Voici une demande d’ajout pour le dimmer IKEA.
Site du fabricant :
Information brute :
"ieee": "00:0b:57:ff:fe:25:3e:b8",
"nwk": 46442,
"status": 2,
"lqi": "196",
"rssi": "-51",
"last_seen": "1637860020.033767",
"node_descriptor": "02:40:80:7c:11:52:52:00:00:00:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 2064,
"profile_id": 260,
"manufacturer": "IKEA of Sweden",
"model": "TRADFRI wireless dimmer",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 17
"id": 2,
"name": "stack_version",
"value": 87
"id": 3,
"name": "hw_version",
"value": 30
"id": 4,
"name": "manufacturer",
"value": "IKEA of Sweden"
"id": 5,
"name": "model",
"value": "TRADFRI wireless dimmer"
"id": 6,
"name": "date_code",
"value": "20160923"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": "1.1.1.1-5.7.2.0"
"id": 1,
"name": "Power Configuration",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 9,
"name": "Alarms",
"attributes": []
"id": 2821,
"name": "Diagnostic",
"attributes": []
"id": 4096,
"attributes": []
"signature": {
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4476,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 0,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
9,
2821,
4096
3,
4,
6,
8,
25,
4096
"class": "zigpy.device"
Log Zigbee en debug :
[2021-11-25 18:04:40][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"7","cluster_name":"Level control"},"1":{"value":"[]","cluster_name":"Level control"},"1.1":{"value":"195","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:40][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 7 convert to 7
[2021-11-25 18:04:40][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1.1 => 195 convert to 195
[2021-11-25 18:04:41][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"5","cluster_name":"Level control"},"1":{"value":"0","cluster_name":"Level control"},"1.1":{"value":"195","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:41][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 5 convert to 5
[2021-11-25 18:04:41][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1 => 0 convert to 0
[2021-11-25 18:04:41][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1.1 => 195 convert to 195
[2021-11-25 18:04:41][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":[{"value":"7","cluster_name":"Level control"},{"value":"[]","cluster_name":"Level control"}]}}}}}
[2021-11-25 18:04:41][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 7 convert to 7
[2021-11-25 18:04:43][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":[{"value":"7","cluster_name":"Level control"},{"value":"[]","cluster_name":"Level control"}]}}}}}
[2021-11-25 18:04:43][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 7 convert to 7
[2021-11-25 18:04:49][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"1","cluster_name":"Level control"},"1":{"value":"1","cluster_name":"Level control"},"1.1":{"value":"195","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:49][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 1 convert to 1
[2021-11-25 18:04:49][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1 => 1 convert to 1
[2021-11-25 18:04:49][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1.1 => 195 convert to 195
[2021-11-25 18:04:51][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"1","cluster_name":"Level control"},"1":{"value":"1","cluster_name":"Level control"},"1.1":{"value":"195","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:51][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 1 convert to 1
[2021-11-25 18:04:51][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1 => 1 convert to 1
[2021-11-25 18:04:51][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1.1 => 195 convert to 195
[2021-11-25 18:04:52][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"7","cluster_name":"Level control"},"1":{"value":"[]","cluster_name":"Level control"},"1.1":{"value":"195","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:52][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 7 convert to 7
[2021-11-25 18:04:52][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1.1 => 195 convert to 195
[2021-11-25 18:04:55][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"5","cluster_name":"Level control"},"1":{"value":"0","cluster_name":"Level control"},"1.1":{"value":"195","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:55][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 5 convert to 5
[2021-11-25 18:04:55][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1 => 0 convert to 0
[2021-11-25 18:04:55][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1.1 => 195 convert to 195
[2021-11-25 18:04:55][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"7","cluster_name":"Level control"},"1":{"value":"[]","cluster_name":"Level control"},"1.1":{"value":"195","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:55][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 7 convert to 7
[2021-11-25 18:04:57][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"1","cluster_name":"Level control"},"1":{"value":"1","cluster_name":"Level control"},"1.1":{"value":"195","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:57][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 1 convert to 1
[2021-11-25 18:04:57][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1 => 1 convert to 1
[2021-11-25 18:04:57][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1.1 => 195 convert to 195
[2021-11-25 18:04:57][DEBUG] : {"devices":{"00:0b:57:ff:fe:25:3e:b8":{"1":{"8":{"cmd":{"0":{"value":"4","cluster_name":"Level control"},"1":{"value":"0","cluster_name":"Level control"},"1.1":{"value":"1","cluster_name":"Level control"}}}}}}}
[2021-11-25 18:04:57][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::0 => 4 convert to 4
[2021-11-25 18:04:57][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1 => 0 convert to 0
[2021-11-25 18:04:57][DEBUG] : Search command for 00:0b:57:ff:fe:25:3e:b8 logicalId : 1::8::cmd::1.1 => 1 convert to 1
Photo du produit :
J’espère n’avoir rien oublié.
Eleckito21
