Sauf erreur de ma part ;), je n’ai pas trouvé ce module dans le pluging
ci dessous les renseignements demandés :
- le modèle exact** du module avec un lien :
Détecteur de fumée TYZB01_dsjszp0x.TS0205
Page Not Found - Aliexpress.com
"ieee": "84:71:27:ff:fe:04:bb:4c",
"nwk": 6451,
"status": 2,
"lqi": "108",
"rssi": "-73",
"last_seen": "1623663486.9281764",
"node_descriptor": "02:40:80:00:00:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 1026,
"profile_id": 260,
"manufacturer": "_TYZB01_dsjszp0x",
"model": "TS0205",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 64
"id": 4,
"name": "manufacturer",
"value": "_TYZB01_dsjszp0x"
"id": 5,
"name": "model",
"value": "TS0205"
"id": 7,
"name": "power_source",
"value": 3
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 3,
"name": "Identify",
"attributes": []
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 16,
"name": "cie_addr",
"value": [
90,
35,
73,
254,
255,
114,
2,
92
"signature": {
"model": "TS0205",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 0,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
1280
3,
25
"class": "zigpy.device"
une image représentative sur fond transparent :
Sur la page de l’équipement, cliquer sur le bouton bleu Configuration du module :
TYZB01_dsjszp0x.TS0205.txt (4,1 Ko) -
Mettre le démon en
debugdepuis la page de configuration du plugin et le redémarrer.
TYZB01_dsjszp0x.TS0205_zigbee.log (12,9 Ko)
[2021-06-14 12:06:36][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":{"2820":{"1291":{"value":"25","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:06:36][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::2820::1291 => 25
[2021-06-14 12:06:49][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":{"2820":{"1291":{"value":"15","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:06:49][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::2820::1291 => 15
[2021-06-14 12:06:51][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":[{"1":{"value":"67","cluster_name":"Basic"}}]}}}
[2021-06-14 12:06:51][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::0::1 => 67
[2021-06-14 12:06:57][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:06:57][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:2c:42","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:06:57][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:29:cf","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:06:59][DEBUG] : {"devices":{"00:12:4b:00:22:67:98:de":{"1":{"1029":[{"value":"4266","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-06-14 12:06:59][DEBUG] : Search attribut for 00:12:4b:00:22:67:98:de logicalId : 1::1029::0 => 4266
[2021-06-14 12:07:01][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:07:01][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:2c:42","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:07:01][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:29:cf","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:07:02][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:07:02][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:2c:42","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:07:03][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:07:03][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:29:cf","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:07:03][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":[{"1":{"value":"67","cluster_name":"Basic"}}]}}}
[2021-06-14 12:07:03][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::0::1 => 67
[2021-06-14 12:07:06][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:07:06][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:2c:42","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:07:06][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":{"2820":{"1291":{"value":"23","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:07:06][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::2820::1291 => 23
[2021-06-14 12:07:06][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:29:cf","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:07:19][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":{"2820":{"1291":{"value":"14","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:07:19][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::2820::1291 => 14
[2021-06-14 12:07:27][DEBUG] : {"devices":{"84:71:27:ff:fe:71:2e:39":{"1":{"1026":[{"value":"2424","cluster_name":"Temperature Measurement"}]}}}}
