Merci pour ton aide.
Pour activer l’alarme, je vais dans Expose de l’alarme sous Z2M, je choisis le type de son, le level, et la durée et je fais appliquer et elle sonne.
Dans les logs cela semble donner :
Debug 2023-04-06 21:58:11Received MQTT message on 'zigbee2mqtt/Sirene Evo/set' with data '{"warning":{"duration":2,"level":"low","mode":"burglar"}}'
Debug 2023-04-06 21:58:11Publishing 'set' 'warning' to 'Sirene Evo'
Debug 2023-04-06 21:58:11Received Zigbee message from 'Sirene Evo', type 'commandStatusChangeNotification', cluster 'ssIasZone', data '{"extendedstatus":0,"zonestatus":1}' from endpoint 1 with groupID 0
Info 2023-04-06 21:58:11MQTT publish: topic 'zigbee2mqtt/Sirene Evo', payload '{"ac_status":false,"alarm":true,"battery_low":false,"device":{"applicationVersion":0,"friendlyName":"Sirene Evo","hardwareVersion":0,"ieeeAddr":"0x000d6f0010306a15","manufacturerID":65440,"manufacturerName":"","model":"PSE03-V1.1.0","networkAddress":9676,"powerSource":"DC Source","softwareBuildID":"1.1.0","stackVersion":0,"type":"Router","zclVersion":1},"enrolled":true,"linkquality":160,"max_duration":180,"restore_reports":false,"supervision_reports":false,"tamper":false,"test":false}'
Debug 2023-04-06 21:58:13Received Zigbee message from 'Sirene Evo', type 'commandStatusChangeNotification', cluster 'ssIasZone', data '{"extendedstatus":0,"zonestatus":0}' from endpoint 1 with groupID 0
Info 2023-04-06 21:58:13MQTT publish: topic 'zigbee2mqtt/Sirene Evo', payload '{"ac_status":false,"alarm":false,"battery_low":false,"device":{"applicationVersion":0,"friendlyName":"Sirene Evo","hardwareVersion":0,"ieeeAddr":"0x000d6f0010306a15","manufacturerID":65440,"manufacturerName":"","model":"PSE03-V1.1.0","networkAddress":9676,"powerSource":"DC
Merci d’avance pour ton aide.
