j’ai actuellement 3 antennes Tgw,
2 sur raspi Zero
1 sur une VM sur Freebox Delta, cette dernière me pose problème.
Elle ne fonctionne plus depuis quelques jours.
J’ai mis l’antenne a jour à l’instant, redémarré la VM, mais toujours pareil.
Clé SENA UD100-G03 branché sur l’usb de la Freebox Delta
Je vous met les logs de l’antenne
ERROR:BLEGateway:[org.freedesktop.DBus.Error.NoReply] Message recipient disconnected from message bus without replying
INFO:BLEGateway:Starting BLE scan
INFO:BLEGateway:Connected to MQTT broker
INFO:BLEGateway:Subscribed to home/+/BTtoMQTT/undecoded
INFO:BLEGateway:Sent 0 messages to MQTT
DEBUG:BLEGateway:CE:73:9D:AB:2D:09:AdvertisementData(local_name='DoorLocker', manufacturer_data={2855: b'(\x08\x035\x91\x15\xf2\x80*\n\xf2"\x80'}, service_uuids=['0000fcb9-0000-1000-8000-00805f9b34fb'], tx_power=2, rssi=-42)
DEBUG:BLEGateway:Sent `{"manufacturerdata": "270b280803359115f2802a0af22280", "name": "DoorLocker", "id": "CE:73:9D:AB:2D:09", "rssi": -42, "mfr": "Lumi United Technology Co., Ltd"}` to topic `home/TGW_5/BTtoMQTT/CE739DAB2D09`
INFO:BLEGateway:Sent 1 messages to MQTT
DEBUG:BLEGateway:79:6E:5B:69:EA:FE:AdvertisementData(manufacturer_data={76: b'\x02\x15\x1c\xa9.#\xf0\x87M\xf7\xb9\xa2\xfdKqjK\xf6\x0b\xc5\x00\x00\x03'}, rssi=-60)
DEBUG:BLEGateway:Already discovered or filtered: 796E5B69EAFE
DEBUG:BLEGateway:Sent `{"manufacturerdata": "4c0002151ca92e23f0874df7b9a2fd4b716a4bf60bc5000003", "id": "79:6E:5B:69:EA:FE", "rssi": -60, "brand": "GENERIC", "model": "iBeacon", "model_id": "IBEACON", "type": "BCON", "mfid": "4c00", "uuid": "1ca92e23f0874df7b9a2fd4b716a4bf6", "major": 3013, "minor": 0, "volt": 0.3}` to topic `home/TGW_5/BTtoMQTT/796E5B69EAFE`
DEBUG:BLEGateway:CE:73:9D:AB:2D:09:AdvertisementData(local_name='DoorLocker', manufacturer_data={2855: b'(\x08\x035\x91\x15\xf2\x80*\n\xf2"\x80'}, service_uuids=['0000fcb9-0000-1000-8000-00805f9b34fb'], tx_power=2, rssi=-53)
DEBUG:BLEGateway:Sent `{"manufacturerdata": "270b280803359115f2802a0af22280", "name": "DoorLocker", "id": "CE:73:9D:AB:2D:09", "rssi": -53, "mfr": "Lumi United Technology Co., Ltd"}` to topic `home/TGW_5/BTtoMQTT/CE739DAB2D09`
DEBUG:BLEGateway:1C:AF:4A:25:77:9B:AdvertisementData(manufacturer_data={117: b'B\x04\x01\x80f\x1c\xafJ%w\x9b\x1e\xafJ%w\x9a\x01)\x00\x00\x00\x00\x00'}, rssi=-73)
DEBUG:BLEGateway:Sent `{"manufacturerdata": "750042040180661caf4a25779b1eaf4a25779a01290000000000", "id": "1C:AF:4A:25:77:9B", "rssi": -73, "mfr": "Samsung Electronics Co. Ltd."}` to topic `home/TGW_5/BTtoMQTT/1CAF4A25779B`
DEBUG:BLEGateway:1C:AF:4A:25:77:9B:AdvertisementData(manufacturer_data={117: b'B\x04\x01\x80f\x1c\xafJ%w\x9b\x1e\xafJ%w\x9a\x01)\x00\x00\x00\x00\x00'}, rssi=-74)
DEBUG:BLEGateway:Sent `{"manufacturerdata": "750042040180661caf4a25779b1eaf4a25779a01290000000000", "id": "1C:AF:4A:25:77:9B", "rssi": -74, "mfr": "Samsung Electronics Co. Ltd."}` to topic `home/TGW_5/BTtoMQTT/1CAF4A25779B`
Merci à vous ![]()
