Ajout module Terncy-LS01
Serait’il possible d’ajouter le module Terncy-LS01 au plugin zigbee.
Merci et bravo pour ce plugin.
Patrice
https://fr.aliexpress.com/item/32994762257.html?spm=a2g0o.productlist.0.0.7d7e4806EnzVCc&algo_pvid=6cbc393e-fd65-4637-8fdc-e12962f20e1d&algo_expid=6cbc393e-fd65-4637-8fdc-e12962f20e1d-2&btsid=0b0a187916190059618741694edddc&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
    "ieee": "00:0d:6f:00:10:6a:72:43",
    "nwk": 56760,
    "status": 2,
    "lqi": "160",
    "rssi": "-60",
    "last_seen": "1619005872.5146995",
    "node_descriptor": "01:40:8e:28:12:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": null,
            "model": "TERNCY-LS01",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 0
                            "id": 5,
                            "name": "model",
                            "value": "TERNCY-LS01"
                            "id": 7,
                            "name": "power_source",
                            "value": 0
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
    "signature": {
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
            "manufacturer_code": 4648,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    3,
                    6
                    25
    "class": "zigpy.device"
Terncy-LS01
Merci pour le json ca sera disponible dans la beta de demain
Merci Loic
