Ajout moteur de rideaux XIAOMI
Je viens de lancer la migration de ma COMBEE II / DECONZ vers ELELABS / ZIGBEE, principalement pour bénéficier de la visualisation du réseau et des capacités du plugin de la team JEEDOM pour référencer de nouveaux équipements.
Serait il possible d’ajouter le moteur de rideaux XIAOMI ? : Lien ICI
Image :
Les logs lors de l’inclusion :
[2021-04-30 08:42:26][DEBUG] : {"device_joined":"00:15:8d:00:02:b3:07:9e"}
[2021-04-30 08:42:27][DEBUG] : {"device_initialized":"00:15:8d:00:02:b3:07:9e"}
[2021-04-30 08:42:27][DEBUG] : {"devices":{"00:15:8d:00:02:b3:07:9e":{"1":[{"5":{"value":"lumi.curtain","cluster_name":"Basic"},"1":{"value":"1","cluster_name":"Basic"}}]}}}
[2021-04-30 08:42:29][DEBUG] : {"devices":{"00:15:8d:00:02:b3:07:9e":{"1":[{"0":{"value":"1","cluster_name":"Basic"},"2":{"value":"2","cluster_name":"Basic"},"3":{"value":"17","cluster_name":"Basic"}}]}}}
[2021-04-30 08:42:30][DEBUG] : {"devices":{"00:15:8d:00:02:b3:07:9e":{"1":[{"7":{"value":"PowerSource.Mains_single_phase","cluster_name":"Basic"}}]}}}
[2021-04-30 08:42:31][DEBUG] : {"devices":{"00:15:8d:00:02:b3:07:9e":{"1":[{"6":{"value":"07-17-2020","cluster_name":"Basic"}}]}}}
[2021-04-30 08:42:32][DEBUG] : {"devices":{"00:15:8d:00:02:b3:07:9e":{"1":[{"65281":{"value":"\u0003(","cluster_name":"Basic"}}]}}}
[2021-04-30 08:42:57][DEBUG] : {"ieee":"00:15:8d:00:02:b3:07:9e"}
[2021-04-30 08:42:57][DEBUG] : {"ieee":"00:15:8d:00:02:b3:07:9e","attributes":[{"endpoint":1,"cluster_type":"in","cluster":10,"attributes":{"0":673080177,"1":1}}],"allowQueue":false}
[2021-04-30 08:44:05][DEBUG] : {"ieee":"00:15:8d:00:02:b3:07:9e"}
Données brutes :
    "ieee": "00:15:8d:00:02:b3:07:9e",
    "nwk": 63879,
    "status": 2,
    "lqi": "192",
    "rssi": "-52",
    "last_seen": "1619767785.4963582",
    "node_descriptor": "01:40:8e:5f:11:7f:64:00:00:00:64:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 514,
            "profile_id": 260,
            "manufacturer": "LUMI",
            "model": "lumi.curtain",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 13,
                    "name": "AnalogOutput",
                    "attributes": []
                    "id": 258,
                    "name": "Window Covering",
                    "attributes": []
                    "id": 19,
                    "name": "MultistateOutput",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": []
                    "id": 1030,
                    "name": "Occupancy Sensing",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 1
                            "id": 1,
                            "name": "app_version",
                            "value": 1
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 17
                            "id": 4,
                            "name": "manufacturer",
                            "value": "LUMI"
                            "id": 5,
                            "name": "model",
                            "value": "lumi.curtain"
                            "id": 6,
                            "name": "date_code",
                            "value": "07-17-2020"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 258,
                    "attributes": []
                    "id": 13,
                    "attributes": []
                    "id": 19,
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 1,
                    "attributes": []
                    "id": 1030,
                    "attributes": []
    "signature": {
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
            "manufacturer_code": 4447,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 100,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 100,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 514,
                "input_clusters": [
                    0,
                    4,
                    3,
                    5,
                    10,
                    258,
                    13,
                    19,
                    6,
                    1,
                    1030
                    25,
                    10,
                    13,
                    258,
                    19,
                    6,
                    1,
                    1030
    "class": "zigpy.device"
Ca sera disponible dans la beta de demain
Top ! Merci @Loic !
