J’ai régulierement le message d’erreur, quand je dis regulierement c’est plusieurs fois par heure.
2022-12-18 02:55:04 SomfyHomeAlarm Attention le plugin Somfy Home Alarme n’a recu de message depuis 1 min
Version Jeedom: 4.3.9
Version debian: 10.9
Version plugin: 2022-07-29
Je mets les logs ci-dessous, si quelqu’un à une idée.
> 0441|[2022-12-18 02:45:05.988]WARNING : websocket connected
> 0442|[2022-12-18 02:45:05.997]DEBUG : Received message: {"key":"websocket.connection.ready","message_id":"dc4fb1be79390594"}
> 0443|[2022-12-18 02:45:10]DEBUG : État du démon: ok
> 0444|[2022-12-18 02:45:58.369]DEBUG : Received message: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"tCOUTymfzq6jZTRmtOYhI8RmudcE2DkH","device_lost":false,"rlink_quality":-64,"rlink_quality_percent":75,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:45:58.000000Z","diagnosis":{"is_everything_ok":true,"problems":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e70d65617d"}
> 0445|[2022-12-18 02:45:58.370]DEBUG : Unknown message type: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"tCOUTymfzq6jZTRmtOYhI8RmudcE2DkH","device_lost":false,"rlink_quality":-64,"rlink_quality_percent":75,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:45:58.000000Z","diagnosis":{"is_everything_ok":true,"problems":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e70d65617d"}
> 0446|[2022-12-18 02:45:58.505]DEBUG : Received message: {"profiles":["owner","admin"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"site.device.testing.status","diagnosis":{"main_status":"ok","main_message":"diagnosis.ok","main_message_vars":{},"device_diagnosis_available":true,"device_diagnosis_expired":false,"items":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e70d6770d0"}
> 0447|[2022-12-18 02:45:58.505]DEBUG : Unknown message type: {"profiles":["owner","admin"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"site.device.testing.status","diagnosis":{"main_status":"ok","main_message":"diagnosis.ok","main_message_vars":{},"device_diagnosis_available":true,"device_diagnosis_expired":false,"items":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e70d6770d0"}
> 0448|[2022-12-18 02:50:04.759]DEBUG : Signal 15 caught, exiting...
> 0449|[2022-12-18 02:50:04.760]DEBUG : Shutdown
> 0450|[2022-12-18 02:50:04.760]DEBUG : Removing PID file /tmp/jeedom/SomfyHomeAlarm/somfyd.pid
> 0451|[2022-12-18 02:50:04.789]DEBUG : Exit 0
> 0452|[2022-12-18 02:50:05]DEBUG : Lancement démon SomfyProtect : /usr/bin/python3 /var/www/html/plugins/SomfyHomeAlarm/resources/somfyprotectd/somfyprotectd.py --loglevel debug --callback http://x.x.x.x/plugins/SomfyHomeAlarm/core/php/jeeSomfyHomeAlarm.php --apikey ILTpJfnL90jFcjvEFJn9OFb2WYIu8e5ilVkUFD3DsZCgst5p5VN4d8FMepKQgPBX --pidfile /tmp/jeedom/SomfyHomeAlarm/somfyd.pid --username "lafamilledauphin@gmail.com" --password "no44GsNkRHCFTNARGjDK" --cachepath /tmp/jeedom/SomfyHomeAlarm/.token
> 0453|[2022-12-18 02:50:05]DEBUG : État du démon: nok
> 0454|[2022-12-18 02:50:05.406]INFO : Start demond
> 0455|[2022-12-18 02:50:05.406]INFO : Log level : debug
> 0456|[2022-12-18 02:50:05.406]INFO : PID file : /tmp/jeedom/SomfyHomeAlarm/somfyd.pid
> 0457|[2022-12-18 02:50:05.406]INFO : Apikey : ILTpJfnL90jFcjvEFJn9OFb2WYIu8e5ilVkUFD3DsZCgst5p5VN4d8FMepKQgPBX
> 0458|[2022-12-18 02:50:05.406]INFO : Callback : http://.x.x.x/plugins/SomfyHomeAlarm/core/php/jeeSomfyHomeAlarm.php
> 0459|[2022-12-18 02:50:05.406]INFO : cachepath : /tmp/jeedom/SomfyHomeAlarm/.token
> 0460|[2022-12-18 02:50:05.407]DEBUG : Writing PID 19105 to /tmp/jeedom/SomfyHomeAlarm/somfyd.pid
> 0461|[2022-12-18 02:50:05.407]DEBUG : Init request module v2.28.1
> 0462|[2022-12-18 02:50:05.408]INFO : Starting websocket
> 0463|[2022-12-18 02:50:05.408]DEBUG : Opening websocket connection to wss://websocket.myfox.io/events/websocket?token=ZjJlMDY3MWE1YWVlYmY4M2MxNzBjZmQxMzNjODkxNDI2ZmVjMDFiYmJlM2MxY2EwM2Y3MTk4YmYwNmY5OTdkNw
> 0464|[2022-12-18 02:50:05.544]WARNING : websocket connected
> 0465|[2022-12-18 02:50:05.548]DEBUG : Received message: {"key":"websocket.connection.ready","message_id":"6fb46990c05b5c14"}
