Déjà, un grand merci pour le plugin ainsi que le suivi/évolution que vous nous proposés au quotidien. C’est vraiment un plugin prometteur
J’ai depuis la dernière stable des erreurs à répétitions dans le log http.error… rien de bloquant mais c’est histoire de vous le faire remonter !
[Mon Oct 28 18:46:49.005026 2019] [:error] [pid 18505] [client 192.168.254.37:55226] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
thrown in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php on line 133
[Mon Oct 28 19:00:04.360731 2019] [:error] [pid 4160] [client 192.168.254.37:54354] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 19:31:48.941574 2019] [:error] [pid 25294] [client 192.168.254.37:37036] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:00:04.372677 2019] [:error] [pid 5790] [client 192.168.254.37:39538] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:19:13.419265 2019] [:error] [pid 4072] [client 192.168.254.37:51706] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:30:07.822582 2019] [:error] [pid 4160] [client 192.168.254.37:45648] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:30:08.273134 2019] [:error] [pid 5593] [client 192.168.254.37:45694] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:30:08.291336 2019] [:error] [pid 5790] [client 192.168.254.37:45682] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:30:08.509610 2019] [:error] [pid 27009] [client 192.168.254.37:45688] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:30:52.441094 2019] [:error] [pid 4160] [client 192.168.254.37:47188] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:20.462533 2019] [:error] [pid 5790] [client 192.168.254.37:40786] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:20.938408 2019] [:error] [pid 7087] [client 192.168.254.37:40820] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:21.904071 2019] [:error] [pid 4072] [client 192.168.254.37:40824] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:306
Stack trace:
#0 /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php(106): metAJourPlayer('G070RR13904300M...', NULL, false)
#1 {main}
thrown in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php on line 306
[Mon Oct 28 20:41:23.977368 2019] [:error] [pid 5790] [client 192.168.254.37:40936] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:24.235681 2019] [:error] [pid 5593] [client 192.168.254.37:40930] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:24.297740 2019] [:error] [pid 27009] [client 192.168.254.37:40940] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:24.671150 2019] [:error] [pid 7097] [client 192.168.254.37:40942] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:306
Stack trace:
#1 {main}
[Mon Oct 28 20:41:27.560865 2019] [:error] [pid 25294] [client 192.168.254.37:41046] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:43.576829 2019] [:error] [pid 20288] [client 192.168.254.37:41602] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:44.049261 2019] [:error] [pid 4072] [client 192.168.254.37:41648] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:44.082629 2019] [:error] [pid 4160] [client 192.168.254.37:41604] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 20:41:44.225066 2019] [:error] [pid 5790] [client 192.168.254.37:41642] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 21:07:26.611366 2019] [:error] [pid 5593] [client 192.168.254.37:37628] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 21:41:31.378732 2019] [:error] [pid 5593] [client 192.168.254.37:50916] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 21:55:44.945790 2019] [:error] [pid 5593] [client 192.168.254.37:51766] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 22:02:51.436102 2019] [:error] [pid 20288] [client 192.168.254.37:38106] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 22:41:31.396077 2019] [:error] [pid 29094] [client 192.168.254.37:60486] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 22:42:10.028288 2019] [:error] [pid 29094] [client 192.168.254.37:33526] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 23:28:40.324378 2019] [:error] [pid 29134] [client 192.168.254.37:42880] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 23:32:39.336965 2019] [:error] [pid 29094] [client 192.168.254.37:50996] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Mon Oct 28 23:41:31.450424 2019] [:error] [pid 31525] [client 192.168.254.37:40632] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 00:19:13.256025 2019] [:error] [pid 30101] [client 192.168.254.37:60260] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 00:41:31.632742 2019] [:error] [pid 29134] [client 192.168.254.37:49496] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 00:58:54.177226 2019] [:error] [pid 7097] [client 192.168.254.37:56804] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 01:11:47.622992 2019] [:error] [pid 3060] [client 192.168.254.37:55004] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 01:41:31.682377 2019] [:error] [pid 29134] [client 