb11u1_all.deb ...
[2024-09-15 18:35:01] Unpacking python-pip-whl (20.3.4-4+rpt1+deb11u1) ...
[2024-09-15 18:35:02] Selecting previously unselected package python3.9-dev.
[2024-09-15 18:35:02] Preparing to unpack .../08-python3.9-dev_3.9.2-1_arm64.deb ...
[2024-09-15 18:35:02] Unpacking python3.9-dev (3.9.2-1) ...
[2024-09-15 18:35:02] Selecting previously unselected package python3-lib2to3.
[2024-09-15 18:35:02] Preparing to unpack .../09-python3-lib2to3_3.9.2-1_all.deb ...
[2024-09-15 18:35:02] Unpacking python3-lib2to3 (3.9.2-1) ...
[2024-09-15 18:35:02] Selecting previously unselected package python3-distutils.
[2024-09-15 18:35:02] Preparing to unpack .../10-python3-distutils_3.9.2-1_all.deb ...
[2024-09-15 18:35:02] Unpacking python3-distutils (3.9.2-1) ...
[2024-09-15 18:35:03] Selecting previously unselected package python3-dev.
[2024-09-15 18:35:03] Preparing to unpack .../11-python3-dev_3.9.2-3_arm64.deb ...
[2024-09-15 18:35:03] Unpacking python3-dev (3.9.2-3) ...
[2024-09-15 18:35:03] Preparing to unpack .../12-python3-pkg-resources_52.0.0-4+deb11u1_all.deb ...
[2024-09-15 18:35:03] Unpacking python3-pkg-resources (52.0.0-4+deb11u1) over (52.0.0-4) ...
[2024-09-15 18:35:04] Selecting previously unselected package python3-setuptools.
[2024-09-15 18:35:04] Preparing to unpack .../13-python3-setuptools_52.0.0-4+deb11u1_all.deb ...
[2024-09-15 18:35:04] Unpacking python3-setuptools (52.0.0-4+deb11u1) ...
[2024-09-15 18:35:04] Selecting previously unselected package python3-wheel.
[2024-09-15 18:35:04] Preparing to unpack .../14-python3-wheel_0.34.2-1_all.deb ...
[2024-09-15 18:35:04] Unpacking python3-wheel (0.34.2-1) ...
[2024-09-15 18:35:04] Selecting previously unselected package python3-pip.
[2024-09-15 18:35:04] Preparing to unpack .../15-python3-pip_20.3.4-4+rpt1+deb11u1_all.deb ...
[2024-09-15 18:35:04] Unpacking python3-pip (20.3.4-4+rpt1+deb11u1) ...
[2024-09-15 18:35:05] Selecting previously unselected package python3.9-venv.
[2024-09-15 18:35:05] Preparing to unpack .../16-python3.9-venv_3.9.2-1_arm64.deb ...
[2024-09-15 18:35:05] Unpacking python3.9-venv (3.9.2-1) ...
[2024-09-15 18:35:05] Selecting previously unselected package python3-venv.
[2024-09-15 18:35:05] Preparing to unpack .../17-python3-venv_3.9.2-3_arm64.deb ...
[2024-09-15 18:35:05] Unpacking python3-venv (3.9.2-3) ...
[2024-09-15 18:35:05] Setting up python3-pkg-resources (52.0.0-4+deb11u1) ...
[2024-09-15 18:35:06] Setting up javascript-common (11+nmu1) ...
[2024-09-15 18:35:07] Setting up python3-wheel (0.34.2-1) ...
[2024-09-15 18:35:08] Setting up libexpat1-dev:arm64 (2.2.10-2+deb11u5) ...
[2024-09-15 18:35:08] Setting up python-pip-whl (20.3.4-4+rpt1+deb11u1) ...
[2024-09-15 18:35:08] Setting up libjs-jquery (3.5.1+dfsg+~3.5.5-7) ...
[2024-09-15 18:35:08] Setting up python3-lib2to3 (3.9.2-1) ...
[2024-09-15 18:35:08] Setting up libjs-underscore (1.9.1~dfsg-3) ...
[2024-09-15 18:35:08] Setting up python3-distutils (3.9.2-1) ...
[2024-09-15 18:35:09] Setting up python3-setuptools (52.0.0-4+deb11u1) ...
[2024-09-15 18:35:11] Setting up libpython3.9-dev:arm64 (3.9.2-1) ...
[2024-09-15 18:35:11] Setting up python3-pip (20.3.4-4+rpt1+deb11u1) ...
[2024-09-15 18:35:13] Setting up libjs-sphinxdoc (3.4.3-2) ...
[2024-09-15 18:35:13] Setting up python3.9-dev (3.9.2-1) ...
[2024-09-15 18:35:13] Setting up python3.9-venv (3.9.2-1) ...
[2024-09-15 18:35:14] Setting up libpython3-dev:arm64 (3.9.2-3) ...
[2024-09-15 18:35:14] Setting up python3-venv (3.9.2-3) ...