> 0466|[2022-12-18 02:50:07.955]DEBUG : Received message: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"2FHqvdaUl8uduD2Jc1BUlxOEZtcUS7bd","device_lost":false,"rlink_quality":-64,"rlink_quality_percent":75,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:50:07.000000Z","diagnosis":{"is_everything_ok":true,"problems":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e71cfe57c8"}
> 0467|[2022-12-18 02:50:07.955]DEBUG : Unknown message type: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"2FHqvdaUl8uduD2Jc1BUlxOEZtcUS7bd","device_lost":false,"rlink_quality":-64,"rlink_quality_percent":75,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:50:07.000000Z","diagnosis":{"is_everything_ok":true,"problems":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e71cfe57c8"}
> 0468|[2022-12-18 02:50:08.028]DEBUG : Received message: {"profiles":["owner","admin"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"site.device.testing.status","diagnosis":{"main_status":"ok","main_message":"diagnosis.ok","main_message_vars":{},"device_diagnosis_available":true,"device_diagnosis_expired":false,"items":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e71d00336e"}
> 0469|[2022-12-18 02:50:08.029]DEBUG : Unknown message type: {"profiles":["owner","admin"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"site.device.testing.status","diagnosis":{"main_status":"ok","main_message":"diagnosis.ok","main_message_vars":{},"device_diagnosis_available":true,"device_diagnosis_expired":false,"items":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e71d00336e"}
> 0470|[2022-12-18 02:50:10]DEBUG : État du démon: ok
> 0471|[2022-12-18 02:50:14.241]DEBUG : Received message: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"9HoQYfGaWpADJ2UWrzyshScrtrlRxRM4","device_lost":false,"rlink_quality":-80,"rlink_quality_percent":50,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:50:14.000000Z","diagnosis":{"is_everything_ok":true,"problems":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e71d636f8d"}
> 0472|[2022-12-18 02:50:14.242]DEBUG : Unknown message type: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"9HoQYfGaWpADJ2UWrzyshScrtrlRxRM4","device_lost":false,"rlink_quality":-80,"rlink_quality_percent":50,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:50:14.000000Z","diagnosis":{"is_everything_ok":true,"problems":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e71d636f8d"}
> 0473|[2022-12-18 02:54:04.622]DEBUG : Received message: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"tSLiY42rxLaWJjqAHkgDkNPYpIniMNar","device_lost":false,"rlink_quality":-57,"rlink_quality_percent":100,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:54:04.000000Z","diagnosis":{"is_everything_ok":true,"problems":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e72bc942c8"}
> 0474|[2022-12-18 02:54:04.623]DEBUG : Unknown message type: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"tSLiY42rxLaWJjqAHkgDkNPYpIniMNar","device_lost":false,"rlink_quality":-57,"rlink_quality_percent":100,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:54:04.000000Z","diagnosis":{"is_everything_ok":true,"problems":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e72bc942c8"}
> 0475|[2022-12-18 02:54:04.740]DEBUG : Received message: {"profiles":["owner","admin"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"site.device.testing.status","diagnosis":{"main_status":"ok","main_message":"diagnosis.ok","main_message_vars":{},"device_diagnosis_available":true,"device_diagnosis_expired":false,"items":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e72bcb0fc7"}
> 0476|[2022-12-18 02:54:04.741]DEBUG : Unknown message type: {"profiles":["owner","admin"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"site.device.testing.status","diagnosis":{"main_status":"ok","main_message":"diagnosis.ok","main_message_vars":{},"device_diagnosis_available":true,"device_diagnosis_expired":false,"items":[]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e72bcb0fc7"}
> 0477|[2022-12-18 02:55:04.417]DEBUG : Signal 15 caught, exiting...
