tartan
Janvier 7, 2024, 3:19
21
Merci beaucoup, j’avais regarder dmesg sans vraiment comprendre la cause des timeout, voici les 2 drniers plantages sur une install fraiche, à 17:08 et 04:15
[sam. janv. 6 10:56:29 2024] Bluetooth: RFCOMM ver 1.11
[sam. janv. 6 17:08:07 2024] Bluetooth: hci1: Malformed Event: 0x02
[sam. janv. 6 17:08:08 2024] Bluetooth: hci1: Received unexpected HCI Event 0x00
[sam. janv. 6 17:08:09 2024] Bluetooth: hci1: unexpected event 0x20 length: 99 > 7
[sam. janv. 6 17:08:09 2024] Bluetooth: hci1: unexpected event 0x02 length: 0 < 1
[sam. janv. 6 17:08:09 2024] Bluetooth: hci1: unexpected event 0x18 length: 9 < 23
[sam. janv. 6 17:08:10 2024] Bluetooth: hci1: unexpected event 0x09 length: 255 > 3
[sam. janv. 6 17:08:14 2024] Bluetooth: hci1: command 0x200c tx timeout
[sam. janv. 6 17:08:14 2024] Bluetooth: hci1: Opcode 0x200c failed: -110
[sam. janv. 6 17:08:14 2024] Bluetooth: hci1: Unable to disable scanning: -110
[dim. janv. 7 04:15:01 2024] Bluetooth: hci1: command 0x200c tx timeout
[dim. janv. 7 04:15:01 2024] Bluetooth: hci1: Opcode 0x200c failed: -110
[dim. janv. 7 04:15:01 2024] Bluetooth: hci1: Unable to disable scanning: -110
[dim. janv. 7 04:15:12 2024] Bluetooth: hci1: command 0x0c52 tx timeout
[dim. janv. 7 04:15:12 2024] Bluetooth: hci1: Opcode 0x0c52 failed: -110
[dim. janv. 7 04:15:14 2024] Bluetooth: hci1: command 0x0c13 tx timeout
[dim. janv. 7 04:15:14 2024] Bluetooth: hci1: Opcode 0x0c13 failed: -110
[dim. janv. 7 04:15:16 2024] Bluetooth: hci1: command 0x0c52 tx timeout
[dim. janv. 7 04:15:16 2024] Bluetooth: hci1: Opcode 0x0c52 failed: -110
[dim. janv. 7 04:15:18 2024] Bluetooth: hci1: command 0x0c24 tx timeout
[dim. janv. 7 04:15:18 2024] Bluetooth: hci1: Opcode 0x0c24 failed: -110
[dim. janv. 7 04:15:20 2024] Bluetooth: hci1: command 0x0c24 tx timeout
[dim. janv. 7 04:15:20 2024] Bluetooth: hci1: Opcode 0x0c24 failed: -110
[dim. janv. 7 04:15:22 2024] Bluetooth: hci1: command 0x0c24 tx timeout
[dim. janv. 7 04:15:22 2024] Bluetooth: hci1: Opcode 0x0c24 failed: -110
[dim. janv. 7 04:15:24 2024] Bluetooth: hci1: Opcode 0x0c52 failed: -110
[dim. janv. 7 04:15:24 2024] Bluetooth: hci1: command 0x0c52 tx timeout
[dim. janv. 7 04:15:26 2024] Bluetooth: hci1: command 0x0c13 tx timeout
[dim. janv. 7 04:15:26 2024] Bluetooth: hci1: Opcode 0x0c13 failed: -110
[dim. janv. 7 04:15:28 2024] Bluetooth: hci1: command 0x0c52 tx timeout
[dim. janv. 7 04:15:28 2024] Bluetooth: hci1: Opcode 0x0c52 failed: -110
J’ai mis à jour BlueZ, je vais surveiller
Edit :
cette fois ci même pas deux heure pour planter avec bluez mis à jour
[dim. janv. 7 06:04:07 2024] Bluetooth: hci1: Malformed Event: 0x02
[dim. janv. 7 06:04:09 2024] Bluetooth: hci1: unexpected event 0x09 length: 255 > 3
[dim. janv. 7 06:04:10 2024] Bluetooth: hci1: Malformed Event: 0x13
[dim. janv. 7 06:04:11 2024] Bluetooth: hci1: unexpected event 0x08 length: 10 > 4
[dim. janv. 7 06:04:13 2024] Bluetooth: hci1: command 0x200c tx timeout
[dim. janv. 7 06:04:13 2024] Bluetooth: hci1: Opcode 0x200c failed: -110
[dim. janv. 7 06:04:13 2024] Bluetooth: hci1: Unable to disable scanning: -110
Tout cela, ce n’est pas sur une machine dédié à cet usage ?