[2024-09-15 18:35:14] Setting up python3-dev (3.9.2-3) ...
[2024-09-15 18:35:14] Processing triggers for man-db (2.9.4-2) ...
[2024-09-15 18:35:16] Reading package lists...
[2024-09-15 18:35:17] Building dependency tree...
[2024-09-15 18:35:17] Reading state information...
[2024-09-15 18:35:20] 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 33 not upgraded.
[2024-09-15 18:35:20] Need to get 1,038 kB of archives.
[2024-09-15 18:35:20] After this operation, 0 B of additional disk space will be used.
[2024-09-15 18:35:20] Get:1 http://archive.raspberrypi.org/debian bullseye/main arm64 bluez arm64 5.55-3.1+rpt2+deb11u1 [1,038 kB]
[2024-09-15 18:35:22] Fetched 1,038 kB in 0s (2,194 kB/s)
[2024-09-15 18:35:23] (Reading database ...
(Reading database ... 38662 files and directories currently installed.)
[2024-09-15 18:35:23] Preparing to unpack .../bluez_5.55-3.1+rpt2+deb11u1_arm64.deb ...
[2024-09-15 18:35:23] Unpacking bluez (5.55-3.1+rpt2+deb11u1) over (5.55-3.1+rpt2+deb11u1) ...
[2024-09-15 18:35:24] Setting up bluez (5.55-3.1+rpt2+deb11u1) ...
[2024-09-15 18:35:28] Processing triggers for man-db (2.9.4-2) ...
[2024-09-15 18:35:29] Processing triggers for dbus (1.12.28-0+deb11u1) ...
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pip in /opt/TheengsGateway/lib/python3.9/site-packages (20.3.4)
Collecting pip
Downloading https://www.piwheels.org/simple/pip/pip-24.2-py3-none-any.whl (1.8 MB)
Requirement already satisfied: setuptools in /opt/TheengsGateway/lib/python3.9/site-packages (44.1.1)
Collecting setuptools
Downloading setuptools-75.0.0-py3-none-any.whl (1.2 MB)
Installing collected packages: setuptools, pip
Attempting uninstall: setuptools
Found existing installation: setuptools 44.1.1
Uninstalling setuptools-44.1.1:
Successfully uninstalled setuptools-44.1.1
Attempting uninstall: pip
Found existing installation: pip 20.3.4
Uninstalling pip-20.3.4:
Successfully uninstalled pip-20.3.4
Successfully installed pip-24.2 setuptools-75.0.0
[2024-09-15 18:36:25] ****************************
[2024-09-15 18:36:25] * Install TheengsGateway *
[2024-09-15 18:36:28] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
[2024-09-15 18:36:28] Collecting TheengsGateway
[2024-09-15 18:36:28] Downloading https://www.piwheels.org/simple/theengsgateway/TheengsGateway-1.5.0-py3-none-any.whl (33 kB)
[2024-09-15 18:36:29] Collecting bleak>=0.19.0 (from TheengsGateway)
[2024-09-15 18:36:29] Downloading https://www.piwheels.org/simple/bleak/bleak-0.22.2-py3-none-any.whl (142 kB)
[2024-09-15 18:36:29] Collecting bluetooth-clocks<1.0 (from TheengsGateway)
[2024-09-15 18:36:29] Downloading https://www.piwheels.org/simple/bluetooth-clocks/bluetooth_clocks-0.2.0-py3-none-any.whl (20 kB)
[2024-09-15 18:36:30] Collecting bluetooth-numbers<2.0,>=1.0 (from TheengsGateway)
[2024-09-15 18:36:30] Downloading https://www.piwheels.org/simple/bluetooth-numbers/bluetooth_numbers-1.1.2-py3-none-any.whl (500 kB)
[2024-09-15 18:36:31] Collecting importlib-metadata (from TheengsGateway)
[2024-09-15 18:36:31] Downloading https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-8.5.0-py3-none-any.whl (26 kB)
[2024-09-15 18:36:31] Collecting paho-mqtt<3.0.0,>=2.0.0 (from TheengsGateway)
[2024-09-15 18:36:31] Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-2.1.0-py3-none-any.whl (67 kB)
[2024-09-15 18:36:33] Collecting pycryptodomex>=3.18.0 (from TheengsGateway)
[2024-09-15 18:36:33] Downloading pycryptodomex-3.20.0-cp35-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (3.4 kB)
[2024-09-15 18:36:33] Collecting TheengsDecoder>=1.7.8 (from TheengsGateway)
[2024-09-15 18:36:33] Downloading TheengsDecoder-1.7.8.tar.gz (300 kB)
[2024-09-15 18:36:34] Installing build dependencies: started
[2024-09-15 18:37:10] Installing build dependencies: finished with status 'done'
[2024-09-15 18:37:10] Getting requirements to build wheel: started
[2024-09-15 18:37:12] Getting requirements to build wheel: finished with status 'done'