> 0478|[2022-12-18 02:55:04.417]DEBUG : Shutdown
> 0479|[2022-12-18 02:55:04.417]DEBUG : Removing PID file /tmp/jeedom/SomfyHomeAlarm/somfyd.pid
> 0480|[2022-12-18 02:55:04.450]DEBUG : Exit 0
> 0481|[2022-12-18 02:55:04]DEBUG : Lancement démon SomfyProtect : /usr/bin/python3 /var/www/html/plugins/SomfyHomeAlarm/resources/somfyprotectd/somfyprotectd.py --loglevel debug --callback http://x.x.x.x/plugins/SomfyHomeAlarm/core/php/jeeSomfyHomeAlarm.php --apikey ILTpJfnL90jFcjvEFJn9OFb2WYIu8e5ilVkUFD3DsZCgst5p5VN4d8FMepKQgPBX --pidfile /tmp/jeedom/SomfyHomeAlarm/somfyd.pid --username "lafamilledauphin@gmail.com" --password "no44GsNkRHCFTNARGjDK" --cachepath /tmp/jeedom/SomfyHomeAlarm/.token
> 0482|[2022-12-18 02:55:04]DEBUG : État du démon: nok
> 0483|[2022-12-18 02:55:04.947]INFO : Start demond
> 0484|[2022-12-18 02:55:04.947]INFO : Log level : debug
> 0485|[2022-12-18 02:55:04.947]INFO : PID file : /tmp/jeedom/SomfyHomeAlarm/somfyd.pid
> 0486|[2022-12-18 02:55:04.947]INFO : Apikey : ILTpJfnL90jFcjvEFJn9OFb2WYIu8e5ilVkUFD3DsZCgst5p5VN4d8FMepKQgPBX
> 0487|[2022-12-18 02:55:04.948]INFO : Callback : http://x.x.x.x/plugins/SomfyHomeAlarm/core/php/jeeSomfyHomeAlarm.php
> 0488|[2022-12-18 02:55:04.948]INFO : cachepath : /tmp/jeedom/SomfyHomeAlarm/.token
> 0489|[2022-12-18 02:55:04.948]DEBUG : Writing PID 28496 to /tmp/jeedom/SomfyHomeAlarm/somfyd.pid
> 0490|[2022-12-18 02:55:04.948]DEBUG : Init request module v2.28.1
> 0491|[2022-12-18 02:55:04.949]INFO : Starting websocket
> 0492|[2022-12-18 02:55:04.950]DEBUG : Opening websocket connection to wss://websocket.myfox.io/events/websocket?token=ZjJlMDY3MWE1YWVlYmY4M2MxNzBjZmQxMzNjODkxNDI2ZmVjMDFiYmJlM2MxY2EwM2Y3MTk4YmYwNmY5OTdkNw
> 0493|[2022-12-18 02:55:05.100]WARNING : websocket connected
> 0494|[2022-12-18 02:55:05.108]DEBUG : Received message: {"key":"websocket.connection.ready","message_id":"6945e2cf3016a6b0"}
> 0495|[2022-12-18 02:55:09]DEBUG : État du démon: ok
> 0496|[2022-12-18 02:56:35.856]DEBUG : Received message: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"9HoQYfGaWpADJ2UWrzyshScrtrlRxRM4","device_lost":false,"rlink_quality":-89,"rlink_quality_percent":25,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:56:35.000000Z","diagnosis":{"is_everything_ok":false,"problems":["weak_signal"]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e7353cd339"}
> 0497|[2022-12-18 02:56:35.857]DEBUG : Unknown message type: {"profiles":["admin","owner","installer_write"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"device.status","device_id":"9HoQYfGaWpADJ2UWrzyshScrtrlRxRM4","device_lost":false,"rlink_quality":-89,"rlink_quality_percent":25,"battery_level":100,"recalibration_required":false,"cover_present":true,"last_status_at":"2022-12-18T01:56:35.000000Z","diagnosis":{"is_everything_ok":false,"problems":["weak_signal"]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e7353cd339"}
> 0498|[2022-12-18 02:56:35.926]DEBUG : Received message: {"profiles":["owner","admin"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"site.device.testing.status","diagnosis":{"main_status":"ok","main_message":"diagnosis.ok","main_message_vars":{},"device_diagnosis_available":true,"device_diagnosis_expired":false,"items":[{"device_id":"9HoQYfGaWpADJ2UWrzyshScrtrlRxRM4","problem":"weak_signal"}]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e7353de86c"}
> 0499|[2022-12-18 02:56:35.927]DEBUG : Unknown message type: {"profiles":["owner","admin"],"site_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp","type":"testing","key":"site.device.testing.status","diagnosis":{"main_status":"ok","main_message":"diagnosis.ok","main_message_vars":{},"device_diagnosis_available":true,"device_diagnosis_expired":false,"items":[{"device_id":"9HoQYfGaWpADJ2UWrzyshScrtrlRxRM4","problem":"weak_signal"}]},"message_id":"fEerFkXQafDiMgUOhkSXgjs3659qOMUp639e7353de86c"}
