Sans log impossible de répondre.
[START UPDATE]
[PROGRESS][1]
****Update from 4.3.17 (2023-08-26 14:42:08)****
Parameters : {"preUpdate":"0","backup::before":"1","plugins":"1","core":"1","force":"0","update::reapply":""}
Send begin of update event...OK
Check update...
OK
[PROGRESS][5]
Check rights...OK
[START BACKUP]
***************Start of Jeedom backup at 2023-08-26 14:42:10***************
Send begin backup event...OK
Checking files rights...OK
Checking database...
OK
Backing up database...OK
Cache persistence:
OK
Creating archive...
OK
Cleaning old backup...OK
Limiting backup size to 500 Mb...
OK
Backup name: /var/www/html/core/php/../../backup/backup-Jee_Deb11_B-4.3.17-2023-08-26-14h42.tar.gz
Send end backup event...OK
Backup operation duration: 26s
***************Jeedom backup end***************
[END BACKUP SUCCESS]
[PROGRESS][10]
[PROGRESS][15]
Download url : https://github.com/jeedom/core/archive/beta.zip
Download in progress...--2023-08-26 14:42:36-- https://github.com/jeedom/core/archive/beta.zip
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/beta [following]
--2023-08-26 14:42:37-- https://codeload.github.com/jeedom/core/zip/refs/heads/beta
Resolving codeload.github.com (codeload.github.com)... 140.82.121.9
Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443... connected.
200 OK
Length: 83753863 (80M) [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K ........ ........ ........ ........ ........ ........ 3% 11.5M 7s
3072K ........ ........ ........ ........ ........ ........ 7% 49.3M 4s
6144K ........ ........ ........ ........ ........ ........ 11% 20.2M 4s
9216K ........ ........ ........ ........ ........ ........ 15% 23.6M 3s
12288K ........ ........ ........ ........ ........ ........ 18% 20.9M 3s
15360K ........ ........ ........ ........ ........ ........ 22% 28.5M 3s
18432K ........ ........ ........ ........ .
....... ........ 26% 19.1M 3s
21504K ........ ........ ........ ........ ........ ........ 30% 29.2M 3s
24576K ........ ........ ........ ........ ........ ........ 33% 17.9M 2s
27648K ........ ........ ........ ........ ........ ........ 37% 25.8M 2s
30720K ........ ........ ........ ........ ........ ........ 41% 15.5M 2s
33792K ........ ........ ........ ........ ........ ........ 45% 50.2M 2s
36864K ........ ........ ........ ........ ........ ........ 48% 16.8M 2s
39936K ........ ........ ........ ........ ........ ........ 52% 35.0M 2s
43008K ........ ........ ........ ........ ........
........ 56% 26.2M 2s
46080K ........ ........ ........ ........ ........ ........ 60% 19.7M 1s
49152K ........ ........ ........ ........ ........ ........ 63% 26.6M 1s
52224K ........ ........ ........ ........ ........ ........ 67% 19.3M 1s
55296K ........ ........ ........ ........ ........ ........ 71% 30.9M 1s
58368K ........ ........ ........ ........ ........ ........ 75% 26.1M 1s
61440K ........ ........ ........ ........ ........ ........ 78% 19.2M 1s
64512K ........ ........ ........ ........ ........ ........ 82% 32.9M 1s
67584K ........ ........ ........ ........ ........ ........ 86% 26.8M 0s
70656K .
....... ........ ........ ........ ........ ........ 90% 18.7M 0s
73728K ........ ........ ........ ........ ........ ........ 93% 28.8M 0s
76800K ........ ........ ........ ........ ........ ........ 97% 19.3M 0s
79872K ........ ........ ........ ..... 100% 61.6M=3.5s
2023-08-26 14:42:41 (23.1 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [83753863/83753863]
[PROGRESS][25]
OK
Cleaning folders...OK
[PROGRESS][30]
Create temporary folder...OK
[PROGRESS][35]
Unzip in progress...