[2024-09-15 18:37:12] Installing backend dependencies: started
[2024-09-15 18:37:28] Installing backend dependencies: finished with status 'done'
[2024-09-15 18:37:28] Preparing metadata (pyproject.toml): started
[2024-09-15 18:37:31] Preparing metadata (pyproject.toml): finished with status 'done'
[2024-09-15 18:37:31] Collecting bluetooth-adapters>=0.15.3 (from TheengsGateway)
[2024-09-15 18:37:31] Downloading https://www.piwheels.org/simple/bluetooth-adapters/bluetooth_adapters-0.19.4-py3-none-any.whl (19 kB)
[2024-09-15 18:37:32] Collecting async-timeout<5,>=3.0.0 (from bleak>=0.19.0->TheengsGateway)
[2024-09-15 18:37:32] Downloading https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
[2024-09-15 18:37:35] Collecting dbus-fast<3,>=1.83.0 (from bleak>=0.19.0->TheengsGateway)
[2024-09-15 18:37:35] Downloading dbus_fast-2.24.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (10 kB)
[2024-09-15 18:37:35] Collecting typing-extensions>=4.7.0 (from bleak>=0.19.0->TheengsGateway)
[2024-09-15 18:37:35] Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.12.2-py3-none-any.whl (37 kB)
[2024-09-15 18:37:36] Collecting aiooui>=0.1.1 (from bluetooth-adapters>=0.15.3->TheengsGateway)
[2024-09-15 18:37:36] Downloading aiooui-0.1.6-py3-none-any.whl.metadata (3.8 kB)
[2024-09-15 18:37:36] Collecting uart-devices>=0.1.0 (from bluetooth-adapters>=0.15.3->TheengsGateway)
[2024-09-15 18:37:36] Downloading https://www.piwheels.org/simple/uart-devices/uart_devices-0.1.0-py3-none-any.whl (4.8 kB)
[2024-09-15 18:37:37] Collecting usb-devices>=0.4.5 (from bluetooth-adapters>=0.15.3->TheengsGateway)
[2024-09-15 18:37:37] Downloading https://www.piwheels.org/simple/usb-devices/usb_devices-0.4.5-py3-none-any.whl (5.3 kB)
[2024-09-15 18:37:37] Collecting zipp>=3.20 (from importlib-metadata->TheengsGateway)
[2024-09-15 18:37:37] Downloading https://www.piwheels.org/simple/zipp/zipp-3.20.2-py3-none-any.whl (9.2 kB)
[2024-09-15 18:37:37] Downloading pycryptodomex-3.20.0-cp35-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (2.1 MB)
[2024-09-15 18:37:38] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 3.2 MB/s eta 0:00:00
[2024-09-15 18:37:38] Downloading aiooui-0.1.6-py3-none-any.whl (379 kB)
[2024-09-15 18:37:38] Downloading dbus_fast-2.24.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (5.0 MB)
[2024-09-15 18:37:40] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 5.0/5.0 MB 3.0 MB/s eta 0:00:00
[2024-09-15 18:37:40] Building wheels for collected packages: TheengsDecoder
[2024-09-15 18:37:40] Building wheel for TheengsDecoder (pyproject.toml): started
[2024-09-15 18:38:24] Building wheel for TheengsDecoder (pyproject.toml): finished with status 'done'
[2024-09-15 18:38:24] Created wheel for TheengsDecoder: filename=TheengsDecoder-1.7.8-cp39-cp39-linux_aarch64.whl size=63789 sha256=3bb9f4a5292eaaf528f2e3a30184601c31ea2657fc1caa4db6f5bca09775bd82
[2024-09-15 18:38:24] Stored in directory: /root/.cache/pip/wheels/80/a0/88/ce9fd508a091486356365ce33333d86e321353ac27920f672a
[2024-09-15 18:38:24] Successfully built TheengsDecoder
[2024-09-15 18:38:24] Installing collected packages: TheengsDecoder, zipp, usb-devices, uart-devices, typing-extensions, pycryptodomex, paho-mqtt, dbus-fast, bluetooth-numbers, async-timeout, aiooui, importlib-metadata, bleak, bluetooth-clocks, bluetooth-adapters, TheengsGateway
[2024-09-15 18:38:31] Successfully installed TheengsDecoder-1.7.8 TheengsGateway-1.5.0 aiooui-0.1.6 async-timeout-4.0.3 bleak-0.22.2 bluetooth-adapters-0.19.4 bluetooth-clocks-0.2.0 bluetooth-numbers-1.1.2 dbus-fast-2.24.2 importlib-metadata-8.5.0 paho-mqtt-2.1.0 pycryptodomex-3.20.0 typing-extensions-4.12.2 uart-devices-0.1.0 usb-devices-0.4.5 zipp-3.20.2
[2024-09-15 18:38:34] ***************************
[2024-09-15 18:38:34] * Install ended *
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:04 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:06 --:--:-- 0
