Ajout module volet roulant SC500ZB LoraTop
Est-til possible d’ajouter ce module LoraTop SC500ZB:
Lien du site d’achat :[https://fr.aliexpress.com/item/1005003123388237.html?spm=a2g0s.9042311.0.0.5cd96c37e9U8ss]
    "ieee": "00:0d:6f:ff:fe:b0:1a:42",
    "nwk": 28055,
    "status": 2,
    "lqi": "252",
    "rssi": "-55",
    "last_seen": "1635443960.7095206",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 514,
            "profile_id": 260,
            "manufacturer": "_TZ3000_8kzqqzu4",
            "model": "TS130F",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 68
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_8kzqqzu4"
                            "id": 5,
                            "name": "model",
                            "value": "TS130F"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 6,
                    "name": "TuyaWithBacklightOnOffCluster",
                    "attributes": [
                            "id": 32769,
                            "name": "backlight_mode",
                            "value": 0
                    "id": 258,
                    "name": "Window Covering",
                    "attributes": [
                            "id": 8,
                            "name": "current_position_lift_percentage",
                            "value": 100
                            "id": 61440,
                            "name": "tuya_moving_state",
                            "value": 1
                            "id": 61441,
                            "name": "calibration",
                            "value": 1
                            "id": 61442,
                            "name": "motor_reversal",
                            "value": 0
                            "id": 61443,
                            "name": "calibration_time",
                            "value": 100
    "signature": {
        "model": "TS130F",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 514,
                "input_clusters": [
                    0,
                    4,
                    5,
                    10,
                    6,
                    258
                    25
    "class": "zhaquirks.tuya.ts130f"
Débug Zigbee:
[2021-10-30 19:11:41][ERROR] : Erreur exécution de la commande [Extérieur ][Lampe Extérieur Avant][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"80:4b:50:ff:fe:b3:55:32","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"","code":0}
[2021-10-30 19:27:02][ERROR] : Erreur exécution de la commande [Extérieur ][Lampe Extérieur Avant][Off] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"80:4b:50:ff:fe:b3:55:32","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0xbbf7:1:0x0006]: Message send failure","code":0}
[2021-10-30 19:40:41][ERROR] : Erreur exécution de la commande [Extérieur ][Lampe Extérieur Avant][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"80:4b:50:ff:fe:b3:55:32","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0xbbf7:1:0x0006]: Message send failure","code":0}
[2021-10-30 19:56:03][ERROR] : Erreur exécution de la commande [Extérieur ][Lampe Extérieur Avant][Off] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"80:4b:50:ff:fe:b3:55:32","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0xbbf7:1:0x0006]: Message send failure","code":0}
[2021-11-02 15:35:45][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyACM1 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey VDaJN7BWOLVAQgKKJ9amWf2M0UkZBflb --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller deconz --sub_controller auto --channel 15
[2021-11-02 15:35:53][DEBUG] : null
[2021-11-02 15:36:11][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-02 15:36:11][DEBUG] : {"ieee":"08:6b:d7:ff:fe:01:a7:49","cmd":[{"endpoint":1,"cluster":"window_covering","command":"down_close","await":1}],"allowQueue":false}
[2021-11-02 15:36:11][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x02","cluster_name":"Window Covering"}}}}}}
[2021-11-02 15:36:11][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::8 => 0 convert to 0
[2021-11-02 15:36:11][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::61440 => enum8.undefined_0x02 convert to 2
[2021-11-02 15:36:16][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-02 15:36:16][DEBUG] : {"ieee":"08:6b:d7:ff:fe:01:a7:49","cmd":[{"endpoint":1,"cluster":"window_covering","command":"stop","await":1}],"allowQueue":false}