OK
[PROGRESS][40]
Clean temporary files (tmp)...OK
Disable all task. OK
Disable all scenario OK
[PROGRESS][45]
Moving files...Ignore file /tmp/jeedom_unzip/core-beta///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-beta///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-beta///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-beta///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-beta///docs/pt_PT/noteVersion.md because size is 0
OK
[PROGRESS][50]
Remove temporary files...OK
[PROGRESS][52]
Remove useless files...
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script
find: '/var/www/html/install/../script/*': No such file or directory
Cleaning vendor
[PROGRESS][55]
Check jeedom consistency...
[START CONSISTENCY]
[START CHECK AND FIX DB]
[END CHECK AND FIX DB]
Check jeedom package...OK
Check jeedom database...OK
Check crons...
Check filesystem right...OK
Flush cache widget...
Ça c’est un autre soucis qui n’a rien a voir avec la beta. Je l’ai déjà vu plusieurs fois mais je pourrais pas te dire d’où ça vient ni comment corriger. Peut être en redémarrant jeedom et en relançant la maj.
j’ai essayé avec un rpi, vm, Debian10 /11 et toujour pareil et plus d’accès http. plus qu’a restaurer en ssh à chaque fois .
Faut trouver pourquoi il n’y a plus d’accès en regardant en ssh le log http.error.
Après je dis pas qu’il n’y a pas un bug la dessus dans ton cas a toi juste je suis pas sûr que ça soit du a la beta mais plus un truc révélé par la beta.
pas grand chose dans http.error
[26-Aug-2023 15:31:17 Europe/Brussels] PHP Warning: substr() expects parameter 3 to be int, string given in /var/www/html/desktop/php/backup.php on line 66
Quand tu vas sur l’interface tu as quoi ? Une page blanche ? Hésite pas à détailler plus que nécessaire car je ne vois pas ce que tu vois…
Error 500
j’ai trouvé une erreur je pense que ça explique ce qui se passe chez moi
0003|[Sat Aug 26 16:48:49.447719 2023] [php7:error] [pid 7691] [client 192.168.1.22:61480] PHP Fatal error: Access level to VaillantControl::$_templateArray must be protected (as in class eqLogic) or weaker in /var/www/html/plugins/VaillantControl/core/class/VaillantControl.class.php on line 8
donc dès que le plugin est activé ça provoque ce bug, ce qui n’a jamais été le cas
Oui ça explique ton soucis alors effectivement j’ai rendu ça plus propre en 4.4 donc il faut bien adapter les plugins. Par contre je comprends pas pourquoi ce plugin a besoin de cette variable il ne devrait pas c’est interne au core…
Je ne sais pas non plus ce qu’elle fait là surtout qu’elle n’est pas appelé !
mais bizarrement le plugin est actif sur une autre install 4.4, ces changements sont récent ?
Je pense pas de mémoire j’ai fait ça ta 1 mois ou 2.
J’ai aussi un souci similaire avec mon Jeedom 4.4 alpha.
Je n’arrive pas à avoir la bonne version de guzzlehttp/guzzle car une des dépendances n’accepte pas la version demandée par Jeedom (< 7.0) :
league/oauth2-client 2.7.0 requires guzzlehttp/guzzle (^6.0 || ^7.0)
php-http/guzzle7-adapter 1.0.0 requires guzzlehttp/guzzle (^7.0)
Tu dois savoir qu’elle plugin alors pose soucis ?
c’est dans le composer.json du core ce plugin, non ?
Je reviens tardivement (j’étais en vacances), j’ai un message rouge dès que j’ouvre la page de mise à jour
Erreur sur la vérification des mises à jour : No PSR-18 clients found. Make sure to install a package providing "psr/http-client-implementation". Example: "php-http/guzzle7-adapter".