On cherche à comprendre et vous dites avec le problème sur 2 PI mais pas sur l’antenne ou il y a Jeedom
Pouvez vous faire le test sur l’un de vos Pi qui sert d’antenne, avec seulement l’antenne d’installé depuis Jeedom.
Et testez avec le Bluetooth interne du Pi, cela écartera un problème avec un dongle externe.
Quel OS avez vous installé ? je n’ai pas cette ligne sur mes RPI :
Avez vous quelque chose de raccordé sur le GPIO ? je trouve sur le net des traces de mauvaise isolation qui créer ce problème.
tartan
Janvier 7, 2024, 10:25
23
je récapitule, c’était la nuit…
J’ai un serveur avec jeedom et 2 rpi3 qui me servent que d’antennes Theengateway. Comme les 2 rpi avaient le même comportement depuis le passage de Blea à Theengateway : rssi à -200 des équipements au bout de maximum 12h environ après reboot, je me concentre donc sur un seul rpi.
Il était avec l’antenne bt local, j’ai donc testé avec un dongle, pas mieux, j’ai donc réinstaller bookworm en version raspbian, pas mieux. J’ai rien installé d’autres dessus à part le rôle d’antenne du plugin Theengateway.
J’ai activé l’historique du rssi d’un équipement dans MQTT discovery et, en effet, quand il passe à -200 rssi, j’ai bien ce genre de log dans dmesg.
Je n’ai rien sur les GPIO et alimentation officielle.
Raspbian ou Raspberry Pi OS ?
J’ai des antennes qui tourne avec cela :
Raspberry Pi OS Bookworm lite 32 bits | Raspberry Pi OS Bullseye lite 32 bits et 64 bits (uniquement sur Pi4)
Si cela fonctionne chez moi, cela doit fonctionner chez vous.
Ou alors, vous avez 1 équipement BT qui créer ces problèmes (déjà vue ici, mais en RFXCom)
tartan
Janvier 7, 2024, 10:32
25
Autant pour moi, oui c’est raspiOS
2023-12-05-raspios-bookworm-arm64
Je peut essayer de laisser qu’un équipement BT pour voir, oui
Si vous êtes sur un Pi3, réinstallez avec la version 32 bits
Les Pi3 ne sont pas stable en 64 bits.
tartan
Janvier 7, 2024, 10:35
27
Merci pour l’aide, je tente tout ça et je fait un retour
Soyez vigilant, ces configurations fonctionnent chez moi !
Machine : Rpi 3b rev 1.2
BT : Interne et Sena UD100-G3
OS : Rapsberry PiOS Bookworm 32 bits lite
tartan
Janvier 8, 2024, 5:10
29
J’attends encore de voir pour la journée mais je n’ai jamais tenu aussi longtemps en enlevant les piles de ce module récemment acheté …
https://www.amazon.fr/Govee-Thermomètre-Hygromètre-Intérieur-Température/dp/B08FD81XDV
Si ça peut servir à d’autres
Mips
Janvier 8, 2024, 5:48
30
Mauvaise pioche à mon avis
J’en ai 2 et Fabrice en a aussi et aucun problème avec mes pi servant d’antenne.
C’est pas clair votre message, cela veux dire quoi ?
Que tout semble ok ?
J’ai 8 sondes Govee H5075001FR et je n’ai jamais eu besoin de retirer les piles, pourquoi vous procédez à ce retrait ?
tartan
Janvier 8, 2024, 6:53
32
Cela veut dire que tout semble ok (plus de 24h) en éteignant (enlever les piles) de ce module Govee.
J’ai voulu commencer par ça comme conseillé
avant de passer le rpi sur du 32bits
Je vais prendre la même configuration que vous à présent : 32 bits raspiOS
tartan
Janvier 8, 2024, 6:55
33
Ok, je vais tout remettre à plat et je vous dit. Encore un grand merci pour votre patience.
Mips
Janvier 8, 2024, 7:01
34
C’était bien tenté mais vu qu’on connaît des contre exemples je préférais le signaler
tartan
Janvier 11, 2024, 8:15
35
Tout est nickel en passant sur 32bits, grand merci à vous.
