Page concernée : Mise à jour
Version Core : 4.4 ALPHA
Voila les logs a l’état actuel => les autres logs sont vide
[START UPDATE]
****Update from 4.4.0 (2023-08-17 17:03:07)****
Parameters : {"preUpdate":"0","backup::before":"1","core":"1","force":"0","plugins":"1","update::reapply":""}
Send begin of update event | OK
Check update | OK
Check rights | OK
[START BACKUP]
***************Start of Jeedom backup at 2023-08-17 17:03:13***************
Send begin backup event | OK
Checking files rights | OK
Checking database | OK
Backing up database | OK
Cache persistence: | OK
Creating archive | OK
Cleaning old backup | OK
Limiting backup size to 1000 Mb | OK
Backup name: /var/www/html/core/php///backup/backup-JAG_JeedomVM2-4.4.0-2023-08-17-17h03.tar.gz
Send end backup event | OK
Backup operation duration: 48s
***************Jeedom backup end***************
[END BACKUP SUCCESS]
Download url : https://github.com/jeedom/core/archive/alpha.zip
Download in progress--2023-08-17 17:04:01-- https://github.com/jeedom/core/archive/alpha.zip
Resolving github.com (github.com)
140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443 connected.
HTTP request sent, awaiting response 302 Found
Location: https://codeload.github.com/jeedom/core/zip/refs/heads/alpha [following]
--2023-08-17 17:04:02-- https://codeload.github.com/jeedom/core/zip/refs/heads/alpha
Resolving codeload.github.com (codeload.github.com) 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443 connected.
HTTP request sent, awaiting response 200 | OK
Length: unspecified [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K 5.75M
3072K
7.00M
6144K 4.06M
9216K
6.10M
12288K 3.83M
15360K .
7.71M
18432K 9.98M
21504K 17.1M
24576K 46.3M
27648K 29.9M
30720K 19.7M
33792K 16.4M
36864K
11.0M
39936K 16.3M
43008K 14.2M
46080K 14.2M
49152K 9.33M
52224K 18.4M
55296K
14.4M
58368K 5.24M
61440K 10.6M
64512K 11.6M
67584K
11.6M
70656K 12.8M
73728K 12.1M
76800K 9.57M
79872K
10.1M=8.3s
2023-08-17 17:04:10 (9.68 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [83763660] | OK
Cleaning folders | OK
Create temporary folder | OK
Unzip in progress | OK
Clean temporary files (tmp) | OK
Disable all task. | OK
Disable all scenario | OK
Moving files
Ignore file /tmp/jeedom_unzip/core-alpha///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-alpha///docs/pt_PT/noteVersion.md because size is 0 | OK
Remove temporary files | OK
Remove useless files
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script
find: '/var/www/html/install//script/*': No such file or directory | OK
Update composer file
Composer plugins have been disabled for safety in this non-interactive session. Set COMPOSER_ALLOW_SUPERUSER=1 if you want to allow plugins to run as root/super user.
You are already using the latest available Composer version 2.5.8 (stable channel).
Do not run Composer as root/super user! See https://getcomposer.org/root for details
Loading composer repositories with package information
Info from https://repo.packagist.org: #StandWithUkraine
Updating dependencies
Lock file operations: 23 installs, 19 updates, 15 removals
- Removing bacon/bacon-qr-code (1.0.3)
- Removing guzzle/guzzle (v3.9.3)
- Removing league/oauth2-client (2.6.1)
- Removing matthiasmullie/minify (1.3.69)
- Removing matthiasmullie/path-converter (1.1.3)
- Removing paragonie/random_compat (v9.99.100)
- Removing psr/simple-cache (1.0.1)
- Removing symfony/event-dispatcher (v2.8.52)
- Removing symfony/polyfill-intl-idn (v1.19.0)
- Removing symfony/polyfill-intl-normalizer (v1.19.0)
- Removing symfony/polyfill-php56 (v1.19.0)
- Removing symfony/polyfill-php70 (v1.19.0)
- Removing symfony/polyfill-php72 (v1.19.0)
- Removing symfony/polyfill-util (v1.19.0)
- Removing touki/ftp (v1.2.1)
