Ajout Miboxer FUT035Z
Je viens d’acheter ce module https://miboxer.com/light/xqy/fut035z.html, après quelques manigances pour l’appairage il est reconnu comme TZ3210_jtifm80b.TS0502B.
J’arrive a faire varier l’intensité du blanc froid mais pas à regler la température de couleur.
Ci dessous les données brutes:
    "ieee": "a4:c1:38:7d:80:15:3a:22",
    "nwk": 50910,
    "status": 2,
    "lqi": "220",
    "rssi": "-45",
    "last_seen": "1658320823.159737",
    "node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 268,
            "profile_id": 260,
            "manufacturer": "_TZ3210_jtifm80b",
            "model": "TS0502B",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
                    "id": 8,
                    "name": "Level control",
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 1
                    "id": 768,
                    "name": "Color Control",
                    "attributes": [
                            "id": 7,
                            "name": "color_temperature",
                            "value": 153
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 98
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3210_jtifm80b"
                            "id": 5,
                            "name": "model",
                            "value": "TS0502B"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS0502B",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 268,
                "input_clusters": [
                    3,
                    4,
                    5,
                    6,
                    4096,
                    8,
                    768,
                    61184,
                    0
                    25,
                    10
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
Pensez vous qu’il est possible de l’ajouter, vous pouvez me guider pour la démarche ?
Merci par avance,
Anthony
Hello
Cela a t il été fait ?
Je viens de faire aussi l’acquisition d’un FUTO35Z.
Mon Jeddom le reconnais comme un FUTO38Z.
Du coup:
  • ON/OFF => OK
  • Variation d’intensité => BOF
    • 100% => 0V sur WW et 16V sur CW
    • 0% => 0V sur WW et 15V sur CW
  • Variation de la couleur => aucune variation.
Un idée sur la modification du module dans jeedom?
Je viens de faire des essais:
Visiblement la commande: 1::light_color::move_to_color_temp::#slider#::0
n’a aucun effet.
Elle ne permet pas de modifier les valeurs de la commande: 1::768::7
Du coup je ne sais pas trop ou chercher pour essayer de faire fonctionner le module.
Quelqu’un pourrait nous aider? Car pour commander les bandeaux LED il y a pluseurs boitier pas mal chez Miboxer.
Sachant que le plugin zigbee n’évoluera plus car remplacé par le nouveau plugin jeezigbee qui s’appuie sur la base de donnée zigbee2mqtt qui est bien plus complète je vous conseilles de n pas trop investigué sur le plugin zigbee.
Effectivement, je viens de passer sur JeeZigbee…
Tout est OK! Je peux entièrement piloter le module FUTO35Z.
Bonjour, comment avez vous fait pour inclure votre contrôleur miboxer!?
J’ai un miboxer FUT035s pour piloter un ruban led mono couleur, je n’arrive pas à l’inclure sur ma jeedom smart.
Je possède un conbee2 et utilise habituellement le plugin deconz.
N’arrivant pas à l’inclure avec deconz j’ai installé le plugin jeezigbee mais en vain…
Merci de votre aide,
Cdlt,
Romain
Attention vous ne pouvez pas faire tourné les plugins deconz et jeezigbee avec une seul clé, c’est soit l’un soit l’autre et votre commentaire mais en vain ne veux pas dire grand chose, il faudrai plus de détail
… dans un nouveau sujet