[2021-06-14 12:07:27][DEBUG] : Search attribut for 84:71:27:ff:fe:71:2e:39 logicalId : 1::1026::0 => 2424
[2021-06-14 12:07:29][DEBUG] : {"devices":{"00:12:4b:00:22:67:98:de":{"1":{"1029":[{"value":"4187","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-06-14 12:07:29][DEBUG] : Search attribut for 00:12:4b:00:22:67:98:de logicalId : 1::1029::0 => 4187
[2021-06-14 12:07:36][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":{"2820":{"1291":{"value":"27","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:07:36][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::2820::1291 => 27
[2021-06-14 12:07:44][DEBUG] : {"devices":{"84:71:27:ff:fe:76:47:e5":{"1":{"1026":[{"value":"2238","cluster_name":"Temperature Measurement"}]}}}}
[2021-06-14 12:07:44][DEBUG] : Search attribut for 84:71:27:ff:fe:76:47:e5 logicalId : 1::1026::0 => 2238
[2021-06-14 12:07:49][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":{"2820":{"1291":{"value":"14","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:07:49][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::2820::1291 => 14
[2021-06-14 12:07:50][DEBUG] : http://127.0.0.1:57600/device/info?ieee=84%3A71%3A27%3Aff%3Afe%3A04%3Abb%3A4c type : GET
[2021-06-14 12:07:50][DEBUG] : {"ieee":"84:71:27:ff:fe:04:bb:4c"}
[2021-06-14 12:07:58][DEBUG] : {"devices":{"60:a4:23:ff:fe:3d:48:77":{"1":{"1026":[{"value":"2444","cluster_name":"Temperature Measurement"}]}}}}
[2021-06-14 12:07:58][DEBUG] : Search attribut for 60:a4:23:ff:fe:3d:48:77 logicalId : 1::1026::0 => 2444
[2021-06-14 12:07:59][DEBUG] : {"devices":{"00:12:4b:00:22:67:98:de":{"1":{"1029":[{"value":"4246","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-06-14 12:07:59][DEBUG] : Search attribut for 00:12:4b:00:22:67:98:de logicalId : 1::1029::0 => 4246
[2021-06-14 12:08:06][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":{"2820":{"1291":{"value":"25","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:08:06][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::2820::1291 => 25
[2021-06-14 12:08:19][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":{"2820":{"1291":{"value":"14","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:08:19][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::2820::1291 => 14
[2021-06-14 12:08:19][DEBUG] : {"devices":{"84:71:27:ff:fe:04:bb:4c":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.0","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"255","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-06-14 12:08:19][DEBUG] : Search command for 84:71:27:ff:fe:04:bb:4c logicalId : 1::1280::cmd::1 => ZoneStatus.0
[2021-06-14 12:08:19][DEBUG] : Search command for 84:71:27:ff:fe:04:bb:4c logicalId : 1::1280::cmd::1.1 => bitmap8.0
[2021-06-14 12:08:19][DEBUG] : Search command for 84:71:27:ff:fe:04:bb:4c logicalId : 1::1280::cmd::1.2 => 255
[2021-06-14 12:08:19][DEBUG] : Search command for 84:71:27:ff:fe:04:bb:4c logicalId : 1::1280::cmd::1.3 => 0
[2021-06-14 12:08:35][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":{"2820":{"1291":{"value":"27","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:08:35][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::2820::1291 => 27
[2021-06-14 12:08:49][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":{"2820":{"1291":{"value":"14","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:08:49][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::2820::1291 => 14
[2021-06-14 12:09:00][DEBUG] : {"devices":{"00:12:4b:00:22:67:98:de":{"1":{"1029":[{"value":"4177","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-06-14 12:09:00][DEBUG] : Search attribut for 00:12:4b:00:22:67:98:de logicalId : 1::1029::0 => 4177
[2021-06-14 12:09:02][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:09:02][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:2c:42","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:09:02][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:29:cf","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:09:06][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":{"2820":{"1291":{"value":"27","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:09:06][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::2820::1291 => 27