J’ai lancé la mise à mode forcée pour faire disparaitre ce message, si non j’ai les messages suivants
0000|[START UPDATE]
0001|[PROGRESS][1]
0002|****Update from 4.4.0 (2023-09-09 09:04:52)****
0003|Parameters : {"preUpdate":"0","backup::before":"0","core":"1","force":"0","plugins":"1","update::reapply":""}
0004|Send begin of update event...OK
0005|Check update...Error during update : No PSR-18 clients found. Make sure to install a package providing "psr/http-client-implementation". Example: "php-http/guzzle7-adapter".Details : Array
0006|(
0007|[0] => Array
0008|(
0009|[file] => /var/www/html/vendor/knplabs/github-api/lib/Github/HttpClient/Builder.php
0010|[line] => 85
0011|[function] => find
0012|[class] => Http\Discovery\Psr18ClientDiscovery
0013|[type] => ::
0014|)
0015|[1] => Array
0016|(
0017|[file] => /var/www/html/vendor/knplabs/github-api/lib/Github/Client.php
0018|[line] => 129
0019|[function] => __construct
0020|[class] => Github\HttpClient\Builder
0021|[type] => ->
0022|)
0023|[2] => Array
0024|(
0025|[file] => /var/www/html/core/repo/github.repo.php
0026|[line] => 80
0027|[function] => __construct
0028|[class] => Github\Client
0029|[type] => ->
0030|)
0031|[3] => Array
0032|(
0033|[file] => /var/www/html/core/repo/github.repo.php
0034|[line] => 101
0035|[function] => getGithubClient
0036|[class] => repo_github
0037|[type] => ::
0038|)
0039|[4] => Array
0040|(
0041|[file] => /var/www/html/core/repo/github.repo.php
0042|[line] => 97
0043|[function] => checkUpdate
0044|[class] => repo_github
0045|[type] => ::
0046|)
0047|[5] => Array
0048|(
0049|[file] => /var/www/html/core/class/update.class.php
0050|[line] => 83
0051|[function] => checkUpdate
0052|[class] => repo_github
0053|[type] => ::
0054|)
0055|[6] => Array
0056|(
0057|[file] => /var/www/html/install/update.php
0058|[line] => 70
0059|[function] => checkAllUpdate
0060|[class] => update
0061|[type] => ::
0062|)
0063|)
0064|[END UPDATE ERROR]
0065|PHP Fatal error: Uncaught Http\Discovery\Exception\DiscoveryFailedException: Could not find resource using any discovery strategy. Find more information at http://docs.php-http.org/en/latest/discovery.html#common-errors
0066|- No valid candidate found using strategy "Http\Discovery\Strategy\CommonClassesStrategy". We tested the following candidates: Http\Discovery\Strategy\CommonClassesStrategy::symfonyPsr18Instantiate, GuzzleHttp\Client, Http\Discovery\Strategy\CommonClassesStrategy::buzzInstantiate.
0067|- No valid candidate found using strategy "Http\Discovery\Strategy\CommonPsr17ClassesStrategy". We tested the following candidates: .
0068|in /var/www/html/vendor/php-http/discovery/src/Exception/DiscoveryFailedException.php:41
0069|Stack trace:
0070|#0 /var/www/html/vendor/php-http/discovery/src/ClassDiscovery.php(94): Http\Discovery\Exception\DiscoveryFailedException::create()
0071|#1 /var/www/html/vendor/php-http/discovery/src/Psr18ClientDiscovery.php(25): Http\Discovery\ClassDiscovery::findOneByType()
0072|#2 /var/www/html/vendor/knplabs/github-api/l in /var/www/html/vendor/php-http/discovery/src/Psr18ClientDiscovery.php on line 27
Dans les logs on voit cela aussi
0092|sudo: export: command not found
0093|sudo: export: command not found
0094|sudo: export: command not found
Voila les logs complets
0000|[START UPDATE]
0001|[PROGRESS][1]
0002|****Update from 4.4.0 (2023-09-09 09:07:06)****
0003|Parameters : {"preUpdate":"0","backup::before":"0","core":"1","force":"1","plugins":"1","update::reapply":""}
0005|[PROGRESS][5]
0006|Check rights...