192.168.254.37:59244] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 02:04:27.014759 2019] [:error] [pid 31525] [client 192.168.254.37:49530] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 02:28:12.208704 2019] [:error] [pid 5790] [client 192.168.254.37:41296] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 02:41:31.640464 2019] [:error] [pid 5593] [client 192.168.254.37:40348] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 03:00:05.803314 2019] [:error] [pid 20288] [client 192.168.254.37:50006] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 03:41:31.706361 2019] [:error] [pid 4072] [client 192.168.254.37:49340] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 03:41:31.712892 2019] [:error] [pid 3060] [client 192.168.254.37:49342] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 03:56:04.210597 2019] [:error] [pid 29134] [client 192.168.254.37:50470] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 03:56:04.214844 2019] [:error] [pid 31525] [client 192.168.254.37:50472] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 03:57:45.961991 2019] [:error] [pid 4072] [client 192.168.254.37:53968] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 03:57:45.971206 2019] [:error] [pid 7097] [client 192.168.254.37:53970] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 04:41:31.790216 2019] [:error] [pid 30101] [client 192.168.254.37:57746] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 04:41:31.793300 2019] [:error] [pid 20288] [client 192.168.254.37:57748] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 04:53:11.448568 2019] [:error] [pid 5593] [client 192.168.254.37:53196] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 04:53:11.455216 2019] [:error] [pid 4072] [client 192.168.254.37:53198] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 05:24:27.931452 2019] [:error] [pid 3060] [client 192.168.254.37:60104] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 05:24:27.934148 2019] [:error] [pid 5790] [client 192.168.254.37:60106] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 05:41:31.786159 2019] [:error] [pid 29134] [client 192.168.254.37:38456] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 05:41:31.790949 2019] [:error] [pid 20288] [client 192.168.254.37:38458] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 05:48:41.642623 2019] [:error] [pid 29134] [client 192.168.254.37:53140] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 05:48:41.659882 2019] [:error] [pid 29094] [client 192.168.254.37:53142] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 06:34:21.862794 2019] [:error] [pid 7097] [client 192.168.254.37:33086] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 06:34:21.867939 2019] [:error] [pid 4072] [client 192.168.254.37:33088] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 06:41:31.882448 2019] [:error] [pid 29094] [client 192.168.254.37:47540] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 06:41:31.884087 2019] [:error] [pid 20288] [client 192.168.254.37:47542] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 06:50:52.622423 2019] [:error] [pid 30101] [client 192.168.254.37:38392] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 06:50:52.627533 2019] [:error] [pid 4072] [client 192.168.254.37:38394] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 06:57:39.856697 2019] [:error] [pid 20288] [client 192.168.254.37:52136] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 06:57:39.858976 2019] [:error] [pid 31525] [client 192.168.254.37:52138] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 07:20:07.129623 2019] [:error] [pid 30101] [client 192.168.254.37:41214] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 07:20:07.135484 2019] [:error] [pid 4072] [client 192.168.254.37:41216] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 07:41:32.076748 2019] [:error] [pid 4072] [client 192.168.254.37:57704] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 07:41:32.083960 2019] [:error] [pid 5790] [client 192.168.254.37:57706] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 08:06:59.293529 2019] [:error] [pid 3060] [client 192.168.254.37:53194] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 08:06:59.298653 2019] [:error] [pid 13536] [client 192.168.254.37:53196] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 08:18:00.449656 2019] [:error] [pid 30101] [client 192.168.254.37:47544] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 08:18:00.455566 2019] [:error] [pid 4072] [client 192.168.254.37:47546] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 08:41:32.030459 2019] [:error] [pid 5593] [client 192.168.254.37:39576] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
[Tue Oct 29 08:41:32.036803 2019] [:error] [pid 20288] [client 192.168.254.37:39578] PHP Fatal error: Uncaught Error: Call to a member function refreshWidget() on boolean in /var/www/html/plugins/alexaapi/core/php/jeeAlexaapi.php:133
Stack trace:
#0 {main}
warning: commands will be executed using /bin/sh
job 91 at Tue Oct 29 08:49:00 2019