- Locking abbadon1334/sun-position-spa-php (2.0.0)
- Locking clue/stream-filter (v1.6.0)
- Upgrading doctrine/cache (v1.6.2 => 1.13.0)
- Upgrading dragonmantank/cron-expression (v2.3.1 => v3.3.3)
- Upgrading guzzlehttp/guzzle (6.5.8 => 7.7.0)
- Upgrading guzzlehttp/promises (1.5.2 => 2.0.1)
- Upgrading guzzlehttp/psr7 (1.9.0 => 2.6.0)
- Upgrading knplabs/github-api (1.7.1 => v3.11.0)
- Upgrading league/flysystem (1.0.70 => 1.1.10)
- Locking league/mime-type-detection (1.13.0)
- Upgrading monolog/monolog (1.27.1 => 2.9.1)
- Locking php-http/cache-plugin (1.8.0)
- Locking php-http/client-common (2.7.0)
- Locking php-http/discovery (1.19.1)
- Locking php-http/guzzle7-adapter (1.0.0)
- Locking php-http/httplug (2.4.0)
- Locking php-http/message (1.16.0)
- Locking php-http/message-factory (1.1.0)
- Locking php-http/multipart-stream-builder (1.3.0)
- Locking php-http/promise (1.1.0)
- Upgrading pragmarx/google2fa (v7.0.0 => v8.0.1)
- Upgrading pragmarx/google2fa-qrcode (v1.0.3 => v3.0.0)
- Locking psr/container (1.1.2)
- Locking psr/http-client (1.0.2)
- Locking psr/http-factory (1.0.2)
- Upgrading psr/http-message (1.0.1 => 1.1)
- Upgrading sabre/dav (4.0.3 => 4.4.0)
- Upgrading sabre/event (5.0.3 => 5.1.4)
- Upgrading sabre/http (5.0.5 => 5.1.8)
- Upgrading sabre/uri (2.1.3 => 2.3.3)
- Upgrading sabre/vobject (4.2.2 => 4.5.3)
- Upgrading sabre/xml (2.1.3 => 2.2.6)
- Upgrading symfony/cache (v3.3.6 => v5.4.25)
- Locking symfony/cache-contracts (v2.5.2)
- Locking symfony/deprecation-contracts (v2.5.2)
- Upgrading symfony/expression-language (v3.3.6 => v5.4.21)
- Locking symfony/options-resolver (v5.4.21)
- Locking symfony/polyfill-php73 (v1.27.0)
- Locking symfony/polyfill-php80 (v1.27.0)
- Locking symfony/service-contracts (v2.5.2)
- Locking symfony/var-exporter (v5.4.26)
- Locking webmozart/assert (1.11.0)
Writing lock file
Installing dependencies from lock file
Package operations: 22 installs, 20 updates, 15 removals
- Downloading php-http/discovery (1.19.1)
- Downloading abbadon1334/sun-position-spa-php (2.0.0)
- Downloading doctrine/cache (1.13.0)
- Downloading webmozart/assert (1.11.0)
- Downloading dragonmantank/cron-expression (v3.3.3)
- Downloading guzzlehttp/promises (2.0.1)
- Downloading symfony/polyfill-php80 (v1.27.0)
- Downloading symfony/deprecation-contracts (v2.5.2)
- Downloading psr/http-message (1.1)
- Downloading psr/http-factory (1.0.2)
- Downloading guzzlehttp/psr7 (2.6.0)
- Downloading psr/http-client (1.0.2)
- Downloading guzzlehttp/guzzle (7.7.0)
- Downloading php-http/promise (1.1.0)
- Downloading php-http/httplug (2.4.0)
- Downloading php-http/guzzle7-adapter (1.0.0)
- Downloading php-http/multipart-stream-builder (1.3.0)
- Downloading symfony/polyfill-php73 (v1.27.0)
- Downloading symfony/options-resolver (v5.4.21)
- Downloading clue/stream-filter (v1.6.0)
- Downloading php-http/message (1.16.0)
- Downloading php-http/client-common (2.7.0)
- Downloading php-http/message-factory (1.1.0)
- Downloading php-http/cache-plugin (1.8.0)
- Downloading knplabs/github-api (v3.11.0)
- Downloading sabre/uri (2.3.3)
- Downloading sabre/xml (2.2.6)
- Downloading sabre/vobject (4.5.3)
- Downloading sabre/event (5.1.4)
- Downloading sabre/http (5.1.8)
- Downloading sabre/dav (4.4.0)
- Downloading league/mime-type-detection (1.13.0)
- Downloading league/flysystem (1.1.10)
- Downloading monolog/monolog (2.9.1)
- Downloading pragmarx/google2fa (v8.0.1)
- Downloading pragmarx/google2fa-qrcode (v3.0.0)
- Downloading symfony/cache-contracts (v2.5.2)
- Downloading psr/container (1.1.2)
- Downloading symfony/service-contracts (v2.5.2)
- Downloading symfony/var-exporter (v5.4.26)
- Downloading symfony/cache (v5.4.25)
- Downloading symfony/expression-language (v5.4.21)
A disposition pour donner d’autres infos si je peux