[2021-11-02 15:36:17][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":{"258":{"8":{"value":"40","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-11-02 15:36:17][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::8 => 40 convert to 40
[2021-11-02 15:36:17][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::61440 => enum8.undefined_0x01 convert to 1
[2021-11-02 15:36:20][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-02 15:36:20][DEBUG] : {"ieee":"08:6b:d7:ff:fe:01:a7:49","cmd":[{"endpoint":1,"cluster":"window_covering","command":"up_open","await":1}],"allowQueue":false}
[2021-11-02 15:36:20][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":{"258":{"8":{"value":"40","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x00","cluster_name":"Window Covering"}}}}}}
[2021-11-02 15:36:20][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::8 => 40 convert to 40
[2021-11-02 15:36:20][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::61440 => enum8.undefined_0x00 convert to 0
[2021-11-02 15:36:26][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-11-02 15:36:26][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::8 => 0 convert to 0
[2021-11-02 15:36:26][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::61440 => enum8.undefined_0x01 convert to 1
[2021-11-02 15:36:29][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-02 15:36:29][DEBUG] : {"ieee":"08:6b:d7:ff:fe:01:a7:49","cmd":[{"endpoint":1,"cluster":"window_covering","command":"go_to_lift_percentage","await":1,"args":[29]}],"allowQueue":false}
[2021-11-02 15:36:29][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x02","cluster_name":"Window Covering"}}}}}}
[2021-11-02 15:36:29][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::8 => 0 convert to 0
[2021-11-02 15:36:29][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::61440 => enum8.undefined_0x02 convert to 2
[2021-11-02 15:36:33][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":{"258":{"8":{"value":"29","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-11-02 15:36:33][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::8 => 29 convert to 29
[2021-11-02 15:36:33][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::61440 => enum8.undefined_0x01 convert to 1
[2021-11-02 15:36:37][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-02 15:36:37][DEBUG] : {"ieee":"08:6b:d7:ff:fe:01:a7:49","cmd":[{"endpoint":1,"cluster":"window_covering","command":"go_to_lift_percentage","await":1,"args":[0]}],"allowQueue":false}
[2021-11-02 15:36:37][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":{"258":{"8":{"value":"29","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x00","cluster_name":"Window Covering"}}}}}}
[2021-11-02 15:36:37][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::8 => 29 convert to 29
[2021-11-02 15:36:37][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::61440 => enum8.undefined_0x00 convert to 0
[2021-11-02 15:36:41][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"},"61440":{"value":"enum8.undefined_0x01","cluster_name":"Window Covering"}}}}}}
[2021-11-02 15:36:41][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::8 => 0 convert to 0
[2021-11-02 15:36:41][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::258::61440 => enum8.undefined_0x01 convert to 1
[2021-11-02 15:36:44][DEBUG] : {"devices":{"08:6b:d7:ff:fe:01:a7:49":{"1":[{"1":{"value":"68","cluster_name":"Basic"},"65506":{"value":"27","cluster_name":"Basic"}}]}}}
[2021-11-02 15:36:45][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::0::1 => 68 convert to 68
[2021-11-02 15:36:45][DEBUG] : Search attribut for 08:6b:d7:ff:fe:01:a7:49 logicalId : 1::0::65506 => 27 convert to 27
vous remerciant :slight_smile:
@wilboc
Relecture de la documentation du plugin pour fournir tout ce qui est nécessaire pour que ce soit pris en compte, sinon cela restera lettre morte.
https://doc.jeedom.com/fr_FR/plugins/automation%20protocol/zigbee/
J’ai mis à jour la fiche.
J’espère avoir tout mis.
Est-ce qu’il vous manque quelques choses ?
N’hésitez pas
Les modules ont bien été ajoutés dans la dernière version bêta.
Merci :wink: !
Rebonjour,
Je suis en train d’ajouter mes derniers modules VR et ils ne sont pas identifié automatiquement par Jeedom.
J’ai essayeé de sélectionner le module TS130F manuellement dans la liste, comme pour les autres, mais aucunes commandes ne fonctionnent.
J’ai remarqué que le nom zigbee du fabricants était différent.