0007|OK
0008|[PROGRESS][10]
0009|[PROGRESS][15]
0010|Download url : https://github.com/jeedom/core/archive/alpha.zip
0011|Download in progress...--2023-09-09 09:07:08-- https://github.com/jeedom/core/archive/alpha.zip
0012|Resolving github.com (github.com)... 140.82.121.4
0013|Connecting to github.com (github.com)|140.82.121.4|:443... connected.
0014|HTTP request sent, awaiting response... 302 Found
0015|Location: https://codeload.github.com/jeedom/core/zip/refs/heads/alpha [following]
0016|--2023-09-09 09:07:09-- https://codeload.github.com/jeedom/core/zip/refs/heads/alpha
0017|Resolving codeload.github.com (codeload.github.com)... 140.82.121.10
0018|Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443... connected.
0019|HTTP request sent, awaiting response... 200 OK
0020|Length: unspecified [application/zip]
0021|Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0022|0K ........ ........ ........ ........ ........ ........ 4.65M
0023|3072K ........ ........ ........ ........ ........ ........ 14.5M
0024|6144K ........ ........ ........ ........ ........ ........ 6.03M
0025|9216K ........ ........ .......
0026|........ ........ ........ 12.4M
0027|12288K ........ ........ ........ ........ ........ ........ 5.22M
0028|15360K ........ ........ ........ ........ ........ ........ 10.0M
0029|18432K ........ ........ ........ ........ ........ ........ 10.2M
0030|21504K ........ ........ ........ ........ ........ ........ 26.8M
0031|24576K ........ ........ ........ ........ ........ ........ 28.1M
0032|27648K ........ ........ ........ ........ ......
0033|.. ........ 11.1M
0034|30720K ........ ........ ........ ........ ........ ........ 13.6M
0035|33792K ........ ........ ........ ........ ........ ........ 15.9M
0036|36864K ........ ........ ........ ........ ........ ........ 15.5M
0037|39936K ........ ........ ........ ........ ........ ........ 8.71M
0038|43008K ........ ........ ........ ........ ........ ........ 16.0M
0039|46080K ........ ........ ........ ........ ........ ........ 17.2M
0040|49152K ........ ........ ........ ........ ........ ........ 16.5M
0041|52224K ........ ........ ........ ........ ........ ........ 16.4M
0042|55296K ........ ........ ........ ........ ........ ........ 17.4M
0043|58368K ........ ........ ........ ........ ........ ........ 18.1M
0044|61440K ........ ........ ........ ........ ........ ....
0045|.... 16.9M
0046|64512K ........ ........ ........ ........ ........ ........ 16.9M
0047|67584K ........ ........ ........ ........ ........ ........ 17.8M
0048|70656K ........ ........ ........ ........ ........ ........ 18.7M
0049|73728K ........ ........ ........ ........ ........ ........ 19.1M
0050|76800K ........ ........ ........ ........ ........ ........ 18.1M
0051|79872K ........ ........ ........ ...... 19.4M=6.4s
0052|2023-09-09 09:07:15 (12.6 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [83774126]
0053|[PROGRESS][25]
0054|OK
0055|Cleaning folders...OK
0056|[PROGRESS][30]
0057|Create temporary folder...OK
0058|[PROGRESS][35]
0059|Unzip in progress...
