Depuis la mise à jour de ce matin de mon ALPHA
J’ai ce warning en permanence et cette erreur
Philips Hue (philipsHue) - beta : 2024-08-06 01:05:55
Core Alpha : 4.4.11 (mise à jour faite juste avant ce message)
Debian : 12
PHP : 8
0225|[Tue Aug 06 08:43:39.944593 2024] [php:error] [pid 3113867] [client 127.0.0.1:58820] PHP Fatal error: Uncaught Psr\\Log\\InvalidArgumentException: Level "1000" is not defined, use one of: DEBUG, INFO, NOTICE, WARNING, ERROR, CRITICAL, ALERT, EMERGENCY in /var/www/html/vendor/monolog/monolog/src/Monolog/Logger.php:507\nStack trace:\n#0 /var/www/html/vendor/monolog/monolog/src/Monolog/Handler/AbstractHandler.php(60): Monolog\\Logger::toMonologLevel()\n#1 /var/www/html/vendor/monolog/monolog/src/Monolog/Handler/AbstractHandler.php(38): Monolog\\Handler\\AbstractHandler->setLevel()\n#2 /var/www/html/vendor/monolog/monolog/src/Monolog/Handler/StreamHandler.php(49): Monolog\\Handler\\AbstractHandler->__construct()\n#3 /var/www/html/core/class/log.class.php(65): Monolog\\Handler\\StreamHandler->__construct()\n#4 /var/www/html/core/class/log.class.php(110): log::getLogger()\n#5 /var/www/html/core/class/cmd.class.php(1902): log::add()\n#6 /var/www/html/core/class/eqLogic.class.php(687): cmd->event()\n#7 /var/www/html/plugins/philipsHue/core/class/philipsHue.class.php(866): eqLogic->checkAndUpdateCmd()\n#8 /var/www/html/plugins/philipsHue/core/php/jeephilipsHue.php(45): philipsHue::syncState()\n#9 {main}\n thrown in /var/www/html/vendor/monolog/monolog/src/Monolog/Logger.php on line 507
0229|[2024-08-06 06:44:51] ERROR : Error on send to jeedom : {"message":"Request failed with status code 500","name":"AxiosError","stack":"AxiosError: Request failed with status code 500\n at settle (/var/www/html/plugins/philipsHue/resources/philipsHued/node_modules/axios/dist/node/axios.cjs:1967:12)\n at IncomingMessage.handleStreamEnd (/var/www/html/plugins/philipsHue/resources/philipsHued/node_modules/axios/dist/node/axios.cjs:3062:11)\n at IncomingMessage.emit (node:events:529:35)\n at endReadableNT (node:internal/streams/readable:1400:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/x-www-form-urlencoded","User-Agent":"axios/1.6.2","Content-Length":"451","Accept-Encoding":"gzip, compress, deflate, br"},"method":"post","url":"http://127.0.0.1:80/plugins/philipsHue/core/php/jeephilipsHue.php?apikey=17nLoTicq6vfLxMZzWyw4W09k0JvPt4uxRlO0OhJYQoYn62c7Y3qNFeTiFRIBG7i","data":"{\"bridge\":{\"1\":\"[{\\\"creationtime\\\":\\\"2024-08-06T06:44:51Z\\\",\\\"data\\\":[{\\\"id\\\":\\\"6dd437a7-298b-49bc-b1f5-5ca879d0fbbf\\\",\\\"id_v1\\\":\\\"/sensors/36\\\",\\\"motion\\\":{\\\"motion\\\":false,\\\"motion_report\\\":{\\\"changed\\\":\\\"2024-08-06T06:44:50.613Z\\\",\\\"motion\\\":false},\\\"motion_valid\\\":true},\\\"owner\\\":{\\\"rid\\\":\\\"0d749c09-8f2c-4d14-9982-2a8bf7292b8d\\\",\\\"rtype\\\":\\\"device\\\"},\\\"type\\\":\\\"motion\\\"}],\\\"id\\\":\\\"bc3142d9-0db8-4ed1-8b96-04d7485fa2ac\\\",\\\"type\\\":\\\"update\\\"}]\"}}"},"code":"ERR_BAD_RESPONSE","status":500}
A disposition pour plus d’information