Les 1ers modules se nomment : TS130F_TZ3000_8kzqqzu4
Les derniers, non intégré automatiquement : TF130F_TZ3000_dbpmpco1
La photo du produit est la même
Je vous trace les donnés brutes ci-dessous:
    "ieee": "a4:c1:38:2f:2b:da:dc:a7",
    "nwk": 16622,
    "status": 2,
    "lqi": "255",
    "rssi": "-64",
    "last_seen": "1636531112.963593",
    "node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 514,
            "profile_id": 260,
            "manufacturer": "_TZ3000_dbpmpco1",
            "model": "TS130F",
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 67
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "_TZ3000_dbpmpco1"
                            "id": 5,
                            "name": "model",
                            "value": "TS130F"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "attributes": []
                    "id": 258,
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS130F",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 514,
                "input_clusters": [
                    0,
                    4,
                    5,
                    6,
                    258
                    10,
                    25
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
et les logs zigbee en erreur…
[2021-11-10 10:15:46][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2021-11-10 10:15:46][DEBUG] : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","endpoint":1,"cluster":258,"cluster_type":"in","attributes":[8],"allowCache":0}
[2021-11-10 10:15:56][INFO] : [Aucun][TZ3000_dbpmpco1.TS130F a4:c1:38:2f:2b:da:dc:a7] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","endpoint":1,"cluster":258,"cluster_type":"in","attributes":[8],"allowCache":0} erreur : {"state":"error","result":"[0x40ee:1:0x0102]: Message send failure","code":0}
[2021-11-10 10:16:20][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-10 10:16:20][DEBUG] : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"go_to_lift_percentage","await":1,"args":[50]}],"allowQueue":false}
[2021-11-10 10:16:24][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-10 10:16:24][DEBUG] : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"stop","await":1}],"allowQueue":false}
[2021-11-10 10:16:25][ERROR] : Erreur exécution de la commande [Aucun][TZ3000_dbpmpco1.TS130F a4:c1:38:2f:2b:da:dc:a7][Stop] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"stop","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x40ee:1:0x0102]: Message send failure","code":0}
[2021-11-10 10:16:33][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-10 10:16:33][DEBUG] : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"go_to_lift_percentage","await":1,"args":[50]}],"allowQueue":false}
[2021-11-10 10:16:34][ERROR] : Erreur exécution de la commande [Aucun][TZ3000_dbpmpco1.TS130F a4:c1:38:2f:2b:da:dc:a7][Position] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"go_to_lift_percentage","await":1,"args":[50]}],"allowQueue":false} erreur : {"state":"error","result":"[0x40ee:1:0x0102]: Message send failure","code":0}
[2021-11-10 10:16:37][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-10 10:16:37][DEBUG] : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"up_open","await":1}],"allowQueue":false}
[2021-11-10 10:16:38][ERROR] : Erreur exécution de la commande [Aucun][TZ3000_dbpmpco1.TS130F a4:c1:38:2f:2b:da:dc:a7][Monter] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"up_open","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x40ee:1:0x0102]: Message send failure","code":0}
[2021-11-10 10:16:39][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2021-11-10 10:16:39][DEBUG] : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"down_close","await":1}],"allowQueue":false}
[2021-11-10 10:16:40][ERROR] : Erreur exécution de la commande [Aucun][TZ3000_dbpmpco1.TS130F a4:c1:38:2f:2b:da:dc:a7][Descendre] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"down_close","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x40ee:1:0x0102]: Message send failure","code":0}
[2021-11-10 10:16:41][ERROR] : Erreur exécution de la commande [Aucun][TZ3000_dbpmpco1.TS130F a4:c1:38:2f:2b:da:dc:a7][Position] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"a4:c1:38:2f:2b:da:dc:a7","cmd":[{"endpoint":1,"cluster":"window_covering","command":"go_to_lift_percentage","await":1,"args":[50]}],"allowQueue":false} erreur : {"state":"error","result":"[0x40ee:1:0x0102]: Message send failure","code":0}
Dispo s’il manque quelques choses !
Rebonjour,
Pensez-vous que cette référence de module va être intégrée ?
En vous remerciant,
S’ils ne peuvent être intégrés.
Il faut que je me charge de les renvoyer et il me reste que peu de temps pour prendre cette décision.
Est-il possible qu’un membre de la Team Jeedom puisse me confirmer ou non la possible prise en charge de cette version du module ?
Merci d’avance.
Je viens de passer sur ZigbeeLinker MQTT.
Toutes les générations sont bien reconnus, beaucoup plus de commande.
Plugin bien plus rapide.
Dans mon cas, je suis très déçu du plugin officiel.