0060|OK
0061|[PROGRESS][40]
0062|Clean temporary files (tmp)...OK
0063|Disable all task
0064|. OK
0065|Disable all scenario............. OK
0066|[PROGRESS][45]
0067|Moving files...Ignore file /tmp/jeedom_unzip/core-alpha///docs/de_DE/noteVersion.md because size is 0
0068|Ignore file /tmp/jeedom_unzip/core-alpha///docs/en_US/noteVersion.md because size is 0
0069|Ignore file /tmp/jeedom_unzip/core-alpha///docs/es_ES/noteVersion.md because size is 0
0070|Ignore file /tmp/jeedom_unzip/core-alpha///docs/fr_FR/noteVersion.md because size is 0
0071|Ignore file /tmp/jeedom_unzip/core-alpha///docs/pt_PT/noteVersion.md because size is 0
0072|OK
0073|[PROGRESS][50]
0074|Remove temporary files...OK
0075|[PROGRESS][52]
0076|Remove useless files...
0077|Cleaning 3rdparty
0078|Cleaning desktop
0079|Cleaning mobile
0080|Cleaning core
0081|Cleaning docs
0082|Cleaning install
0083|Cleaning script
0084|find: '/var/www/html/install/../script/*': No such file or directory
0085|OK
0086|[PROGRESS][53]
0087|Update composer file...
0088|sudo: export: command not found
0089|sudo: export: command not found
0090|sudo: export: command not found
0091|rm: cannot remove '/tmp/composer': No such file or directory
0092|OK
0093|[PROGRESS][58]
0094|Update jeedom information date...
0095|OK
0096|[PROGRESS][59]
0097|[PROGRESS][60]
0098|Check jeedom consistency...
0099|[START CONSISTENCY]
0100|[START CHECK AND FIX DB]
0101|[END CHECK AND FIX DB]
0102|Check jeedom package...OK
0103|Check jeedom database...OK
0104|Check crons...
0105|Check filesystem right...
0106|OK
0107|Flush cache widget...
0108|Check jeedom object...OK
0109|Check jeedom cmd...OK
0110|Set cache hour...OK
0111|Check composer...OK
0112|Check nodejs...
0113|Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
0114|Hit:2 http://ftp.fr.debian.org/debian bullseye InRelease
0115|Hit:3 http://ftp.fr.debian.org/debian bullseye-updates InRelease
0116|Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
0117|Fetched 4586 B in 1s (3782 B/s)
0118|Reading package lists...
0119|Reading package lists...
0120|Building dependency tree...
0121|Reading state information...
0122|apt-utils is already the newest version (2.2.4).
0123|build-essential is already the newest version (12.9).
0124|git is already the newest version (1:2.30.2-1+deb11u2).
0125|lsb-release is already the newest version (11.1.0).
0126|The following packages were automatically installed and are no longer required:
0127|libre2-9 linux-image-5.10.0-19-amd64
0128|Use 'sudo apt autoremove' to remove them.
0129|0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
0130|[Check Version NodeJS actuelle : v16.20.2 : [ OK ]
0131|[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
0132|OK
0133|[END CONSISTENCY]
0134|OK
0135|Check update...OK
0136|***************Jeedom is up to date in 4.4.0***************
0137|[PROGRESS][75]
0138|***************Update plugins***************
0139|***************Update plugin successfully***************
0140|[PROGRESS][90]
0141|Check update
0142|***ERROR*** No PSR-18 clients found. Make sure to install a package providing "psr/http-client-implementation". Example: "php-http/guzzle7-adapter".
0143|[PROGRESS][95]
0144|Enable scenario : OK
0145|Enable task : OK
0146|[PROGRESS][100]
0147|Launch cron dependancy plugins...OK
0148|Send end of update event...OK
0149|Update duration : 41s
0150|[END UPDATE SUCCESS]
Par contre impossible de lancer une mise à jour sans mode forcé
J’ai lancé une mise à jour forcée en ligne de commande après avoir simplifié la fonction de création du client Github.
Mise à jour réalisée et à présent j’ai la même erreur que toi :
Je pense que c’est la même erreur que ce sujet
J’ai fais un retour arriere sur toute la partie composer. Pouvez vous mettre a jour et me dire si c’est mieux ?
Je viens de faire une mise à jour sur alpha 4.4 et tout se déroule bien.