[2021-06-14 12:09:06][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:09:06][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:2c:42","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:09:06][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:29:cf","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:09:19][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":{"2820":{"1291":{"value":"14","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:09:19][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::2820::1291 => 14
[2021-06-14 12:09:21][DEBUG] : {"devices":{"84:71:27:ff:fe:76:47:e5":{"1":{"1026":[{"value":"2237","cluster_name":"Temperature Measurement"}],"1029":[{"value":"6307","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-06-14 12:09:21][DEBUG] : Search attribut for 84:71:27:ff:fe:76:47:e5 logicalId : 1::1026::0 => 2237
[2021-06-14 12:09:21][DEBUG] : Search attribut for 84:71:27:ff:fe:76:47:e5 logicalId : 1::1029::0 => 6307
[2021-06-14 12:09:30][DEBUG] : {"devices":{"00:12:4b:00:22:67:98:de":{"1":{"1029":[{"value":"4266","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-06-14 12:09:30][DEBUG] : Search attribut for 00:12:4b:00:22:67:98:de logicalId : 1::1029::0 => 4266
[2021-06-14 12:09:31][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":[{"1":{"value":"67","cluster_name":"Basic"}}]}}}
[2021-06-14 12:09:31][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::0::1 => 67
[2021-06-14 12:09:35][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":{"2820":{"1291":{"value":"25","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:09:35][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::2820::1291 => 25
[2021-06-14 12:09:42][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":[{"1":{"value":"67","cluster_name":"Basic"}}]}}}
[2021-06-14 12:09:42][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::0::1 => 67
[2021-06-14 12:09:42][DEBUG] : {"devices":{"84:71:27:ff:fe:04:bb:4c":{"1":{"1280":{"cmd":{"1":{"value":"ZoneStatus.Alarm_1","cluster_name":"IAS Zone"},"1.1":{"value":"bitmap8.0","cluster_name":"IAS Zone"},"1.2":{"value":"255","cluster_name":"IAS Zone"},"1.3":{"value":"0","cluster_name":"IAS Zone"}}}}}}}
[2021-06-14 12:09:42][DEBUG] : Search command for 84:71:27:ff:fe:04:bb:4c logicalId : 1::1280::cmd::1 => ZoneStatus.Alarm_1
[2021-06-14 12:09:42][DEBUG] : Search command for 84:71:27:ff:fe:04:bb:4c logicalId : 1::1280::cmd::1.1 => bitmap8.0
[2021-06-14 12:09:42][DEBUG] : Search command for 84:71:27:ff:fe:04:bb:4c logicalId : 1::1280::cmd::1.2 => 255
[2021-06-14 12:09:42][DEBUG] : Search command for 84:71:27:ff:fe:04:bb:4c logicalId : 1::1280::cmd::1.3 => 0
[2021-06-14 12:09:49][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:29:cf":{"1":{"2820":{"1291":{"value":"14","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:09:49][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:29:cf logicalId : 1::2820::1291 => 14
[2021-06-14 12:09:54][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:09:54][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:2c:42","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:09:54][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:29:cf","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:09:57][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:09:57][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:2c:42","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:09:58][DEBUG] : http://127.0.0.1:57600/device/command type : PUT
[2021-06-14 12:09:58][DEBUG] : {"ieee":"84:fd:27:ff:fe:c2:29:cf","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-06-14 12:10:00][DEBUG] : {"devices":{"00:12:4b:00:22:67:98:de":{"1":{"1029":[{"value":"4177","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-06-14 12:10:00][DEBUG] : Search attribut for 00:12:4b:00:22:67:98:de logicalId : 1::1029::0 => 4177
[2021-06-14 12:10:05][DEBUG] : {"devices":{"84:fd:27:ff:fe:c2:2c:42":{"1":{"2820":{"1291":{"value":"25","cluster_name":"Electrical Measurement"}}}}}}
[2021-06-14 12:10:05][DEBUG] : Search attribut for 84:fd:27:ff:fe:c2:2c:42 logicalId : 1::2820::1291 => 25
[2021-06-14 12:10:09][DEBUG] : {"devices":{"84:71:27:ff:fe:71:8a:ba":{"1":{"1029":[{"value":"4813","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-06-14 12:10:09][DEBUG] : Search attribut for 84:71:27:ff:fe:71:8a:ba logicalId : 1::1029::0 => 4813
Merci d’avance
Un très grand Bravo pour votre système Ultra performant et toutes ces évolutions dont vous nous faites profiter
très bonne journée à vous tous
Nicolas