Deb12 - Core Alpha 4.4 sur VM ESXi
Debian 11.7 et j’ai le meme probleme sur une mise à jour alpha faite à l’instant
[START UPDATE]
****Update from 4.4.0 (2023-09-14 14:47:05)****
Parameters : {"preUpdate":"0","backup::before":"0","core":"1","force":"1","plugins":"0","update::reapply":""}
Send begin of update event | OK
Check rights | OK
Download in progress--2023-09-14 14:47:21-- https://github.com/jeedom/core/archive/alpha.zip
Resolving github.com (github.com) 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443 connected.
HTTP request sent, awaiting response 302 Found
--2023-09-14 14:47:22-- https://codeload.github.com/jeedom/core/zip/refs/heads/alpha
Resolving codeload.github.com (codeload.github.com) 140.82.121.9
Connecting to codeload.github.com (codeload.github.com)|140.82.121.9|:443 connected.
HTTP request sent, awaiting response 200 | OK
0K
7.06M
3072K 8.11M
6144K
7.36M
9216K
10.0M
12288K 4.76M
15360K
13.0M
18432K
. 10.1M
21504K 29.6M
24576K 19.6M
27648K 27.1M
30720K 25.3M
33792K 29.1M
36864K
15.7M
39936K
. 6.29M
43008K 22.0M
46080K 27.3M
49152K 26.8M
52224K
19.0M
55296K 25.9M
58368K .
32.3M
61440K 12.3M
64512K 24.5M
67584K 27.4M
70656K 18.8M
73728K
15.3M
76800K 33.1M
79872K 21.0M=5.7s
2023-09-14 14:47:28 (14.1 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [83787926] | OK
Cleaning folders | OK
Create temporary folder | OK
Unzip in progress | OK
Clean temporary files (tmp) | OK
Disable all task | OK
| OK
Moving filesIgnore file /tmp/jeedom_unzip/core-alpha///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/pt_PT/noteVersion.md because size is 0 | OK
Remove temporary files | OK
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script | OK
Update jeedom information date | OK
[START CONSISTENCY]
Check jeedom package | OK
Check jeedom database | OK
Check crons
Check filesystem right | OK
Flush cache widget
Check jeedom object | OK
Check jeedom cmd | OK
Set cache hour | OK
Check composer | OK
Check nodejs
Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Hit:2 http://deb.debian.org/debian bullseye InRelease
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:4 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
Get:6 http://security.debian.org/debian-security bullseye-security/main Sources [155 kB]
Get:7 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [246 kB]
Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
Fetched 536 kB in 2s (251 kB/s)
The following package was automatically installed and is no longer required:
libopengl0
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 36 not upgraded.
[Check Version NodeJS actuelle : v16.20.1 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ] | OK
[END CONSISTENCY] | OK
Check update | OK
Check update
PHP Fatal error: Uncaught Error: Class 'Guzzle\Http\Client' not found in /var/www/html/vendor/knplabs/github-api/lib/Github/HttpClient/HttpClient.php:52
Stack trace:
#0 /var/www/html/vendor/knplabs/github-api/lib/Github/Client.php(258): Github\HttpClient\HttpClient->__construct()
#1 /var/www/html/vendor/knplabs/github-api/lib/Github/Api/AbstractApi.php(76): Github\Client->getHttpClient()
#2 /var/www/html/vendor/knplabs/github-api/lib/Github/Api/Repo.php(379): Github\Api\AbstractApi->get()
#3 /var/www/html/core/repo/github.repo.php(103): Github\Api\Repo->branches()
#4 /var/www/html/core/repo/github.repo.php(97): repo_github::checkUpdate()
#5 /var/www/html/core/class/update.class.php(83): repo_github::checkUpdate()
#6 /var/www/html/install/update.php(328): update::checkAllUpdate()
#7 {main}
thrown in /var/www/html/vendor/knplabs/github-api/lib/Github/HttpClient/HttpClient.php on line 52
Bloqué à 90% mode forcé actif
